docc Posted September 16, 2016 Share Posted September 16, 2016 OMRON, apparently, discontinued this G8HN relay (Those are the ones I'm using). You can easily run a bead of epoxy around the underside of your relay where the case joins the base and seal it yourself. What we cannot do is alter the intrinsic materials and contact sizes: GEI | OmronMoving contact material: Silver alloy | Silver alloyNC contact material: Copper | Silver alloyNO contact material: Copper | Silver alloyMoving contact diameter: 0.085/0.083 | 0.099/0.098 inchesTerminal material: Plated Brass | Plated Copper EDIT: Higher Capacity OMRON are available: http://www.v11lemans.com/forums/index.php?showtopic=19755&p=216605 Heat comparison forthcoming . . . (waiting for "riding weather." ) Link to comment Share on other sites More sharing options...
brlawson Posted September 16, 2016 Share Posted September 16, 2016 Docc, I have used the Panasonic products in the past. Discovered them when doing business with a company called Easter Beaver http://www.easternbeaver.com/Main/main.html (Canadian Guy marries a Japanese woman and...you get the rest) With all the talk about bad relays I had thought about trying some to see how they held up. They're very durable, well sealed, and tolerate heat well. They are also rated to 35amp. Not to expensive either and I trust a Japanese part to a Chinese one any day. Have seen these sold as replacements for older bikes. Upgraded connections recommended. http://www.cycleterminal.com/accessory-relays.html Spec sheet https://www.panasonic-electric-works.com/cps/rde/xbcr/pew_eu_en/ds_61204_en_cm.pdf Volume purchase: http://www.mouser.com/ProductDetail/Panasonic-Industrial-Devices/CM1-12V/?qs=UO%2Fx91QLkSBUaPb1eC%2FvuQ%3D%3D 1 Link to comment Share on other sites More sharing options...
brlawson Posted October 1, 2016 Share Posted October 1, 2016 I got several of the new relays and have been running them for a little while now with no issues so far. At first glance they do appear to be very high quality and tightly sealed. The connectors are nicely coated and while they weigh a gram or so more than the others they are at least 5% smaller so they are not crowded together as the others which may help with the heat issue addressed in this thread. 1 Link to comment Share on other sites More sharing options...
docc Posted January 18, 2017 Share Posted January 18, 2017 It's looking like "heat issues" are more a function of contact ratings, "thermal conduction path for contact heat", and load. Looking forward to installing the higher rated OMRON G8HE and re-testing temperatures. I would think that lower temperatures = *better* relays. Link to comment Share on other sites More sharing options...
docc Posted January 31, 2017 Share Posted January 31, 2017 InfraRed temperature readings with the new high capacity G8HE relays: New Relay (previous 9 year old G8HN OMRON)#1 88ºF 115ºF#2 112º 115º#3 96º (and rising while in neutral)#4 114º 125º#5 138º 147º (Again, my headlights do not run through the front relays as on factory wired early Sports.) I suppose we could conclude that Relay#5 runs a good 20ºF/7ºC hotter than #4. Yeah, you can feel that difference without putting your lips on it. A "weaker" relay in the #5 position could, theoretically, get even hotter. Link to comment Share on other sites More sharing options...
BigBlock Posted January 31, 2017 Share Posted January 31, 2017 The new G8HE relays are definitely cooler. Looks like I will be ordering some soon. Link to comment Share on other sites More sharing options...
docc Posted January 31, 2017 Share Posted January 31, 2017 Arriving home (just eleven miles with a stop for fuel), and Relay#5 was cooler yet (126ºF). Lots of variables here, no doubt. But it's easy to be encouraged by something besides just the spec sheet! Link to comment Share on other sites More sharing options...
BigBlock Posted February 2, 2017 Share Posted February 2, 2017 Any change in temps with the other relays? Link to comment Share on other sites More sharing options...
docc Posted February 2, 2017 Share Posted February 2, 2017 Any change in temps with the other relays? All the changes are posted above in Post # 20. Not sure why Relay#1 changed so much. Figure I'll recheck this repeatedly and try to get a better understanding what may have changed. Link to comment Share on other sites More sharing options...
