Everything posted by MartyNZ
On a V11, you cannot set the PF3C TPS from a computer. GuzziDiag will only show you the ECU's interpretation of the TPS voltage. If the physical position of that TPS is wrong, then the ECU will have bad data. Then the ECU outputs for fuel and ignition will be sub-optimal. The TPS is set mechanically by loosening the clamp screws and twisting the TPS to the datum position. See guru Docc's instructions on how to do this here: http://www.v11lemans.com/forums/index.php?showtopic=19610.
So both Apple and Microsoft are a problem? Some days I think the same. Computers are one of the few consumer products that we expect to have trouble with. Good news. Now your bike is back to the ECU configuration it was delivered with in 2004. It's ok, but it can be awesome with a better .BIN map. Rather than loading the Ti map, (though it would be interesting to hear your views on it), you could ask Meinolf for something more developed.BTW, that Rosso Mandello map was copied from Cash1000's bike, so credit goes to him. However I forgot to ask him if it was ok to share. So yeah, Nigel, sorry, I hope you don't mind.
Here is a link to the parts you need to replace the needle roller. http://www.v11lemans.com/forums/index.php?showtopic=19514&page=2&do=findComment&comment=216691
I've been thinking about this too. As I try various ECU programs, it is obvious that exhaust gas analysis is a good way to test changes to the hardware and software on the bike. I suspect that my butt dyno can't discern a 5% change in power, especially if there is a change in noise at the same time. These guys have some interesting products that I'd like to try: http://www.zeitronix.com/index.html. AFR monitoring & logging would be the essential complement to tweaking ECU programming with TunerPro. The wideband sensor needs an 18mm port on the header or crossover, the existing plug looks too small, so I believe that I'd need to weld new ports on the headers. I just need some disposable cash. Sadly the easter bunny let me down, and xmas is a long time away.
I had some connection problems with getting the right driver for the cable. A cheap Chinese OBD2 cable would only connect to a 15M using the driver from the same site I got GuzziDiag from, but it refused to connect to a 15RC. The cable I bought from www.lonelec.co.uk worked best using Lonelec's driver. Windows 10 didn’t get the cable working, but forcing Lonelec's driver made it work. Once I consistently got a reliable connection on GuzziDiag, I have never had an issue with IAW15XWRITER. Dangerous and I both have succeeded in browsing for, and loading a .BIN file using a windows 10 or XP computer, but I can't comment about a Mac. I saw GuzziDiag fail to connect to a 15RC ECU when GD was set to a V11 model which uses 15M. It just returns a message "switch off ignition" after about 10 seconds of no other response, with no error message. Your error message could be related to a driver or cable problem.
Oil pressure during cranking (first start jitters!)
MartyNZ replied to Craig's topic in Technical Topics
Motrhead has a lesson about loose filters: http://www.v11lemans.com/forums/index.php?showtopic=19189 -
Hello Meinolf, Can you help me with a description of how to use this EEPROM Reader/Writer, and .XDF? More than one Kiwi tried the program, and then reverted to GuzziDiag after flailing around hopelessly without achieving anything. Can you help us dummies on the other side of the planet? MartyNZ
Hello John, PM me with your email address, and I can send you two .BIN maps for a 15M ECU. One is standard, and the other is a Titanium map. These will only suit a 15M ECU, not a 15RC. It is possible that some of your trouble could be if a 15M ECU is fitted to your bike, and you are telling GuzziDiag to connect to a 15RC. The 15RC was the standard fit on some 2004 V11s, with a corresponding lambda sensor in the crossover. Can you read the label on your bike to confirm what you have? Dangerous recently fitted a 15M ECU to his 2004 Nero Corsa in place of a 15RC. GuzziDiag only worked properly when we set it to a V11 model that used a 15M. The plug in the ECU is the same, and everything works the same, except that the 15M cannot see or react to inputs from the lambda sensor. He did that so he could use some of the more refined maps developed by Meinolf. If you need a standard .BIN map copied from a 15RC, I could borrow Dangerous's unused 15RC, power it up, and email you the result.
Martin, If you have a 15M or 15RC ECU in your V11, then you need GuzziDiag. A 2001 most likely has a 15M. Currently the latest GuzziDiag version is V0.47. Select the version for your computer operating system. If you bought the Lonelec cable (I recommend their well made and reliable package) then you should download the driver from their website. Even though windows 10 should make the cable work, I've seen W10 fail to connect till you visit Lonelec's site. The cable comes with good instructions. The old Windows XP netbook I use works well, with a rock solid connection to the ECU, so you don't need a new or powerful computer. The cable and GuzziDiag will let you do diagnostic checks and troubleshooting on your V11. It will also let you adjust your CO (fuel) trim. Here is the tutorial from Docc: http://www.v11lemans.com/forums/index.php?showtopic=19641 Once you get to that point, you are ready to save a copy of your .BIN file onto your computer using IAW15XREADER. This allows you to revert to the original .BIN file if you don't like any other .BIN you loaded. If you have another .BIN to load, you need IAW15XWRITER. This lets you overwrite the .BIN on the ECU with another. If you have a 15M ECU, then you could ask Meinolf if he could offer you a suitable .BIN for your bike. I'm on my 3rd .BIN, and my bike has improved from a cantankerous bitch to an awesome machine. Docc's Decent Tuneup guide can take some of the credit, but Meinolf has transformed my ECU from a croaking frog to symphonic harmony. Marty
Are you sure it isn’t a NZ beer label stuck on the frame? I only know of one NZ built bike in recent years, made by John Britten. My 03 V11 has a sticker on the spine near the steering head that says - MOTO GUZZI S.p.A. USA N. ZELANDA. ZGUKRAKRX3M1... I think that means that it was made in Italy for USA & NZ markets.
