Everything posted by MartyNZ
Good suggestion, and is easy to check. The bike now has a Le Mans champagne tank on it that I have never used before, so some blockage is possible, although the misfire was only at low rpm. Yes, a smile for the first few minutes. It was running really well at high power, but since I was still inside an urban 80 km/hr speed limit, high power was only for a few seconds. That angry howl above 6000 is balm for the soul. I will look at those components that you suggest this week. The signal lights are "smoke" colour with amber LEDs inside. Lens P/N GU06753700 "Copetta Indic Direz Fume" is standard on a Griso 1200 8V and fits the original V11 lights. I was trying to reduce the number of different colours on the bike.
First ride after new tires, new front disks, new timing gear set, new TPS, new phase sensor, new rear shock. A nice 21°C (70°F) day. It ran really well for the first 4 km, then started misfiring badly below 3000rpm. Back home I changed the ECU BIN and looked for Guzzi Diag faults. It was still almost unrideable in slow traffic when it gets hot. The LH snorkel fell off (see pic) but I don't think this is the problem. Exhaust leak perhaps? Check the TPS again? That's tomorrow's job.
That sounds like me years ago. I started by getting helmet jacket & gloves so I could test ride a few bikes. I have a maintenance background, so a second hand bike in need of TLC was OK. I rode a few bikes that were fine, but none had the appeal of the V11. A Bonneville was good, but not exciting. A Yamaha R6 was exciting, but didn't stir my soul. I think your friend should try lots of bikes.
I fitted a Wilbers 641-519-01 to my 03 long frame bike. It's an easy swap. It is 5mm longer than the original Sachs Boge. Sachs: 280.5mm center to center. Wilbers: 285.4mm. I only realized the extra shock length when the rear tire just touched the ground while on the maintenance stand, after I fitted the new shock and a new tire.
teslas killing Motorcyclists
MartyNZ replied to KINDOY2's topic in Special place for banter and conversation
That doesn't seem right! What's your source? -
Item 19 is important. The shape improves airflow into the throttle body. It's called "velocity stack", "bellmouth", or "trumpet", and you should try hard to get the right parts. Have you checked to see if they are wedged into whatever gravel strainer pod filters you had before?
Someone with the same name as you asked that question in 2021. https://www.v11lemans.com/forums/topic/23134-v11-breather-tubes/page/2/#elControls_267496_menu
1. Style. Guzzi manages to make good looking bikes. 2. Handling. Up there with the best. 3. Brand allegiance.
I've had a new battery electric car for the last 6 months. It has all the safety features to qualify for ANCAP rating 5, and I don't regret buying it. It should engage auto braking for a bike (if I don't see it) but I'm not going to test it. Some of the critics of my choice say things that have the same tone as comments I've heard through the decades. "Tubeless tires? No thanks". "Multi-grade oil? Not for me". "Don't like auto transmission, I want to be in control". "Don't like seat belts, I want...". So yeah, I like a modern car. Even stranger are the criticisms of an electric car. "They catch fire". -Less often than ICE cars. "We're going to run out of Lithium" -It's 3rd element in the periodic table. There's shit-tons of it around. "It's mined with slave labor". -Australia is currently producing 1/2 of the world's supply, and those miners are extremely well paid. "Lithium batteries can't be recycled ". - obvious nonsense. Yes I have a 20 year old Guzzi, but I like modern stuff. -
There's a lot of discussion about cold performance of lithium batteries, but I have never noticed an issue. Push button - engine starts. But then I'm a fine weather rider too.
https://shoraipower.litema.com.au/contact/ SHORAI AUSTRALIA CONTACTS PHONE: 07 5504 5595, MOBILE: 0412 170 020 I fitted a LFX21L6-BS12 way back in 2016, still going strong. You should consider buying the dedicated charger for storage and "balance charging".
I'm happy with mine. See https://www.v11lemans.com/forums/topic/30633-share-your-lithium-battery-experience-cold-environment-durability-else/#comment-289414
Good job. Better suspension, lower unsprung weight. How does it handle? I've been wondering if there is a tire that has lower weight. A cheap way to reduce unsprung weight? I've not been able to find any info on this. I weighed a new Bridgestone Battlax 120/70ZR17 T32 at 4.39kg, and a worn BT023 at slightly heavier. Have you weighed any tires?
ANSWERED Acceleration Enrichment Map-2004 Rosso Corsa
MartyNZ replied to Rob NZ's topic in Technical Topics
Have you seen this post? -
Woah, before you buy a new regulator, how about cutting out the bad connector, and crimping the wires. A bad connector doesn't mean you have a bad regulator
+1. I think that a poor ground from the regulator to the bike is the reason for many overcharged batteries and failed regulators.
The pinch bolts make the yoke quite tight on the spline, and there may be some slight distortion of the yoke where it touches the spline. A sharp edge can get swaged/smeared so it touches the end of a spline tooth in the recess for the pinch bolts, that will make it hard to remove. Assuming there's no rust, I'd try opening the pinch slot of the yoke with wedges (big flat bladed screwdrivers) then tapping & levering.
My bike has always been the same as your bike. I don't plan to change it. The open end of the centre sliding spline faces back, so less road spray can get inside, but spline lubrication may be slightly worse with the grease nipple at the low end. As for alignment of the 2 halves of the shaft, the yokes on the shaft must be on the same plane, and the yokes on the gearbox/transmission at each end also on their own plane which is 90° turned. If it is wrong, your gearbox, shaft, and rear transmission feel torsional vibration. This would be bad. See the video pointed out by @Chuck https://youtu.be/5aCK4Bob6a0
Everyone has a favorite, so you are unlikely to get complete agreement on the best. It's hard to go wrong with the popular brands, as @GuzziMoto said. Have you seen this post: https://www.v11lemans.com/forums/topic/28190-a-test-report-for-v11-tyres/
Brad. what kind of file did you use for the inventory? I had trouble reading it.
V11 LeMans VS GRISO
MartyNZ replied to red lion's topic in Special place for banter and conversation
I got a spare lid from @Scud some years ago. I had grand plans to modify it for my bike, but decided that I liked the standard airbox so didn't use it. Also no chick in NZ seemed to dig it, so if I still have it, you can have it for nix +shipping cost. PM me. Shipping from NZ to UK varies from eye-watering to arm/leg/first born, so be warned. -
Have you seen this: Front brake disc 320 mm, Griso 1100, 307,97 € (hmb-moto.de) 307,97 € or even cheaper: Front brake disc 320 mm, V11, Cali EV, Jackal, Stone etc., 199,00 € (hmb-moto.de) 199,00 € Röttenbach is just down the road about 7 hours away from Gld Moto Guzzi manual lists part number GU01613330 Front brake disc, quantity 2
Never seen such- 254 4 cylinder
MartyNZ replied to Pressureangle's topic in Special place for banter and conversation
Chain drive? I think this is a rebadged Benelli. Cool restoration -
The Sport 1100i manual says "Absolute pressure transducer. This transducer is powered by the electronic control centre and gives information about the absolute pressure in the air filter box. This transducer is connected to the filter box through a small pipe. Its output signal will produce a correction signal as function of the barometrical pressure". On the V11 there is a pressure transducer built into the ECU.
