Everything posted by paulnaz
Check your messages Paul B.
External tooth lockwasher, is the only washer I have. No clue what the second one is. I did find an extra bolt in my stash. Paul B washer.webp
Bolt Dimensions 14mmX1.5 pitch Thread length 28mm. I may have one in my stash and will look this afternoon. Paul B
ANSWERED Front driveshaft protection collars: no differences
paulnaz replied to docc's topic in Technical Topics
I measured a set I bought off Pinwall a while back, and they are the same measurement as yours Docc. Listed as 2001 V11, so it must be true. (short frame) Paul B -
Chuck's "Little Homebuilt"
paulnaz replied to audiomick's topic in Special place for banter and conversation
Congrats on a successful build and flight, Chuck. Paul B -
You are correct Al, They are very tight. Mine has the "credit card" clearance on both sides at the corners but I wonder if Odyssey cases are held to exact tolerances. With the rubber tray and strap on mine, it doesn't move at all. Paul B
Hi Chuck, looks like the fourth fuse goes to the ignition through a four connector molex plug. Should be Brown wire. Paul B
Early 2000 Sport ZGUKRAKR2YMXX2946. Paul B
Hi Ho Docc, You had to remind me, didn't you. In the past couple of years I've been retired and been working on our house, painting, plumbing re roofing, all the fun stuff you know. I'm almost ashamed to admit to a little over 2600 miles in that time, so I'll diligently work on increasing the numbers as my list of projects is getting shorter. Paul B
ANSWERED "Custom" V11 Cafe Racer
paulnaz replied to Joe's topic in Special place for banter and conversation
That's where the seat off my Mini Bike went ! -
If no one has the new and improved model, I can mail you my old one......lemme know Paul B
The injectors your looking for have an industry part # IW 031, These are used on Maserati's, Lamborghini's, Ducati's and Moto Guzzi. Probably Lancia, Fiat and a few others. They are made by Weber Marelli and are available through most automotive supply houses. Avoid the Chineseum Paul B
It appears that the petcock is on the Right side of the tank. If this is true where is the pressure regulator mounted, on the Left side? You may want to start with a fuel hose diagram and make sure everything is plumbed properly. The petcock turns anti clockwise to close, clockwise to open. ( when sittting on the bike) They do get stuck and may need removal and cleaning. Table 33.31v11_lemans-sport-naked_2001-2002 | Cadre Cycle Paul B
PFFFT, The salesman told me, "It's Hypersonic Kid" the old ones were supersonic. Paul B
Color bands only signify resistance value. No directional requirement. Paul B
Fill your cold tires to a pressure, write it down. Go ride for at least a half hour through hiway and twisties as best you can. Stop and check the pressures again and they should be within 10% of your initial fill. Adjust accordingly. Paul B
High idle cam (choke) underneath throttle body hanging up? If not, a can of WD40 might be useful now. Paul B looks like pressureangle beat me to it
I if you do a search on emissions and settings on google, you will find the basic info on air/fuel ratio, timing and atmospheric conditions that effect c/o, nox and co2. Your ecu is taking several parameters and trying to adjust for performance to keep those levels in acceptable range. All ecu's react differently depending on those variables and adjust accordingly Like I listed on mine, three different ecu's three different settings. Paul B
