Timing Cover Gasket Replacement
'03 Lemans timing cover gasket replacement.  It required removing exhaust headers because of header crossover pipe blocking removal of alternator cover, alternator, etc.  Removed the fairing to budge the fairing sub frame out of the way because timing cover will not clear it.  Loosened and moved fuel tank slightly aft but did not remove it from bike. Removed two aft most fairing sub-frame bolts, then loosened foreward most sub-frame bolts and rotated sub-frame down & forward enough to allow timing cover clearance to remove it.  E Z peezy but hope I never have to do it again.
'03 V11 Lemans
· 28 images
  • 28 images
  • 37 image comments
