Everything posted by PJPR01
My Scura has acquired a cough - post TPS adjustment
PJPR01 replied to PJPR01's topic in Technical Topics
Thanks again G…I’ve got the feeler gauge set at 0.002 and am using that to make sure I’ve got clearance on both sides of the idle screws. Where I’m struggling is getting the bike to idle high enough with both idle screws not touching, linkage disconnected and Air screws backed out 1 full turn and high idle screw just letting the cam set to nudge. The idle is just too low to keep it running under those conditions so, I end up having to find a way around it to get it warmed up enough to check CO trim and when doing the other adjustments, Somewhere in the middle of all of that the bike still coughs. I’m going to try again tonight…turn my head sideways and cough….maybe the bike has a hernia! Ha ha! -
You are 100% correct...the only epiphany I have had so far is that apparently I'm missing something or I have a wandering TPS even after snugged down and triple verified, but I'm patient enough to go thru it again and again until I get it right. I'd like to address the building of a small allen wrench with a 120 degree angle and a gear drive on it so I could just insert it and move a dial back and forth to turn that bloody RHS idle screw...it's a royal PITA to do it in such small increments. I'm also realizing that I would enjoy this a bit more if I had a moto lift, but my garage space is too valuable to put another device in there at the moment between the sports car, 3 motorcycles, 4 bicycles, 2 unicycles and a few other toys! -
Thanks Gstallons…I have your write up as well as a reference! Fully aligned on the 0.157 as the TPS volt reading with the throttle plate fully closed. That’s done now! -
Danke sehr Meinolf and Docc...you are both 100% right (as usual!). The learning continues here in the well illuminated Houston garage! Indeed, late last night I was able to loosen the right hand high idle screw and sure enough that enabled the throttle body to close completely...so when I read the voltmeter again it was then sitting at approx 0.100 less than before when I thought it was fully closed. Reset everything to 0.157mv, snapped it a few times, came back to 0.157 and at WOT was registering 4.78...so that's a good sign! I proceeded a few more steps, got it started again (it did sound smoother) but it struggles to idle without some inputs. After getting it to stabilize and warm up I checked again the CO Trim, sitting at +20, so that seems fine (maybe I should try +26), air bleed screws are 1 full turn out, high idle screw is just "nudging" the cam, and both LH and RH idle screws are not touching (0.02 feeler guage slips in just fine). Will get at it again this afternoon at a break. So much fun!! -
80CX: Got it now, I fully understand what you're referencing now. Ok, no issues on this side, it's got about 1/2 inch of thread going into the black threaded cup...all good there! I figured it was just as easy to spin the rod off, even took advantage to put a little white grease into the threaded plastic cup to make it a bit easier to turn. Luckily I know this whole cough is related to the TPS setting, since the bike was running great after I had done all of the other work a few months ago and had never had a cough since I bought the bike back in 2016, I just had the need to tinker with this last piece to see how it was done as the manual TPS adjustment is so different and somewhat archaic compared to my two other CARC bikes where we can reset it via Guzzidiag. Good learnings all the way around playing with this and I feel good about putting a new TPS sensor on as it certainly looks like an original one there now, plus I was able to clean out all of the crud that gets into that TPS housing reservoir. Hopefully I'll have good news to report shortly this week once I get the adjustment done and time for a ride sometime during the week. Thanks all...much appreciated! -
Ok...I'm intrigued enough to head back out to the garage again to take a blow torch, I mean screwdriver to the high idle screw tonight and then re-connect the Casper harness and see if the 0.157 has changed once the screw is backed out enough...will pay attention again to the right hand idle screw. The good news is I've become quite adept at contorting myself sideways to get that little allen wrench into the RHS idle screw...nothing is impossible now. I can even slip a 0.02 feeler gauge in there to make sure it's truly not touching. If this solves it...let me know where to send a bottle of your choice of fine liquor! -
