- Past hour
OK @Tomchri, maybe my sarcasm doesn't go over big up North. My apologies. Very nice lineup of bikes there! And one that looks like mine!
Do you like to dive? tired of carrying tanks?
Gmc28 replied to p6x's topic in Special place for banter and conversation
So a smaller version of the old Snuba setup, right? almost bought a snuba for a Caribbean sail trip, but I had to cancel trip for work, and never pulled trigger. Just seems way easier for shallow, tropical diving than the tanks. But wondering about weight belts, and buoyancy control in that first 1/2-1 atmosphere of change, where we like to dive and where snuba would be the ticket . - Yesterday
Green light on. Haven't touch the gear lever yet, just pushed her on the floor. Kranked her up a couple of times, all normal. Testing outside tomorrow. Cheers Tom.
On the V11, this is characteristic of a failure of the Neutral Switch --> Neutral (middle/#3) Relay. Does the Neutral Light come on in the display panel? Is the gearbox definitely in Neutral, or is it in gear? Or even in a gap between gears, but not actually in >Neutral< to activate the Neutral Switch --> #3 Relay?
It striked me, remebering when I was gone fire up my brother in law's K1100 RS. No fuel pump, sidestand up, priming. Cheers Tom.
I'm curious what @luckyescobedo thinks of his GB500. And what he is trying to achieve changing the chin pad on his V11 Sport . . .
That strikes me as being a bit odd. Mine (2002 Le Mans, which I believe should have the same wiring as a Coppa Italia) will start with the side-stand down, but the motor stops when it is put in gear with the side-stand down. However, it is too late at night for me to be able to understand the wiring diagram to that depth. Maybe I'll find time to have a closer look in the next couple of days. Or maybe not.The next few days at work promise to be fairly full. It is indeed the brain thing.
For now just welded on some more alu. My bikes have minimum time idling, so not much wear on my watch. Cheers Tom.
Bike resting on the sidestand. Sidestand up = feeding juice to fuse #2. It's the brain thing . Cheers Tom.
So the sidestand wasn't on the bike, or what? PS: you really do need to clean those bikes.
Tomchri started following Laughing is good, right!
Finished with the paint treatment, Car Pro. Put the tank on and wanted to hear her running. No fuel pump, WHAT. Usual round, direct juice to the pump= working, but no juice in the connector, ended up with, no juice in fuse 2. 2 red feeding wires underneath, have juice. All 4 male connectors underneath are actually move able? So thought bad conection. Probably possible to take apart with some dynamite. Suddenly a miracle in top floor, SIDESTAND. Back together and runs Very good. Ha ha [emoji23] Cheers Tom. Sent fra min SM-S906B via Tapatalk
@docc that would be quite pretty if it had a sensible motor sticking out from under the tank.
Trying for that slick tank look of "something else" in the collection?
audiomick replied to p6x's topic in Special place for banter and conversation
Indeed, that looks good. Expensive, but good things tend to be expensive, and I wouldn't like to trust my life to something cheap. -
Well you can forget about the Scura one if you want lower or even equal height to the original V11 rubber pad. I have a Scura one on my bike and it's at least the same height as the original and maybe even a little taller.
For the foreigners, that road is quite famous in Australia. I've never been down it, but looking at the map, I can see why one might go along there on a bike. https://www.openstreetmap.org/search?query=putty+road%2C+australia&zoom=5&minlon=-29.663085937500004&minlat=40.81380923056961&maxlon=29.487304687500004&maxlat=60.1524422143808#map=16/-33.50645/150.81744
Lucky Phil replied to p6x's topic in Special place for banter and conversation
Neat, simple. Phil -
"Don't bury me, I've got a show to play."
Hello all. I am looking for an alternative to the OEM tank/chin pad on my MY 2000 V11 (greenie). Specifically, I am looking for the OEM carbon fiber version that came on the Scura. (The goal here is to find a replacement that fills the cavity on top of the tank once the OEM pad is removed, but do so without the added height of the OEM pad - alternate part suggestions welcome!)
gstallons replied to p6x's topic in Special place for banter and conversation
This looks good ! -
He absolutely did loose it by going over the curb on the inside. But that was because he couldn't keep his bike on the actual line. He ran wide out of the previous corner, being a "left, right, left sort of corner that means being wide out of the previous corner meant he was actually way too tight going in to the corner he crashed in. That put him way over the curbing on the inside. He had numerous slides and it was clear he was pushing hard. Running wide and offline like he did was simply what that led to. The racer that followed his brother around all race saving his tires and keeping his powder dry was not the racer we saw at COTA. He was trying to make a point. That sort of victory was not going to cut it at one of "his tracks".
Besides riding a motorcycle, diving was one of my favorite hobby. I did a lot of diving in the Red Sea, Mediterranean, Atlantic, Indian ocean... Renting the tanks, filling the tanks, depending where you dive, can quickly become expensive. My "deep dives" are now behind me, and there are plenty of places where you don't need to go dark to enjoy the dives. If you like diving, I found this company, based in Australia, that proposes equipment that avoid the tanks; https://airbuddy.com/
I discovered while adding a hardened bolt to the heel of mine that there's a steel core cast inside the leg. Too bad they didn't make it a steel foot. Seems like they're hen's teeth- what happened? Is your mounting bracket ok?
I really have a hard time believing that he was pushing. There wasn't any reason to justify that he had to. One of the (plausible?) explanation was that he lost the bike by going over the curb, which (according to pundits) in the USA are not coated with anti-skid paint. Now, I completely trust that he is quite the astute man, on top of being an incredible pilot. The way he did a 180 degrees with his career, by leaving mighty Honda (including an even higher salary to stay) for a second fiddle team. this was a very bold move. I am not underevaluating Francesco Bagnaia, but when it comes to being a snake, Marc Marquez will prevail. It is being whispered that Valentino Rossi is 100% mentoring Francesco on what traps may lie ahead of him.
