"High Current" Starter Relay, Base & Harness
I added the HC Starter Relay Harness to eliminate passing high inrush current to starter solenoid through the ignition switch based on some comments I read in the forum. My own current draw tests appeared to be very low/minimal. However, should the starter solenoid become marginal, the higher draw of the solenoid could damage the ignition switch...imho. I bought the HC Starter relay, base, fuse and harness from Greg Bender at This Old Tractor. It is s nice easy install..the relay base slides onto the existing starter relay base, Red to Batt+, Black to Batt-, spade connctors are routed to starter - Female spade to starter, Male spade to exiting starter solenoid feed wire.
https://www.thisoldtractor.com/for_sale_wiring_harness_ordering.html
2
