Dimitris Posted February 13, 2009 Share Posted February 13, 2009 Hi! Anyone knows the Ohlins code number for the Ohlins rearshock of the Rosso Corsa-Scura models? As far as the Ohlins front forks, the code is FG313, am I right? Link to comment Share on other sites More sharing options...
Paul Minnaert Posted February 13, 2009 Share Posted February 13, 2009 Should be pressed in, I think the scura and later models had different tuned rearshocks, but I'm not shure. Forks are 313 right. You won't find much on them at the ohlins site because they are made for guzzi. I think there is a topic that has the numbers: http://www.v11lemans.com/forums/index.php?showtopic=9000 Link to comment Share on other sites More sharing options...
Greg Field Posted February 14, 2009 Share Posted February 14, 2009 Ohlins USA doesn't offer anything for Guzzi. Elsewhere, they may. Link to comment Share on other sites More sharing options...
Guzzirider Posted February 14, 2009 Share Posted February 14, 2009 Harris Performance in the UK can get them for you. They used to be about £700- not sure what the price is now. Antonio used to be able to source them cheaply-nor sure if he still can. Cheers Guy Link to comment Share on other sites More sharing options...
S251 Posted February 25, 2009 Share Posted February 25, 2009 This was on the forum from July 3 2002 from al_roethlisberger@yahoo.com Sanford, NC USA BTW, since there have been some lack-luster reviews of the rear OEM Ohlins shock on the Scura (justified or not rolleyes.gif ) ... here is Ohlins direct replacement for anyone interested: Brand Model Year Moto-Guzzi V11 2002 Öhlins shock absorber Part No. Type Position Comment MG 127 46HRCS Rear " • Type 46PRC with hose mounted reservoir, easy to fit where it is easy to reach. • Fully adjustable single shock absorber. • Improved cooling gives more consistent damping and longer damper life. • Features compression, rebound and hydraulic pre-load adjuster. Hi! Anyone knows the Ohlins code number for the Ohlins rearshock of the Rosso Corsa-Scura models? As far as the Ohlins front forks, the code is FG313, am I right? Link to comment Share on other sites More sharing options...
Dimitris Posted February 25, 2009 Author Share Posted February 25, 2009 Thank you for your help! Link to comment Share on other sites More sharing options...