MartyNZ Posted February 23, 2017 Share Posted February 23, 2017 I just measured the relay temps on my VIN 03 Sport Naked, and found this: First column Omron G8HN-1C2T-R-DC12 all 5 positions Second column OMRON G8HN-1C2T-R-DC12 in position 1-4 & G8HE-1C7T-R-DC12 in position 5. position 1》 37°C---38°C position 2》 51°C --51°C position 3》 52°C --54°C position 4》 58°C --54°C position 5》 63°C --50°C The temp for the Omron G8HE-1C7T-R-DC12 relay seems to be better, just as Docc's research tells us in post 20 above, and here: http://www.v11lemans.com/forums/index.php?showtopic=19755&page=5&do=findComment&comment=216605 1 Link to comment Share on other sites More sharing options...
Stick Posted March 13, 2017 Author Share Posted March 13, 2017 InfraRed temperature readings with the new high capacity G8HE relays: New Relay (previous 9 year old G8HN OMRON) #1 88ºF 115ºF #2 112º 115º #3 96º (and rising while in neutral) #4 114º 125º #5 138º 147º (Again, my headlights do not run through the front relays as on factory wired early Sports.) I suppose we could conclude that Relay#5 runs a good 20ºF/7ºC hotter than #4. Yeah, you can feel that difference without putting your lips on it. A "weaker" relay in the #5 position could, theoretically, get even hotter. Hey Docc, Thanks for taking this to a personal level. I had though it was a bit odd when I started the thread, and it seems like "they all do it". And you a VERY correct in saying that a cooler running relay is better. Switches, connectors, and wiring in general are NOT supposed to get warm or hot. It indicates that either the limit of the device (or wire) is being approached, or you have a plain old "bad connection". The only wiring I want to see warm are my grip heaters, or electric heated clothing! Stick 1 Link to comment Share on other sites More sharing options...
docc Posted October 13, 2021 Share Posted October 13, 2021 On 1/31/2017 at 3:40 PM, docc said: InfraRed temperature readings with the new high capacity G8HE relays: New Relay (previous 9 year old G8HN OMRON) #1 88ºF 115ºF #2 112º 115º #3 96º (and rising while in neutral) #4 114º 125º #5 138º 147º (Again, my headlights do not run through the front relays as on factory wired early Sports.) I suppose we could conclude that Relay#5 runs a good 20ºF/7ºC hotter than #4. Yeah, you can feel that difference without putting your lips on it. A "weaker" relay in the #5 position could, theoretically, get even hotter. On 2/23/2017 at 3:16 AM, MartyNZ said: I just measured the relay temps on my VIN 03 Sport Naked, and found this: First column Omron G8HN-1C2T-R-DC12 all 5 positions Second column OMRON G8HN-1C2T-R-DC12 in position 1-4 & G8HE-1C7T-R-DC12 in position 5. position 1》 37°C---38°C position 2》 51°C --51°C position 3》 52°C --54°C position 4》 58°C --54°C position 5》 63°C --50°C The temp for the Omron G8HE-1C7T-R-DC12 relay seems to be better, just as Docc's research tells us in post 20 above, and here: http://www.v11lemans.com/forums/index.php?showtopic=19755&page=5&do=findComment&comment=216605 My cheap infrared temp reader is only accurate to +/- 4ºF, but I wanted to bring these two posts together as it appears we have some newly available CTI relays available to be evaluated and operating temperatures have proven revealing. Link to comment Share on other sites More sharing options...
Lucky Phil Posted October 13, 2021 Share Posted October 13, 2021 I think both of you have missed the point with regards to relay temps. Guzzi have designed them as a "seat warmer". A free option not previously advertised but revealed here after 20 years. Ciao 1 2 Link to comment Share on other sites More sharing options...
docc Posted October 13, 2021 Share Posted October 13, 2021 5 minutes ago, Lucky Phil said: I think both of you have missed the point with regards to relay temps. Guzzi have designed them as a "seat warmer". A free option not previously advertised but revealed here after 20 years. Ciao Moto Guzzi seat warmers my well-digger's ass! 1 Link to comment Share on other sites More sharing options...
Weegie Posted October 13, 2021 Share Posted October 13, 2021 @brlawson I think you'll find the Panasonic are rated at 20A continuous and 35A switching. So they're not as good as the Omrons. They are very good relays though and I've used them in the past and they haven't failed, but I'd still prefer to have the Omrons. You need to check the continuous rating not the switching load John 1 Link to comment Share on other sites More sharing options...
