MartyNZ
    43
Everything posted by MartyNZ
  1. I got some aluminium foil faced self-adhesive fiberglass insulation sheet that is 1.5mm thick. It looks like it will work well, as it has some insulation against both convection heat and infra-red radiation, and if I can make a 1 piece panel, it should stay in place, and continue to do its job even if the adhesive fails.
  2. Let me know if you need some pictures of how to mount the rack. It's not immediately obvious (at least it wasn't to me).
  3. An interesting thought, but in my opinion, the change in clamp type is more likely to be a cost of manufacture decision, and also a styling choice. The earlier finned clamp has more surface area to lose heat, but since it is clamping the exhaust pipe to the head with an insulating ceramic filled gasket in between, almost all the heat lost by the clamp comes from the pipe. I think that the exhaust valve temp will be unchanged by the clamp type.
  4. I have a manometer I could loan, but I'm out on Stewart Island for 2 weeks.
  5. When I had tiny leaks on my tank, I went to replace the O-rings under the flange fittings. I noticed that the screw inserts that attach the flange to the tank had pulled out a tiny bit, creating bulges in the tank plastic. This meant that the clamping of the O-ring was reduced so allowing leaks. Running a file across the tank insert face reduced the bulging at the inserts without touching the sealing face.
  6. I think that anything is better than dry assembly if the bike ever gets wet. Jointing compound, anti-seize, or grease, are all good.
  7. My gearbox had small leaks and weeps because it was overfilled. Checking the level with the bike on the sidestand is bad. It must be vertical for minutes before you check that the level is in the middle of the sight glass. I can tell you that I can't do this by holding the bike up then bending down to check the level. I had leaks until I got it onto a maintenance stand.
  8. Black oxide conversion coating is good for corrosion protection, cheaper than cadmium plating, but not as good. Still, it is good enough.
  9. Actually we can be certain that Guzzi calculated the shear strength required correctly. If the bolt failed in shear, then we would see 2 shear planes, as the bolt is in a double shear clevis. Since the bolt usually fails under the head, or at the first thread on the shank, failure is likely caused by stress corrosion cracking or fatigue. These conditions can lead to a break at very low loads compared to simple shear. We have to stop the rust, as a rust pit is the initiation point for a crack. I believe that a new standard bolt assembled with anti-corrosion jointing compound will last a other 20 years.
  10. Yes, identical loads on each end of the reaction rod, as a single bolt forms a "pin joint". However I think that the forward end of the rod is more exposed to road spray, which explains the number of reports of the forward bolt breaking. Assembly with an anti-corrosion jointing compound like Duralac or Mastinox will reduce rust without encouraging bolt rotation as grease would. Since stress corrosion cracking is more likely on high tensile bolts, I believe that staying with the original spec bolt is a better idea, if you want it to last another 20 years.
  11. I wonder if that bolt failure is related to the condition of the needle bearing in the RH side of the bevel box? 🤔 Obviously stiffness in this bearing will increase fatigue loads on the reaction rod & bolt during suspension movement.
  12. It would be interesting to know if the heat comes from internal to the relay, or just from the engine. If engine heat is the cause of your problem, then an added baffle and reflective panel may be simpler to fit than a fan. I'm not familiar with the 1100 Sport, but is it possible that a cooling air path past the relays is blocked by extra gear under the seat? Something like a pack of spare relays? Have you considered vapor lock? I fixed a similar problem on my external pump V11 by adding reflective insulation on the pump and filter.
  13. @Chuck posted pictures of the lovely little radial 3 cyl fitted to his homebuilt here: https://www.v11lemans.com/forums/topic/19319-what-did-you-do-to-your-v11-today/page/158/#elControls_272417_menu
  14. MartyNZ
    Taped relays
    Docc is on to it (yet again); the two problems with the relays which have conflicting solutions; vibration in the sockets and heat dissipation. I tried to think of a heatsink that both held the relays steady and conducted away the heat, but the relays in my bike are all different sizes, so I decided that the problem wasn't big enough to need a solution.
  15. MartyNZ
    Taped relays
    A curious and unnatural modification alright. But then I always wondered if relays vibrating in their sockets was the reason that the relay socket contacts became loose over the years. My bike needed the KiwiRoy fix. Maybe tape or heat shrink sleeve stops jiggling and is a good thing.
  16. The guard on my oil cooler is either homemade or aftermarket. It screens out rabbits and low flying seagulls, but I cleaned out about a cupful of dirt and grit from between the cooler fins before I painted it. I think I need a fender extender.
  17. Have you read the comments in the "No Clutch!" post? https://www.v11lemans.com/forums/topic/22529-no-clutch/?do=findComment&comment=259113 On 11 April 2021 @Tinknocker suggested zip-tying the clutch lever to the grip overnight. This assumes that you have got most of the air out of the system. The theory is that pressure in the system makes the air-bubbles smaller, so the bubbles can rise to places where they can escape in the next bleed attempt. Then on 24 April @Lucky Philsuggested pushing fluid up from the slave with a syringe. Lots of good advice there. I have some disposable 60ml syringes that you can have. It is good practice not to let the reservoir get close to empty. With 6mm level remaining in the reservoir, I have seen a tiny whirlpool of air bubbles sucked down into the master cylinder when the lever is released quickly. As @gstallons suggests, having the anti-drain loop above the slave cyl bleed nipple avoids the possibility of air being sucked in as the lever is released.
  18. There's a plate at the weld to close the bottom of the crankcase breather chamber, inside the upper part of the spine. Condensed oil vapor returns to the sump from a port just above the weld. Not a new idea, but it is smart, two functions for the spine.
  19. Ha, well spotted @ScuRoo Both horses are fitted with a type of martingale. Also called a "tiedown" or a "head check". It's used to discourage head raising, which changes the angle of the pressure of the bit. If a horse is spooked or ornery, it might charge off with head raised, becoming dangerous and difficult to stop. Also stops the horse’s head from smacking the rider in the face. I imagine that the big knot has enough weight to warn the horse that the limit is approaching. See a pic of the Delaware police using another variation.
  20. NZ cops are open to other transport options too.
  21. The NZ cops have several models on the road. BMW R1200RT, Honda ST1300, Yamaha FJR1300 & MT09 Tracer. No HDs, but they do have John Deere Gator & New Holland Tractors in police livery.
  22. The spline plate can be hard to remove. The fins that engage the rubber blocks are tight, so you need a way to pry it out. A crowbar is bigger than you need, any pry bar is fine so long as you don't damage the wheel.
  23. Then you can see 12 rubber pucks in recesses in the wheel hub. Some people grease the recesses and the non-metallic ring. I coated these with moly dry lube spray. You can see that I fitted only half of the pucks in my bike, and they were drilled to be more squishy. As you assemble, check that the O-ring is good, and there is wheel bearing grease on the spline plate bore. Before you refit the wheel, put a good layer of spline grease like Staburags NBU 30 PTM on the splines at the connection to the bevel box.
  24. I'd say "don't disassemble the wheel & cush assembly" The tire can be changed as it is. Also don't lose the bush that goes on the axle between the wheel and the bevel box. It's needed to get bearing preloads right. If you're like me and can't help pulling it apart, then the following pictures may help. The retaining plate screws are likely to be frozen. Heat and penetrating oil are your friends. How hot, you ask? Well the rear disk can be red hot without other damage, but 60°C would be safe. Then you can lift the splined plate out.
  25. Actual numbers! Excellent!
