This stream auto-updates
  1. Past hour
  2. Hunter Valley NSW
  3. Today
  4. activpop
    V11 kickstand
    Geez @Tomchri, when you gonna clean those things...
  5. activpop
    V11 kickstand
    Looked closely and measured both the 04 and the 01. Looks the same to me.
  6. I would check the nut on the gearbox carefully to see if it's split. If so, you could use a clamp or perhaps a sturdy zip tie to tighten it on the thread after assembly. If not, a few wraps of teflon tape should tighten the threads up enough to keep it in place.
  7. Instead of loctite, you could use a very very small amount of Blue Hylomar on the thread, would provide enough "stickiness" w/o creating a locking situation. I couldn't imagine how it would spin off by itself unless it was well enough loose, or the Quota is like a paint shaker and vibrates like hell. Seems unlikely though.
  8. Because somebody was looking at this topic, I had a look, and looked at the Avon site. It seems that they are still in the game. https://www.avontyres.com/de-de/reifen/?cartype=motorcycle
  9. Yesterday
  10. No, I couldn't work out which one it was. Changing the t-shirt fooled me completely. I will refrain from comparisons to Jon Lord, because that would be silly. I had the great fortune to encounter him on a couple of jobs. Polite, friendly, a real gentleman. Musically: the second time was one of those "rock meets classic" things. The orchestra was a combination of a semi-professional orchestra and students from a commercial "music academy". The finale was a Deep Purple melody, of course. They rehearsed it once without the man, and it was all correct. Then he came on stage. First thing was, the organ sounded different (better) when he played it than when the organ-hire bloke played it after he set it up. How does that work? A Hammond organ is a machine. You push a button, and a noise comes out. And on top of that, the rehearsal without was, as I said, correct. With him playing along, all of a sudden it also grooved. One man pulled an entire orchestra into the groove. Not bad, I reckon... So it would be silly to draw comparisons between a teenage girl and someone like that. The same applies to the guitarist that played the solos. She has potential, but needs a few years. Ritchie Blackmore was an experienced and creative guitarist when that song was produced. No comparison, so no comment.
  11. gstallons
    V11 kickstand
    Please include a little more information
  12. You said you did not check this when it came back from the service center? We have no way to know if it was tight or not? Get it about as snug as you would reseal a 2 liter soda. Put a dob of yellow paint pencil on it and run it a while and see what happens. I can't see what the hose clamp is doing so I can't comment on it.
  13. I reinstalled it, and I tightened it by hand. Its a very fine thread, not sure how it could come loose in the first place. But I did not check it when the instruments came back from Germany.
  14. You may have noticed the bass player is also the keyboard player...
  15. Not in a million years. If that retaining nut is working loose all the time then there is an issue with the threads on the nut. It shouldn't need any thread locker at all. Your set up looks a bit of a lash up with the screw clamp, obviously not standard. Phil
  16. Art it is . Cheers Tom.
  17. If you claim that it is art, then no-one will criticise it. In fact, I rather like photos that are taken into the light.
  18. audiomick
    V11 kickstand
    Ahh, I wondered about the colour. A different colour alone would explain the different part number, even if it is actually physically the same part.
  19. Tomchri
    V11 kickstand
    No measurement, looks the same. Black colored, looks different, sure the same. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  20. docc
    V11 kickstand
    Anyone with early and later V11s that could compare the sidestands, er "side-by-side" ?
  21. Realy bad picture. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  22. The little dude is tireless and shows some real soul in his playing. Best for all of them that he keeps his time locked with the bass. I've played with some drummers that wouldn't lock-on. After a while, everyone just packs up and goes home. In all honesty, though, our bass player is just not that cute.
  23. Yes, he is very good. And not just bashing away, he is focussed on the bass player, and she is doing a pretty flash job of it too, I reckon. What say you @docc
  24. I'm pretty sure loctite only works between metal surfaces. The data sheet here appears to confirm that. From the product description https://www.farnell.com/datasheets/24239.pdf EDIT PS: further evidence that loctite doesn't cure against plastic is that the cap on the bottle never gets glued on like, for instance, the one on the super glue tube does.
  25. audiomick
    V11 kickstand
    Maybe not. The parts lists at Wendel in Berlin show a change in the part number, at least for the "stick", around 2002. Subsequent lists refer to "Seitenständer V11 neu", i.e. "sidestand V11 new". The first version, part no. GU02432100 https://wendelmotorraeder.de/fussrasten-v11-sportmandello-99-01-ex-30_3006_300602_30060201_3006020110_300602011003.html https://wendelmotorraeder.de/fussrasten-v11-nakedle-manns-01-02-ex-30_3006_300602_30060202_3006020210_300602021003.html and the new version, part no. GU01432190 https://wendelmotorraeder.de/fussrasten-staender-v11-02-le-mansskura-ex-30_3006_300602_30060203_3006020310_300602031003.html https://wendelmotorraeder.de/fussrasten-staender-v11-03-04-corsa-ex-30_3006_300602_30060204_3006020410_300602041003.html https://wendelmotorraeder.de/fussrasten-staender-v11-03-05-cafballabio-ex-30_3006_300602_30060205_3006020510_300602051003.html However it seems that the new version might fit on the earlier models. Stein-Dinse only lists the newer part number. There is a comment in the list and in the listing in their shop "Nachfolgeprodukt für Artikel: 02432100", i.e. "replacement product for article: 02432100" https://www.stein-dinse.com/de/moto-guzzi-seitenstaender-v11-le-mans-naked-ballabio/item-2-1020771-01432190-.html and under "Geeignet für" i.e. "suitable for" they list pretty much all the V11 Models. The thlot pickens....
  1. Load more activity
