Tinus89
    7
Everything posted by Tinus89
  1. On technical point of view, I fully agree Luhbo. Have you ever seen a loose seat on a Guzzi head? Could that make noise without loosing compression?
  2. I don't really see why you would need to do anything else then properly degreasing the pressure plates?
  3. Soooo, That seller only has one feedback because here in the NL, there is not much use of Ebay. I know the guys is reliable and a real enthousiast. Why? Because that's me
  4. If the RAM 6-speed single disk is identical to the Guzzi single disk hub for the Scura/Tenni/Rosso Mandello, I have one for you (new). It is located in the NL though and I would need to get some other clutch tool instead (I use it as a clutch installation tool). PM if you are interested.
  5. If you refer to Page 31 pos 40, main bearing gasket: yes, very easily. I replaced mine when I had the engine apart, it's just a paper gasket like any other. Give the mating surfaces a good clean and you're ready to go. Indeed, to not forget to seal the bottom two bolts.
  6. As I pointed out on my much earlier post above. wear of the valve guides is not uncommon on a V11. Compared to the work done up to now, this is a minor issue... I would agree, but: - Would I not see significant oil consumption over the valve stems? - Could this cause a metallic rattle?
  7. I think I have made my decision indeed, to leave it for now and see if it develops for something worse, and then fix the collateral damage Thanks for the help all!
  8. I am indeed quite far away from them, but I did check with them last year (with the bike there). After listening, they gave me a list to check when I disassembled the engine. Which I did, and found nothing. I don't really feel like going there again....
  9. Sooo, I replaced both gaskets. Came out quite easily. The right one had a minor leak, see the pic: The metallic rattle is still there... Any other ideas?
  10. Of course, otherwise it would not make any sense
  11. I also replaced it, because: - I wasn't sure it was OK - The base plate of the sensor was bent (due to the too large o-ring) - The cord had already been damaged. But to be honest: I think the distance was the issue (due to the too large o-ring)
  12. I'm not sure I understand where these parts actually go? My exhaust has a flat face, which I think should seal against the gasket. I have the second series (not the crown, but the oval flange), but I think the drawing intends the use of those flanges for both...
  13. In thinking about replacing the gasket anyway, which parts should I actually order? The gasket of course, but if you look at the below picture, I don't think in the current setup, the spacer - circled in red - is installed at all? What's it's function?
  14. How do I check it? Just feel for leaks? Re-tighten it after it has been hot once? Change the gaskets preventively? The exhausts have been off about 6 or 7 times... Thanks! The Candy Red is why I fell in love with this bike:)
  15. So, after discussing a different (electrical) issue on this great forum! here: http://www.v11lemans.com/forums/index.php?showtopic=19943&page=9&do=findComment&comment=222199, I would like to re-start this discussion again. I've noticed the metallic sound is still increasing. Here is a video where you can hear it, but I will try to make a better one soon: https://www.youtube.com/watch?v=LnTi_vtetIM The sound changes/goes up with rpm. Also, it sounds like it is originating more from the right cylinder, so I want to focus on that. I have checked (and let a specialist visually inspect) every moving part in that cylinder, which are all OK. Now my focus is on the head, which is the only thing I have not disassembled. Some points for discussion: - Can a loose valve seat be observed from the bottom with the valve closed? - Could a loose valve guide (or anything else there) create a sound like this? - Could something cause the valve to close "late", which then causes the cam follower to loose contact from the cam momentarily, be pushed back with speed, causing the sound to be coming from right centre of the engine (cam follower hitting camshaft hard), contrary to the head?
