Tim
    V11
Tim's Achievements
Guzzisti
Guzzisti (2/5)
0
  1. Tim
    Tim
  2. hi - answering my own question here - found a company who will rebuild the WP shock for just under £100 (service and regas). They are called K-Tech and are based in Leicestershire (UK). Just got to remove and post it to them. Looks fairly striaghtforward to remove and refit.... Thanks for the suggestion re the Wilbers but I can't afford to buy one
  3. Took the Guzzi to France last weekend for the Le Mans 24hr bike race. On the way noticed slight difference in rear end and a suspicious looking oil slick under the shock. By the time the return journey came all damping was lost and , while smooth roads were OK, any slighlty rough roads had me pogoing all over the place. I assume the shock on my 2000 V11 is rebuildable - any advice or recommendations for rebuild v replacement and any recommendations for companies who do this sort of work - preferable in striking distance of west london. As usual all thoughts, advice and suggstions welcomed Tim
  4. erm I think he's already done that...
  5. Tim
    gearbox woes
    Yes I thought shifting was crisper but the annoying whine in top gear (been like that since I got it) seems to be a bit more noticeable. Could be my imagination though as I didn't have a tank bag on which seems to absorb noise. still no puddle appeared
  6. Tim
    gearbox woes
    Eventually got round to putting in the redline shockproof heavy and went for a run. Early indications are that the leak has disappeared. I only filled up to half way up the gearbox window will post again after I've ridden a good few more miles
  7. Dear Guzzisti I got the dreaded gearbox leak the other day on my stock 2000 V11 sport. I've done over 22,000 miles and the bike has been relatively trouble free in that time. Gearbox oil was changed just over a year ago with Rock oil synthetic 75/90 so I can't think its due to overfilling. I've looked up the gearbox threads and there seems to be a range of possiblites from changing to redline shcok proof heavy via tightening things to entire replacement of gearbox due to cracking . I'm going to have a close inspection this weekend so I wondered was if anyone has ideas about how to diagnose what the actual problem is. The different reasons for leaks all seem to have the same symptoms. Also anyone any views on the extent to which it can be ignored (I can live with a small leak if its not going to result in any dire consequences). As usual all views and comments gratefully recieved Tim
  8. Stripped the front wheel and found the inner spacer 10 thou too short. I hadn't time to get a new spacer or get one machined up so I found a 20 thou shim which gave me the slight over size as recommended by Roperman. Hopefully this should extend the pathetically short wheel bearing life I've experienced so far. Now to sort out the indicator failure.... Tim
  9. thanks Raz - obviously I didn't look hard enough is the spacer length there as well?
  10. I searched the site but couldn't find the spec for the fron wheel bearings (lunched after 3000 miles). Also has anyone got the correct length for the spacer that leves inbetween the bearings as I think I might have one of the problem ones - although I thought it wasn't a probelm on the 2000 models! Indicators all stopped working at the same time - is that the relay or a fuse? grateful for all assisatance Tim
  11. rawbolts are the answer - see my thread on this in late 2006. Use heat (hairdryer) on the hub and drive the bearing out... it might take few goes. Put the new bearings in the freezer and heat the hub again and drive the new bearings in using a pipe/socket/MG service tool on the outer race then get out on the road! Tim
  12. The l/h rear indicator has broken on my 2000 V11. I've been looking for a replacement - I seem to remeber that some triumph models use the same indicator - can anyone enlighten me? Tim
  13. Hi Folks - the Manitou fork lift truck grease gun attachemnt arrived - don't get too excited it's basically an oversized hypodermic needle but if it works it will be worth it I've attached a pictue for Belfastguzzi's benefit - however I won't be able to tell you whether it works as I'm on holiday for a few days....
  14. I prefer the term "dodge" to " bodge"!
  15. I've found a fairly successful method of bearing removal that works well, even with blind bearings. You need to use a thing called a rawbolt - a type of fixing that is used for bolting things to walls or concrete floors etc. You will find them stocked at building supply places although they may be called something else where you live. You need the type with a stud and nut rather than the bolt type and try and get one that is as close to the inner diameter of your inner race as possible. Simply stick it in the hole (oo er missus!) and tighten up as much as you dare and then (after warming the hub) drift the bearing out with a suitably large lump hammer. it might take two or three goes before it works - often you don't tighten it enough at first - but persevere, it does work! When you replace the bearings it's a good idea to put the new bearings in the freezer as well as warming the hub as they slip in nice and easy then(oo oo er missus!) Also always replace both bearings Good luck
