LAGuzzi Posted December 5, 2018 Posted December 5, 2018 I am considering getting Clearwater accessory lights and mounting them on my forks. My concern is the wiring, fusebox etc. Anyone have any experience adding electrical components?
footgoose Posted December 6, 2018 Posted December 6, 2018 Welcome to the forum LAGuzzi. They look like a knowledgable company. I'll bet they'd be inclined to give you some good wiring ideas. Are those type lights all in that price range? I think the Billie Jr brake light is interesting. Post your progress. https://www.clearwaterlights.com/pages/safety-lights
docc Posted December 7, 2018 Posted December 7, 2018 I am considering getting Clearwater accessory lights and mounting them on my forks. My concern is the wiring, fusebox etc. Anyone have any experience adding electrical components? Welcome to the forum LAGuzzi. They look like a knowledgable company. I'll bet they'd be inclined to give you some good wiring ideas. Are those type lights all in that price range? I think the Billie Jr brake light is interesting. Post your progress. https://www.clearwaterlights.com/pages/safety-lights We can talk-up sourcing power, fusing, relays, switching, and wire routing . . .
LAGuzzi Posted December 13, 2018 Author Posted December 13, 2018 They said that you just wire into the headlight so that it's automatic and you don't have to mess with it too much, they are 24 amps https://www.clearwaterlights.com/products/darla
bbolesaz Posted December 13, 2018 Posted December 13, 2018 That's 24 WATTS, not amps. 24 amps would melt the entire V11 charging system. 24W is 2 amps, EACH.
docc Posted December 13, 2018 Posted December 13, 2018 That's 24 WATTS, not amps. 24 amps would melt the entire V11 charging system. 24W is 2 amps, EACH. Adding 4 amps to the headlight switch, and the headlight relay, is definitely pushing the already marginal circuit on the V11, IMO. 4 amps is going to be pretty easy to wire for. I would still use a micro relay (rated 10+ amps NO) and a 10 amp rated switch (waterproofed if it's going to out in the weather, maybe a built in indicator light so you know when they're on). If a 5 amp inline ATC fuse doesn't hold up, go to a 7.5. It's a pretty long run from the battery to the forks, so, 16 gauge wire (18 is probably enough?) [Routing and shielding the wiring and making the connections is another matter entirely . . .]
bbolesaz Posted December 13, 2018 Posted December 13, 2018 Agreed, run the lights off of a relay for sure. Clearwater has relay kits for their lights. And some nice switch options also.
bbolesaz Posted December 13, 2018 Posted December 13, 2018 If you like simplicity (which I do), this Denali switch makes the wiring super simple. Battery, fuse, switch, lights. Easy peasy. https://www.revzilla.com/motorcycle/denali-20-dryseal-on-off-waterproof-illuminated-switch-with-handlebar-mount They sell handy little metal mounting tabs to mount the switch on and then attach to clutch perches also. 1
bbolesaz Posted December 13, 2018 Posted December 13, 2018 BTW, call the folks at Clearwater. Tell them what you want to do. They are generally very helpful.
LAGuzzi Posted December 31, 2018 Author Posted December 31, 2018 Thanks again for all your help. Clearly I have no idea about electrical systems.
JesterGrin_1 Posted December 31, 2018 Posted December 31, 2018 Here is another idea that Docc and I found out the other day lol. And that is on my 02 LM the 8th fuse has O power to it. So one could use it to carry a spare fuse or I would think if one wished they could add something to that spot with a ready made fuse holder. But I could be wrong lol. 1
al_roethlisberger Posted December 31, 2018 Posted December 31, 2018 Here is another idea that Docc and I found out the other day lol. And that is on my 02 LM the 8th fuse has O power to it. So one could use it to carry a spare fuse or I would think if one wished they could add something to that spot with a ready made fuse holder. But I could be wrong lol. And if one removes the 30A main fuse to replace with an external "maxi" fuse or circuit breaker, you get another free slot in the fuse block too. 1
