Guest bordsenius Posted April 21, 2005 Share Posted April 21, 2005 Hi all. My first posting here! Thanks for letting me join. I have ridden Guzzi's for the last 15 years, and the previous ones all had led-acid batteries. And they had to be replaced after 3-4 years. Now the battery on my V11 Sport 2001 seems to be lacking a lot of punch when I start the engine. It might be due to the fact that I live in Norway, and it's about 3 degrees centigrades here in the morning, but I seem to rememeber that the startet turned a lot faster a few years ago. How long are the batteries supposed to last? Do they losse power when they go older? I have no experience with this dry-cell battery type, so all ideas are welcome. Yours Stig bordsenius Link to comment Share on other sites More sharing options...
Mike Stewart Posted April 21, 2005 Share Posted April 21, 2005 Hi all. My first posting here! Thanks for letting me join. I have ridden Guzzi's for the last 15 years, and the previous ones all had led-acid batteries. And they had to be replaced after 3-4 years. Now the battery on my V11 Sport 2001 seems to be lacking a lot of punch when I start the engine. It might be due to the fact that I live in Norway, and it's about 3 degrees centigrades here in the morning, but I seem to rememeber that the startet turned a lot faster a few years ago. How long are the batteries supposed to last? Do they losse power when they go older? I have no experience with this dry-cell battery type, so all ideas are welcome. Yours Stig bordsenius 49263[/snapback] Hello and welcome to the site!, My 2000 V11 Sport battery died about two months ago, so I would say the battery life is still about 3 to 5 years. I also had a small leak from the battery over winter, so that is what most likely caused the battery failure in my case. Mike Link to comment Share on other sites More sharing options...
jrt Posted April 21, 2005 Share Posted April 21, 2005 Mine is still going on an '01 sport, but it lost some punch over the winter. Since it has been warming up, it's getting better again so I think it'll last this year, but not next winter. Link to comment Share on other sites More sharing options...
tikkanen Posted April 21, 2005 Share Posted April 21, 2005 Hej Stig, Velkommen, jeg tror du er den eneste nordmand, der er aktiv på denne site. Sorry for talking crypto, I'm back in English again. Regarding your morning starting routine my Scura acts exactly the same way. It takes a split second before the starter engine decides to wake up, so I wouldn't be worried. The temperatures here in Denamrk this morning was below 0, so I know how you feel. Welcome onboard! Søren PS: I'm still on the original battery Link to comment Share on other sites More sharing options...
guido Posted April 21, 2005 Share Posted April 21, 2005 Your battery will, as you know always be lazy when cold. If you haven't got a heated garage, why are you driving a Guzzi?" (slight acknowledgement to Bugatti " There could be other reasons for a slow starter, including the starter itself, but to be sure, get the battery tested. simple thing to do, it's usually free and takes a minute or so. Link to comment Share on other sites More sharing options...
Guzzirider Posted April 21, 2005 Share Posted April 21, 2005 I can recommend Hawker Odyssey batteries for cold cranking- they cost a few quid extra but last forever and are tough old cookies. Link to comment Share on other sites More sharing options...
gh67 Posted April 21, 2005 Share Posted April 21, 2005 Use a battery tender (regulated trickle charger) whenever you aren't actively riding.....your battery will love you much longer. Link to comment Share on other sites More sharing options...
jimbemotumbo Posted April 21, 2005 Share Posted April 21, 2005 I just replaced the battery on my 00 V11, after similar symptoms. Hawker Odyssey now and great starting, even in the cold. Great price at www.portablepowersystems.com and very inexpensive shipping. btw - I have two of these batteries powering my Defender 90. Less than half the weight of a single battery, enough cranking amps, and running with an isolator I have my winch and lights hooked in with full recharging. Never a problem. Tough little battery. Link to comment Share on other sites More sharing options...
jrt Posted April 21, 2005 Share Posted April 21, 2005 Can you park the bike inside the house? Link to comment Share on other sites More sharing options...
antonio carroccio Posted April 21, 2005 Share Posted April 21, 2005 Velkommen, jeg tror du er den eneste nordmand, der er aktiv på denne site. Héy Knaekebröd, keep it civil... Link to comment Share on other sites More sharing options...
Paul Minnaert Posted April 21, 2005 Share Posted April 21, 2005 in The Guzzi technical notes read this: Subject: new battery Model: V11 Problem: short life-span of the presently fitted ESA SPARK 500E battery. Solution in production: the YUASA YTZ12S battery will be fitted (comes from Yuasa already filled with fluid). In production is fitted a new wiring while on bikes with present wiring it is possible to fit the battery and reroute the cables. My last yuasa was alive for 9 years! And it was even a smaller version, ytx9-bs the YTZ12S is used in: CBR1100xx blackbird VTR 1000F VFR800Fi honda silverwing scooter '02 honda NSS250 Reflex '01-'02 So the dealers of these bikes might have them, yuasa is very good. Link to comment Share on other sites More sharing options...
belfastguzzi Posted April 21, 2005 Share Posted April 21, 2005 btw - I have two of these batteries powering my Defender 90. 49309[/snapback] Now show me yours. Link to comment Share on other sites More sharing options...
