Under the seat
Could use a good cleaning.
I recently added a 6th (high current starter) relay based on some comments posted on the forum. I got the relay & base from Greg Bender at This Old Tractor. The Odyssey battery is using their 90 degree "L" brackets. In addition to all the wiring at the battery posts I also added another ground wire from battery negative directly to the frame for grounding redundancy. Added a insulation to the shock spanner...at some point in this bikes life, the spanner dead shorted batt+ to ground and cooked some wiring...didn't want that to ever happen again.