Some experts posted their experience here: http://www.v11lemans.com/forums/index.php?showtopic=19660 http://www.v11lemans.com/forums/index.php?showtopic=19814 http://www.v11lemans.com/forums/index.php?showtopic=19792 There is likely to be more good tips you could find if you use the search function Jaap built at the top of the page.
Yes, you can easily replace a seal with the shaft in place. If you search for "seal removal tool" you will see there are lots of tools that can help you. I use one like this to remove seals while the shaft is still in place: It is unlikely that you will remove the seal without damage to the seal, so you should try to have a replacement in your hand before you wreck the old one. Be careful not to scratch the shaft or seal housing as you pry it out. Have you seen this posting? http://www.v11lemans.com/forums/index.php?showtopic=19778
You have to wonder why the big manufacturers of diesel vehicles don't use this product, since it claims to offer "efficiency, durability, satisfaction, and increased performance". Perhaps the big guys like Cummins forgot to consider the need to keep out snake oil & lemming squeezings that might get into the fuel? Like you, I am intrested in things that are beneficial, but I'm not sure that this is any better than the OEM water separator & filter systems that come standard on diesel vehicles.
The Jackal workshop manual is available for download here: http://www.thisoldtractor.com/moto_guzzi_tonti_workshop_manuals___shop_manuals___service_manuals.html and FAQ here: http://www.thisoldtractor.com/moto_guzzi_tonti.html The manual mentions removing an "open washer".
I read "Total Control" written by Lee Parks. It is available as a kindle book, recommended by Scud. It has lots af good advice.
Simple Green will clean really well, but be careful. It is corrosive to aluminum if not diluted. This is why they make a different product specifically for aluminum alloys. Aircraft alloys do corrode easier than automotive alloys, but the difference is only a matter of degree. For your pistons, brief exposure at low temp, and washing it off well with hot water & detergent should avoid surface dulling and corrosion pits forming. Their data sheet http://simplegreen.com/gsa/data-sheets/ says it has alkaline pH 9. Simple Green's website says this: Aircraft — Is Simple Green All-Purpose Cleaner safe for cleaning aircraft? Simple Green manufactures a product specifically designed for use on aircraft - Extreme Simple Green Aircraft & Precision Cleaner. This product was initially developed for use in the aircraft industry and extensive testing shows it to be safe for use on aluminum, plastics, rubber, and high tech alloys, in both normal and extreme temperatures and stress conditions. Extreme Simple Green passed a variety of aircraft industry tests. Testing has been performed by Scientific Materials International, Inc. and is available upon request. http://simplegreen.com/en-nz/household/faqs/ You don't need to take my word for it, a web search for "does simple green corrode aluminum" should say something similar.
For minor seal leaks, Chuck offered a good idea here:http://www.v11lemans.com/forums/index.php?showtopic=19654&hl=film
It is worthwhile to remove the loose & flaking carbon. You would only remove the rest if that makes you feel good. In service carbon builds up again quite quickly, then reaches equilibrium. So after a few hours it would look as though you had never been in there at all.
Gregory Bender has an excellent presentation here: http://www.thisoldtractor.com/projects_roy_smith_2013-03-19_install_the_left_piston_and_cylinder.html Yes, it is a roundfin engine, but the principle remains the same. The V11 workshop manual is less specific, just saying : The end parts of the compression rings must be fitted “out of step” with each other.
Last year Scud trialed one of these dipsticks (but with a white face) and wrote a rave review here: http://www.v11lemans.com/forums/index.php?showtopic=19319&page=7&do=findComment&comment=210026
- 169 replies
- roper plate
- windage
(and 1 more)
Tagged with:
The clips are so cheap, and the cost of a clip coming loose is so big, you should not skimp. A displaced pin can score the bore beyond repair. $5 x4 https://www.motointernational.com/store/product/GU90351038 As for piston rings, you are taking a risk of breaking one if you try to remove them. If it was me, I'd only remove them if I was planning to replace them. $60 ×2 https://www.motointernational.com/store/pistoncylinder-sets/92-mm-ring-set-per-side-for-1100s
Maybe if there was enough interest, DD's exhaust maker could make some more of the shark gill style.http://www.v11lemans.com/forums/uploads/post-2086-0-43965900-1473575938.jpg See his post here: http://www.v11lemans.com/forums/index.php?showtopic=19581&page=2&do=findComment&comment=213267
You could prove to yourself whether you need the oil return hose by putting the hose into a temporary collector bottle, then going for a fast run. (after blanking off the the sump fitting of course). A split in my old breather hose meant two drips of oil out the bottom of the clutch housing everywhere I stopped, and probably faster drip rate with the engine running. Even with the split, I think most oil vapor was still getting up into the spine, and then to either the airbox or the sump. I think that this probably means that the return oil flow is more than negligible, depending on many things like power setting, rpm, oil temp/quality/quantity, Roper plate installed, piston ring wear... If you try it, can you let us know what you find out?
Can you try forcing the shaft apart hydraulically by pumping grease into the spline lube nipple?