Steve G. Posted April 22, 2005 Share Posted April 22, 2005 The factory Tesco battery went in my '01 V11 last spring. Got an Oddesy dry cell, lovely strong thing. A word of caution though. Do not, I repeat DO NOT trickle charge dry cell batteries. Which ever battery you buy, read the instructions. Trickle charging dry cell batteries is a no no. Ciao, Steve G. Link to comment Share on other sites More sharing options...
dlaing Posted April 22, 2005 Share Posted April 22, 2005 My Spark 500 lasted from when I got the left over 2000 model December 2000, until December 2004. So, atleast four years...but southern california years... It might have lasted longer if I rode more frequently and did not give it too many volts when charging with my 6 amp automotive charger. Yes, it went over 15 V Maximum charging voltage for the Hawker Odyssey is 15 Volts. You can trickle charge, but follow the Odyssey guidelines. A fully charged battery is 12.84 V I don't think you should charge it once it is fully charged, which is what many do with trickle chargers. Odyssey recommend 1.25amp Battery Tender brand battery charger for keeping it charged, but not recharging. For recharging they recommend Deltran brand 6 amp and 20 amp. The Deltran also supports storage charging. ***EDIT: Warning: Read further on in the thread. Odyssey no longer recommends Deltran...and vice versa. end EDIT*** From what I can figure out, the Spark 500 is identical to the Hawker Genesis, which Hawker does not recommend nor warrant for "power sports" Instead they recommend the Hawker Odyssey. I'll let you know when my Hawker Odyssey fails Checkout the service bulletin that Paul M. mentioned, (see GH67's post at: http://www.v11lemans.com/forums/index.php?showtopic=4967&hl= ) Link to comment Share on other sites More sharing options...
dlaing Posted April 22, 2005 Share Posted April 22, 2005 Dang! Look what I just found: "Notice to Odyssey battery users HEADING_TITLE Deltran Battery Tender no longer endorses nor recommends the Hawker Energy Products Odyssey line of batteries for PowerSports vehicles. In our opinion, Hawker's advertising program for the Odyssey battery does not promote the best interest of the PowerSports industry or consuming public. The marketing department at Hawker uses the term "PCA" to rate their battery cold cranking capacity. The term "Pulse Cranking Ampere" is not a BCI (Battery Council International) industry standard and in our opinion should not be used to measure battery output. The battery industry has, and still uses, a very specific set of criteria to test batteries ("CCA"). The term "PCA" can be, and is, very misleading to the consumer because it is inconsistent with industry standards. Deltran is a forty year old family-owned business that prides itself on not only customer satisfaction, but most importantly, product safety. In our opinion the chargers specifications recommended by Hawker could be very dangerous to the average consumer if those chargers were inadvertently used on normal flooded or gel batteries. Deltran also believes that most of the today's PowerSports vehicles are supplied with standard alternators that have an output of approximately 14.2 volts. Hawker Odyssey batteries require a voltage over 14.7 volts to fully recharge the battery. The standard alternator will not return a Hawker Odyssey battery to a full state of charge. We feel that the Hawker Odyssey battery was developed for the Stand-by Power industry and not for Powersports vehicles. " source: http://batterytender.com/notice_odyssey.php So, our alternator is specified to put out 14.0-14.6 Volts, which may be fine for maintaining adequate charge, but peak battery performance must require periodic charging of 14.7 to 15.0 V. Our service manual recommends the following for charging: 52 BATTERYThe battery’s voltage is 12 V with a capacity of 13 Ah; it is charged by the generator.The battery used on the motorbike is a sealed type lead acid battery (without maintenance) which does not require any checks.CHARGING INSTRUCTIONS WARNING• It contains toxic substances (Pb e H2 SO4);• Extremely high currents, avoid short circuits;• Do not recharge in the sealed container;• Using different battery chargers will cause irreparable damage to the battery.GENERAL NOTES Charging lead acid or pure-tin sealed accumulators, just as other re-chargable accumulators, is a question of saving the energy supplied during discharge. As this process is in some ways inefficient, it is necessary to bring back tothe accumulator from 105% to 110% of the amperes-hour supplied during discharge. The quality of the power necessary to completely re-charge the battey dependson the flatness of the accumulator, on the method, re-charging time and temperature.It is important that the battery is capable of supplying all or nearly all of its capacity before receiving the requiredover-charging. However, to obtain an optimal duration interms of cycle numbers, the battery must periodicallyreceive the required over-charging. Charging can be carried out in different ways. The aim is to convey current through the battery in the direction opposite to the discharge. Constant voltage charging is the standard method used to charge lead acid type accumulators. Constant voltage charging The voltage charging method is the most efficient for charging sealed lead- acid pure-tin accumulators. Using this charging method, it is not necessary to limit the maximum current supplied by the charger. The voltage must however be adjusted so that it is within the values prescribed below. This feature is due to the internal resistance of the battery. It is extremely low and features a high recombination efficiency during charging. We recommend to observe the following values for constant voltage charging: ELECTRICAL SYSTEMACB CYCLIC USE:From 14.7V to 15.0V per battery, at 25°C. No current limit requested. BUFFER USE:From 13.50V to 13.80V per battery, at 25°C. No currentlimit requested. Removal:•Remove the saddle as described in chapter 4 sectionE;•Release the locking belt “C”;•Disconnect the negative terminal “A”, then the positi-ve “B” by unscrewing the nuts;•Remove the battery from the motorbike. N.B.Always disconnect the negative terminal first “A”then the positive one “B”.N.B. The negative terminal “A” is black , while thepositive one “B” is red. Refitting:•Apply protective spray for electrical contacts on thebattery terminal board;•Insert the battery in its seat on the motorbike;•Connect the postive terminal “B” then the negative one“A”;•Hook the locking belt “C” once again.•Refit the saddle. Link to comment Share on other sites More sharing options...