Ok, I'll take another crack at the upward facing high idle screw...hopefully it budges w/o breaking anything and that solves it...it is the 1 step I haven't done. 80CX100: Many thanks for the comments as well. My CO is set at +10, it was at +10 before as well, I took it to zero in one of the iterations here and it ran much worse, so I put it back to +10 via Guzzidiag. I suppose I could experiment and put it +20...easy enough to try! My air screws were 1 turn out before, and again now also 1 turn out. I tried it 2 times rotated out on both, but 1 turn seemed better at this point. I've had a bit of a revelation writing this...I did watch my Carbtune with both airscrews completely removed (you can hear a lot of hissing, but it's interesting to see....my RHS was sucking a bit more until I balanced later on with the linkage connector/white plastic square, so that maybe then the high idle screw is the culprit. Vacuum ports are both connected via hoses, not plugged, so all good there as I had the tank off a few months ago to replace the intake rubbers, clean throttle bodies, do the valve adjustment and ensure the airbox/new filter and all hoses were good and properly connected and snugged up. Even took the time to sand and paint my battery tray...not that anyone sees it but me! I'm not sure I understand what is meant by throttle linkage being indexed? Can you elaborate a bit? The throttle releases nice and smoothly, no catches at all. Nothing physically changed from before, but I can see that I don't have it screwed in all the way into the right hand plastic piece as the balance with the Carbtune doesn't require it to be now so I have a few threads now visible vs. the locking nut on the RHS. Witness paint - there's plenty of that on here from the prior owner...I'm going to have to scrape it off and apply fresh stuff! -
Thanks for the almost immediate reply Docc, I had that thread printed out next to me and followed it step by step several times now. However, I couldn't see anyway to adjust the high idle screw, so I didn't adjust it at all, I tested it with a screwdriver gently, but didn't seem to even budge, and I didn't want to force it. Maybe that's part of what's missing, I'm just reluctant to break something here as that leads me down a path of having to source more parts. With regards to the TPS, snapped or held snug manually, it still reads 0.157mv at full closure and after tightening the screws, it's dead nuts on, so the old and new TPS are not walking anywhere! They're on a tight leash! Can you confirm if your high idle screw does turn easily or is it quite stiff? Thank you!! P.D. I'm still scratching my head as to how the old TPS set at 0.350 could allow the bike to run absolutely smoothly however...I mean, that's seriously out of spec... -
A project years in the making...finally tackled it...but not happy with results. Having finally decided to tackle the TPS setting, despite having no issues, I figured it was time to do the 1 thing I have never done on the Tune up list, after having done absolutely everything else on the list with meticulous attention. I connected the new Casper cable (so that's how it works...aha!), connected the voltmeter, disconnected throttle linkage and see the TPS is registering 0.350mv...well, that's supposed to be .157...hhm, I wonder why the bike runs well despite that, I ponder. Thinking, well surely it will run even better when I set it properly! Premature delusions of grandeur dancing in my head! Ok, remove the old TPS, look inside, pretty oxidized with some crud, so I clean it out thoroughly, re- connect the TPS, back out the idle screws on both sides so they are not touching the cams, snap the RH throttle several times until it's well and truly seated and get it set on the nose at 0.157mv, and snugged in tight. All good, put it at full throttle still disconnected from the linkage, and it reads 4.70...sounds like I'm in the right range. Ok, mission accomplished on the TPS. Connect it all back up again, remove and clean air screws, blow some throttle body cleaner into the TB's, then set the air screws 1 full turn out each, reconnect linkage, get idle screws touching, bike idling like crap, and tons of flat spots and coughing. Put a fresh set of plugs in just for fun also. Cranked it up, idling low, and start adjusting as per the write up here. Played with it a few more times, getting it nicely balanced with the Carbtune, idling beautifully, air screws 1 full rotation turned out, and I still have a flat spot/cough at low rpm's (1.5K to 3k RPMs') that was NEVER there before. Disconnected everything