Tinus89
    7
Everything posted by Tinus89
  1. The distance covered was over 2.5m, so that would class it as a pressure spray right?
  2. Lovely story. Can we ask for pictures?
  3. I have, on mine. After changing the fuel filter, wanted to remove the tank again (after priming the setup a bit) for some other work. The fountain of fuel (probably aided by an air pocket in the fuel filter) was quite considerable, and unexpected after sitting for about 60min between priming and tank removal.
  4. Soooo, my spacers are 60mm. Always found them long but never considered shortening them, but I have also only used the bag once in a weekend.
  5. Yeah well thanks for this. Now I don't like my own Rosso Mandello anymore This to me is almost perfection. Remove the white ribbons on the front wheel and it is perfect.
  6. Anyone who can confirm this? I have a set of re-made racks. The PO of these racks had them on for years so they corroded and he had them re-made by a local shop in stainless steel. However, I am fairly confident my top spacer is even longer, like 60 or 80mm. I'll measure tonight.
  7. Love all the responses! We indeed do drive on the right hand side and because of that, possibly left hand corners are longer, more visible and therefore faster/more throttle causing more tire wear. Thinking of it now, I think my dual compound front tire also wore unevenly, with the pointy "egg" shape not being in the middle but a bit more on the right (so more wear left). Wheel alignment can't be it on a V11 I would have thought, but I will check whether they are in a straight line behind eachother. The inner fender also looking crooked is visual by the way, but the uneven wear definately is not camera angle but real. I can also admit to being somewhat of an ape on the clutch/throttle sometimes, causing a bit of sidestep on the rear end...
  8. Did not get the multimeter out as I did not intend to remove these connectors, but I did follow them. The small one indeed goes to the unused button on my steering damper bracket, of which I took a picture for your entertainment: The other one goes into the loom as well as to either relay one or two. So it is fairly clear to me this indeed was a connection for an alarm, which has been disconnected. I suspect the two yellow wire bridges are the actual connections the alarm electronics would make when deactivated. I think I will leave it as is, since my bike is running fine. Or do you guys disagree? To entertain you guys again, I have a small riddle for you. What is strange on my rear tire, except for the fact it is almost worn?
  9. Yeah these were in the back of the "pocket". Good to know maybe is that when I bought the bike, the actual pocket liner was missing. I installed that myself. So maybe something has been inside that tail. Nothing plugged into either connector. The yellow wire loops were indeed. Your questions are already telling me this is fairly special, so I may actually have to go and trace the wiring after all. Nope, I never got the owners manual with the bike, so no clue on the wiring harness. I don't know exactly how similar they are. My bike is a '01 with a short frame (red frame length) but with a black colored frame. There is a small button on my steering damper mount which obviously is not original, but does not do anything either. Possibly the bike has been fitted with an alarm system in the past, or PC? I will go and investigate in the coming days and report back here.
  10. Literally indeed. Because I removed the rear cover behind the gauges to solder diodes into my indicator idiot light for LED conversion.
  11. Today I started working in removing the Tupperware party Guzzi calls a rear fender. Without starting a discussion on whether this is the way to go or not, I am doing it in such a way it can always be restored to stock. Question: In my tail, I found these two. Out of curiosity and without extracting the entire wire loom to find out where they go, Anyone knows what these are?
  12. On my white face Veglia's on a 2001 Mandello Rosso (black frame, short frame) it spins cw to release. It is left-hand thread. I know this because I actually had to remove it yesterday
  13. Normally I'm like that as well, however that meant ordering parts in Netherlands, which was in a snowstorm and therefore would take at least a week, keeping me from rebuilding her and therefore working on my other bikes due to lack of space... As this bearing only sees minor movement, I'm fairly confident it will last another year or two (which usually is less than 5000km). If you are referring to the rose/heim joints, I'm less confident but they are easily checked once in a while as they are out in the open.
