While I had Rosie's tank off, I was doing the usual cleaning, inspecting, etc.and found one complete strand broken on the throttle cable. She only has around 20K miles, so I'd suspect that it may be a common failure. The inner cable exits the housing at a fairly sharp angle ...
Probably wouldn't hurt to check.
Same here at 41,000 miles.  Sheesh - I should probably check mine again!
Thanks for heads-up!
From the context I'm guessing you mean at the engine end of the cable?
Yeah, you can (sort of) see where the cable wears on this out of focus picture..
Same on my 2004 Le Mans, I 'realigned' the bracket so it was straighter.
That's a good idea!