  16. Yes indeed! Thanks for all contributing! Now back to the existing issue, the sound, in the other topic!
  17. Yes! Excellent progress. Methodology applied: - Put 0.78mm of tape on sensor, place one 0.4mm metal gasket (or shim) and installed. Severe denting of tape, this method does not work at all (requires a lot of tape replacements). I removed the tape. - I then placed another 0.2mm gasket on, placed the sensor in the hole and felt for radial play: gone, but just gone. Placed one layer of tape on and pushed it in, contact was shown. So: I was at zero gap. I then added a 0.7mm gasket ánd 0.7mm of tape and installed. Only a slight blob of oil visible on the tape. I added another 0.12mm piece of tape and installed it again, which indicated contact, so I had gapped it to 0.7mm! Whole process took about an hour or so. I then fired her up and did (in about 5deg C higher outside temperature compared to last time) the exact same route and then stopping and starting routine. Nothing happened! I then "confirmed" by doing a brief city tour, and again all fine. I would say: issue resolved! Some (other) findings: - The o-ring underneath the sensor was significantly too large and had compressed/extruded out underneath the gasket/shim. Also, the metal base of the sensor was bent. - The rattle seems to be coming from the inside of the right cylinder, not the left. Also, it varies with rpm and sometimes is also heard at high load/high rpm, but I am not 100% sure that is not pinging. I will continue to discuss the possible causes in my initial topic here: http://www.v11lemans.com/forums/index.php?showtopic=19627&page=8
  18. So, I have received the new camshaft position sensor. Would you: - Replace (and properly gap) the sensor with a cold engine, and then warm her up and see if the issue returns. - Warm her up, get the issues again, then with the hot engine replace the sensor (gapping might be tricky).
  19. Indeed, but I found a used one for 50eur... Also, TLM sells them for 45eur new: http://www.tlm.nl/webshop/en/sensor-tacho-and-fase-v11-017216000000-moto-guzzi?___SID=U That's a gamble I'm willing to take. The o-ring is supposed to be there according to the parts drawings (#16): Stuff like JBQuick or Engineers' Blue are impossible to get here in the Netherlands:( I'll see if I can find anything that makes sense to use...
  20. I might replace the sensor indeed... But before I do so, how do I reliably measure the air gap? I don't have anything like Engineers blue or wax, but am very willing to be creative. The owners' manual describes using a caliper, but my sensor's base plate is bent (due to the o-ring underneath) and therefore does not touch the engine block mount completely, making it impossible to measure accurately.
  21. Excellent questions. I may be able to acquire a strobe lamp. But I'm not experienced with computer-managed engines. The ECU changes pre-ignition with throttle opening and rpm, so how reliable is that check? How do I make it reliable? Also, if the ignition would be off at temperature, but not cold, would that not confirm the phase sensor to be faulty? I had not paid attention to the pump, but I just re-listened the video on my phone with headphones on: you can clearly hear the pump run and stop after the engine died. I have not tried starting it with WO throttle, cold nor hot. I will try that. Yes, she does backfire and pop into the exhaust, but I can also imagine if the phase pickup is not 100%, ignition will be off, leaving unburnt fuel in the combustion chamber, which burns on the next (wrong) ignition. The backfire is also NOT a full one, but more of a rough smokey cough backwards. It does not hurt my ears, to say.
  22. I have a Go Winky light (on the petcock connector) which stays lit solidly. Also, if the ECU would be switching off, would I not also loose the connection/readout with GuzziDiag? That did not happen when I made the video (I had the laptop connected). I will check the cam sensor visually and measure the distance to the phonic wheel, anything else I can do before the next "try"?
  23. I can't imagine it being the timing chain, as the bike runs perfectly fine when cold or warm (anything aside from "hot" really. The spark plugs look perfect and equal. It does not seem to be running rich or lean, until she stumbles. Then (of course) she smells of petrol. I will retry with the oil temp sensor and fuse #3 unplugged, and I will inspect the cam position sensor. Questions: - is fuse #3 the 30A fuse? - is there any way (except for distance) to check the cam position sensor?
  24. The regulator gives me about 14.35v with no load. When the issue occurs, my thought would be that an overvoltage would occur, causing the ecu to switch off. I checked the coils, they measured out fine, plus I cannot imagine them both failing together, as both cylinders have the misfires.
  25. So when she started stalling again, I had the same thought. Hooked up Guzzidiag and while very slowly increasing throttle until the moment she fails again, looking at TPS voltage and degrees translation as well. I even looked at the pre-ignition value while doing this, but none of them showed any jumps or numbers out of the ordinary. Questions: - if the regulator would be the source, can I measure that with an ordinary multimeter, or would that not pick up any spikes? Do I require to use a scope? - aside from regulator/TPS/timing sensor, are there any other possible culprits? Could it be mechanical? Related to the rattle?