  14. Soooo, pushing some life back in this topic. Did my 2-yearly big maintenance including greasing of the driveshaft and checking the small needle bearing was on the list too. Findings: Bearing pre-cleaning Bearing inner race post-cleaning Bearing post-cleaning (flush with degrease & rag) I've considered cleaning up the inner race even more using scotchbrite/sandpaper, but voted against it for materials loss reasons. I've regreased and remounted the bearing for hopefully another 2years of service. Question: should I expect to change this bearing in two years time? Or should I not expect it to last this long? Also in the same subject/region: I've discovered I have some feeling play in the rose joints of the reaction rod on my bike (the lightened "sport" version of aluminium). I'll most likely have to replace that next year as well...
  15. My V11 had a Yuasa YTX14-BS in it when I bought her (2nd hand). This worked perfectly for 4 years (plus the time it was in there before I bought the bike) and then died. No leaks, nothing.... My bike is stored in a no-heated-non-insulated garage.... On the Ctek trickle charger once a month.
  16. Have you read my edited post two posts up? My explanation was fairly complete, right?:)
  17. So the front fender is brushed aluminium, which I like. The rear one is rolled aluminium. Any idea how I can get the surface finish on the rear fender close to the front one?
  18. Already have a new one installed. The old one was damaged beyond the outer races of the bearings and I did not want to try and resque it with the risk of hairline cracks or anything like that...
  19. Yes indeed, the tank is big. I don't mind. Keep in mind the goal is a scrambler (less need to look fast compared to a cafe racer), it does not yet have shocks installed (yes to fotoguzzi, I will add shocks) and no fenders & exhausts yet. Also no carbs & filters. Adding all those will add to the body of the total bike and make the tank look smaller again. I'll update once I have those installed with another picture:). Thanks for the tip on ACF-50, I'll buy that. Also maybe nice to share: rate my u-joint. Discovered upon removal of the rear swingarm, did not notice anything during driving....
  20. Hi all! I have been FAR too quiet here, apologies for this! I'm checking in with an update on the build, which I should have done more. Apologies. On the carbs, I will have them ultrasonic cleaned in the near future and have bought new choke plungers and a seal kit. I know some people may very much dislike what I have done to her so far, which is OK, but do remind yourself that this started life as a hideous white Florida, so anything is an improvement.... I also have a question. I was thinking about keeping both mudguards in bare/brushed aluminium. How do you keep that looking nice? This is the front mudguard: [
  21. Me neither... The Motoplat have long gone and been exchanged for Carmo Electronic ones. PO did that.
  22. I JUST edited the initial post to clarify this indeed... Part on my V65 Florida. All it states on there are the letters "ART" and "083".
  23. Awesome... Anyone who can shine a light on which part this is and it's function? I can't locate it on the wiring diagram... Edit: it is a part on my V65 Florida, not the V11...
  24. Thanks for the answers! It is now clear to me that my know-how of low-voltage DC systems is far to limited to fully understand the mechanics behind this, but my question on fooling the system has been answered. I'm also not aware on how much the charging system on a V65 Florida (smallblock) is similar to that of the V11. I do have another question regarding the electric system on these bikes, but I need to take a picture tonight first before I can ask. Will update once done. If this topic needs to be moved to "older models" for any further, V65 Florida questions, please do so.
  25. Hey all, I'm asking this not specifically for a V11, but it does apply to one as well, hence I am still posting this in the Tech Topics section instead of the motorcycle-specific one (older models in this case). Please move the topic if my "bending of the rules is not appreciated". If I were to consider installing a Li-ion battery on my V11 (actually in my V65 Florida build), there is a chance the output of the regulator will be too high for the Li-ion battery. Where an AGM likes to charge at 14.5-14.8v, most Li-ions charge at a maximum of 14.5, preferably less then 14v. Normally the solution is a different regulator with a lower voltage output, but that is expensive. BUT, could I also solve this issue by building some resistance between regulator positive and battery positive, such that the regulator reference voltage is e.g. 0.8-1.0v higher than the actual charge voltage to the battery? This way the regulator would charge at 14.5, but the battery would actually see 13.5v. Am I thinking too simplistic? Or would the current flow (20-25A) make it impossible to find a suitable resistor?
