Everything posted by MartyNZ
Wow that's a good weight saving. What titanium alloy did you use?
Just a comment about using a white LED behind a green dash panel lens. I believe that you would get a brighter and more noticeable dash indication if you use a green LED instead of white. A green lens filters out all visible light except green. Only green can pass through, and the rest is absorbed. So, all the light from a green LED passes through the lens with no loss, because it is only green emission. LEDs have a very narrow light emission spectrum (except white LEDs). Your white LEDs are most likely blue or UV LEDs with a phosphor over the emitter surface which glows (sort of bluish) white. Then only some of this white light can pass through the lens, assuming that the bluish white light has some green component to its output. There are two losses in this. 1/ Blue to white conversion inside the LED, and 2/ white filtered by the dash panel lens, to leave only green. This means that a white LED will be dim compared to a green LED when viewed through a green dashboard lens. The same logic applies to red taillight LEDs (better than white LEDs), and amber indicator lights (better than white LEDs). EDIT If those white superbrights are bright enough when installed, then ignore what I wrote above.
I filed off a lot of the encapsulating resin of square LEDs to make them fit.
When I fitted LED indicator lamps, I needed an electronic flasher, since the current draw was too low to make the original flasher work. Then I found that the indicators on both sides flashed at the same time. Evidently the dash indicator light was providing a ground return through the other side lamps. I had to rewire the dash light as shown in the pics. EDIT: The final version has 18,000 mcd (millicandela) LEDs with 360Ω resistors.
A tantalizing presentation. Lots of interesting suggestions but little helpful information. What coatings are good? What is that "better oil"? The only takeaway I got was "ZDDP (zinc additive in oil) increases friction but decreases wear", which suggests that more is not better.
I have Penrite Pro Gear 75W-90 in my gearbox. No oil mist. The troublesome vent hose can split at the outlet on top of the bell housing, which lets oil vapor into the clutch area. When I bought my bike, it came with an oil drip at the witness hole at the bottom of the bell housing. Replacing the vent hose fixed the leak, but I couldn't see the cracks in the hose until I took it out. I have a part used bottle of Shockproof Heavy with about 750ml still in it, not quite enough for a gearbox. I bought it from Brake n Transmissions BNT
Is the vibration felt in the bars or foot pegs? How long since the cylinders were synchronized?
No. It sounds like a spacer is missing. Maybe the short one that drops out when you remove the back wheel. Or possibly a collapsed needle roller bearing in the RH outboard side of the bevel box. The inner race of that bearing is also one of the several spacers along the axle.
If it claims to fit the square head then it should be fine. Before you buy, have you seen Joe Kenny's stuff? https://www.ebay.com/usr/jjkpguzzi?_trksid=p2057872.m2748.l2754 https://www.ebay.com/itm/354611407158?hash=item52907ca936:g:IBgAAOSwWopjBW0A
If you have the time and skills, here's a design using 2 hall effect sensors and neutral SW inputs. https://www.electronics-lab.com/project/motorcycle-universal-gear-indicator/ Of course it can't figure out any missed shifts and false neutrals, so you may find it showing 7th gear
True, fair point. I have tried to shift up from 6th a few times on the open road, but it takes about the same time to attempt the shift as to glance down at a shift indicator, so I don't think I need it there. I have also found myself trying to select neutral by shifting up from 2nd instead of 1st, so an indicator could be handy there. The aftermarket shift indicators I've seen would look clumsy on my bike, so I'm prepared to go without.
Our forum, the only place I can share (MPH)
MartyNZ replied to LaGrasta's topic in Special place for banter and conversation
@Scud has a photo of his speedo showing 183mph. (Sort of) https://www.v11lemans.com/forums/topic/19038-installing-speedhut-gauges/?do=findComment&comment=221768 -
I just use the tacho or engine sound. Above 7000 change up. Below 3000 change down.
It's a good time to repaint the tube and clamping block while it is apart, to repair the road grit damage caused by that inadequate front guard.
Yes, the damper is repairable. A visit to the local seal shop is needed, then fill with ATF fluid. My damper is always on the lowest setting, so you may not need it on the long frame bike.
Any guesses which port on this air-cooled cylinder head is the exhaust port? Once water cooling is introduced, the exhaust port orientation becomes less important
My airbox is off at the moment, so I took a look. The hex head bolts holding the airbox lid down are 6mm dia x1mm pitch, length 82 & 30mm from under head to end. The screws attaching the side panels to the airbox are button head chrome or SS 5 x 0.8mm 12 mm length. The brass nipple is for the engine breather hose from the banjo at the top of the spine. Any oil resistant low pressure hose will keep oil vapour from making a mess. There should be an air temperature sensor on the front of the airbox. If it's not there, the ECU will assume a default temp, and the engine will be out of tune if the air temperature is not 20°C. The 2 screws on the rear of the airbox attach angle brackets going to frame mounts. You need those. The engine is sensitive to air leaks, so replace the cracked intake boots. The designer took some trouble to optimise the intake system, and you are restoring to that. Expect the engine to run better over the rev range, and with proper air filtration, when you finish.
I followed @Lucky Phil's experience and advice and fixed 1 leaking tap. 2 more to go. Steps are: enlarge the O-ring grooves, machine an anti-rotation slot in the plunger, adapt screw to make an anti-rotation pin, tap a hole to the valve body, fit bronze anti-friction washers on each side of the knob, put sealant under the anti-rotation pin, assemble with fuel resistant grease. @cash1000 tells me that his modified tap is easy to open/close, and it doesn't leak.
Just out of curiosity, does that top cylinder interfere with your view of the airstrip on approach?
Have you read all the posts on this site that use the words "Startus Interuptus"?
Relays front to back: 1. START (5 Pin Relay) 2. LIGHTS (4 Pin Relay. 5 Pin OK) 3. NEUTRAL/SIDESTAND (4 Pin Relay. 5 Pin OK) 4. ECU (4 Pin Relay. 5 Pin OK) 5. FUEL/COIL/INJECTION (4 Pin Relay. 5 Pin OK)
You can save your original BIN file off the ECU using the reader. Saving takes about 15 minutes. Then you can load the Meinolf BIN. Loading takes about 10 seconds. Ride and decide yeah/no. Revert by loading the original BIN, or keep, it's a no-risk choice.
I wonder if washing the seal in hot water and detergent, then drying for a day or two, would let it shrink back to normal.
If you mean the ignition switch, then dielectric grease would work, but it is best used in static connections to keep water and oxygen out. I have had good results doing general cleaning/lubrication of switchgear using automotive electrical switch grease: Lubriplate DS-ES, but any white lithium grease is good. https://www.lubriplate.com/Products/Grease/Multi-Purpose-Greases/DS-ES/DS-ES/DS-ES,-1-75-OZ-TUBE/ I use dielectric grease on all exposed electrical connections. It is particularly good on ignition coil connections, but I have heard that it is bad in vented relays, where it can mess with contact resistance when contact sparking happens.
