joe camarda Posted May 27, 2003 Posted May 27, 2003 Has anyone removed and replaced the frame side-plates (that the footpegs mount onto) on their V11 Sport/LeMans? I'm considering a color change, but am wondering if the effort is worth it. On another note, does anyone have a set of these frame plates to sell or to loan to me for several years ?
Guest Jaap Posted May 27, 2003 Posted May 27, 2003 I heard that in the MG factory "Luigi" calls these things "hams" (giambone ? )
sharperdill Posted August 21, 2009 Posted August 21, 2009 Frame Plates, Pork Chops, or Hams call them what you will. I seen these in aluminum on some bikes. Will these aluminum "Pork Chops" bolt up to my original frame "2001 v11 sport"? Or are these frames completely different?
Guest ratchethack Posted August 21, 2009 Posted August 21, 2009 The OE pork chops are aluminum. They can be re-finished any way aluminum can be finished.
sharperdill Posted August 22, 2009 Posted August 22, 2009 The OE pork chops are aluminum. They can be re-finished any way aluminum can be finished. I will probably just polish mine, but I am still curious. The ones I am thinking of are the billet aluminium ones (or maybe they are cast now that I look closer). I see them quite often on 8v guzzis and a few on v11s. Did these come stock on some bikes or are they an after-market item?
raz Posted August 22, 2009 Posted August 22, 2009 They came stock on carbed Sport 1100 and pre 1997 Daytonas.
Skeeve Posted August 23, 2009 Posted August 23, 2009 Frame Plates, Pork Chops, or Hams call them what you will. I seen these in aluminum on some bikes. Will these aluminum "Pork Chops" bolt up to my original frame "2001 v11 sport"? Or are these frames completely different? They'll bolt up, but they won't fit: they're machined w/ the offset for the old 5-spd gearbox and narrow [160] rear tire, so they won't work on your V11S, even tho' all the holes in them are the correct size & distance ctr 2 ctr. The old billet pork chops sure look the t!ts, tho', don't they? At one point, I was determined to take a cad/cam class at the local junior college just so I could recreate them in the correct form to put on our later models, but work got in the way. Massive changes to the schedule there now due to the GFC, tho', so maybe I can do that someday after all?
sharperdill Posted August 23, 2009 Posted August 23, 2009 I would think there would be a market for these as an after market part.
Keith Foster Posted August 29, 2009 Posted August 29, 2009 Has anyone removed and replaced the frame side-plates (that the footpegs mount onto) on their V11 Sport/LeMans? I'm considering a color change, but am wondering if the effort is worth it. On another note, does anyone have a set of these frame plates to sell or to loan to me for several years ? I took a crack at removing them last fall for a repaint. But I gave up taking them off all of the way as a couple of bolts around the big horizontal frame tube were very tough to get to, if I recall several other things needed to unbolt to get to them, so I masked off the surrounding areas (quite the job in itself) and sprayed them in place. I'd be interested if someone has any tips.
alabamav11 Posted December 17, 2009 Posted December 17, 2009 I took mine off to get them repowdercoated. They came off fairly easily after I built a 2x4 frame to hold the front of the bike up. The trick was getting the stub axles that hold the swing arm back in. Bodged them up trying to screw them back in after I remounted the pork chops. Luckily I was able remove the porkchops and thread the stub axles in from the inside of the pork chops them remount the pork chops.
