fubar guzzi
Everything posted by fubar guzzi
  1. Thanks for the posted info.I ordered mine just now,I got free shippin+I learned where the arse end of nowhere is in AUZ
  2. I find this most confusing ---- but I guess I understand?--- the cdi is mounted to the ecu witch is next to the battery. Why didnt they abbreviate battery also??? Because 1cdi isnt enough th ey installed #2 cdi behind the side plate,so you say,whats the problem? nothing here,I'm gonna have to get me a larger bottle of Bn(bourbon) too cope!!!! Thanks for your imput
  3. Thank you Mr. Goose for your speedy reply! So, if thats the ECU what is the big square box(8")next to the battery,I thought that was the ECU!!! Please correct me,thank you.
  4. I own a 98 EV behind the side cover operator side is a THING,it looks like regulator except 2/3 times larger,has about ten wires coming from it. on it is marked,Magneti Marelli aei 450 B,can someone help me identify what this thing is? I will feel stupid later ,thanks!!!!
  5. I would like more info about the reed switch---did you make it or was that the 10 cents you spent??? Would an automotive condenser work as well? How  does the wire hook up?
  6. The golden years are catching up with me-----I was absolutely for certain your post said"know",not knob!!! that makes it much easier to fix now! Now for the good stuff ,I mentioned BOURBON cause I"m a bourbon sort of guy however last week at Gliders place ol" 2Wings fed me some IRISH WHISKEY=====best dadburn whisky I ever drank(good for rust removal 2)----Tullamore Dew they call it,better than MAKERS MARK+just a fraction of the price of GOLD!!!!
  7. Good mornin Mr.LowRider,thank you for your immensely informative posting of co adjustment,now it will be a snap to adjust correctly.On a 2nd note please share with us what brand BOURBON you drink-----I have an inquiring mind!!!!!
  8. Thank you Mr. Antman---I have a small screwdriver,know where the hole is,however I don't know when to stop turning the screw!!!!!!!!!!!! Please advise.
  9. Please explain what eepron is +how to set it up as mentioned byMeinolf.What type hardware do I need? 98EV
  10. fubar guzzi
    fubar guzzi
  11. Hi Andy,I just found your return post so we are even. I am working on a transmission,the weird looking nut at front on the input shaft was the problem.A member from Wildgoose got me through it,all I had to do was drill a hole insert a stick dynamite--------- Thanks for your help anyway
  12. Kick it----
  13. I am totally confused at this point---are we saying replace the entire light (200$),or should we buy a replacement from Guzzi_Tec(80$)? Or should I just make a martini and not care !!!
  14. Mine does the same thing I too will follow advise as given thanks