again, and go thru each step methodically, recheck TPS with linkage and idle screws backed out, and still seeing 0.157 closed and 4.70 at WOT, hook it all up again, but no change in behavior. I'm thinking do I have something clogging up fuel lines or something so I take it for a short ride, but not at all happy with the flat spot/cough. So...decided to buy a new TPS as recommended by Docc...came in a few days, installed it today, and noticeably smoother and I can see it moving in increments of 0.01 easily as I gently tap...so here we go again, set to .157mv and full closure with linkage and idle screws backed out...and 4.70 at WOT. Figure it will run better, and it does...but bugger all, it still has a cough. How is it possible that I could have had NO flat spot or cough ever in the prior years of running, with a TPS obviously set at the wrong point, and now with every thing exactly on spec (or obviously I'm overlooking something), I have it idling perfectly, Carbtuned and balanced to perfection at idle and 3K rpm's and I still have a flat spot/cough. I even went around and snugged up all the new rubber intake boots 3 clamps each side, snugged up exhaust headers (no movement), connector pipes (2 each side). It runs beautifully on the highway, but now, every time I come to a stop I know it's going to stumble when I take off again...until I get above 3 k RPM's again. I know it's not relays, since I had no issues before, no exhaust leaks, fresh rubber, valves set, fresh plugs...WTF? and just for fun I went and put a fresh full tank of new gas in it...no change. Back to the drawing board here...surely I'm missing a step somewhere...
A nice day of riding both the V11 and the 2V Norge...perfect weather to ride, nice and cool. Nice to be able to toggle between the bikes...each a great riding experience.
A 2V Sport or Norge is a fine stable mate for a V11…along with a Griso! They are all different enough to provide a unique riding experience! Get them!! I love the trio combo…but ultimately I think it depends more on if you are planning short to medium rides vs…long ones, based on ergonomics.
Always on the calendar for me...see you there again this year Leroy! 630 miles door to door...maybe I should do it on the Scura this year...but the Norge is so much easier for carrying camping gear and the long distances.
I don’t recall seeing this item for sale last year when we visited the distillery picking up several bottles of heart warming liquid!! That will have to be corrected with a return visit!
The World's Quickest Cars
PJPR01 replied to Joe's topic in Special place for banter and conversation
Just thinking how fun it is to ride 100 mph on a bike, and then imagine how fast 200 mph feels on a Moto GP bike and then another 100 mph on top of that - that's truly insane - must be a hell of an adrenaline rush! The Bugatti is just an amazing piece of art...couldn't agree more! I wonder what the highest mileage Bugatti in the world has...probably not more than a few thousand miles I should imagine...it's difficult to add the miles when you're just doing Sunday drives around Monaco or Dubai! -
I have found using a speed bleeder on my Norge works wonders...much easier to use, it's like having a 3rd hand when bleeding. Keep filling the reservoir, pump gently a few times, watch the fluid/bubbles move thru until all the bubbles are gone, and you're done!
Tire pressures? Cold tires due to temps dropping?
Now this is too funny! Absolutely mimics some of my recent activities! I have now added not only US Ebay, but also Canada Ebay to my recent list of providers (for the Griso I might add, but anyway). Both MG and Harpers have been great to work with...sometimes there are lags in getting items shipped due to worldwide supply chain issues, but they eventually show up. I was pleasantly surprised however the other day to get a couple of items within a day or two of having placed the order... Stein-Dinse has the most amazing shipping speed of any vendor, honestly they must have their own planes with door to door delivery service...it's that fast!
Plus one here...excellent news.
Motorcycle Grand Tour of Texas - 2022 edition - Repository -
PJPR01 replied to p6x's topic in Meetings, Clubs & Events
Hello @p6x…still out there! All Ok? Today I completed the required 25 stops to earn the patch for the 2022 tour! It’s been spectacular riding weather these last two weeks so I was able to get a little time off work and knock off many stops! I had previously covered Navasota (with you as well), Texas Sidecar in Donie (I missed getting Lone Star rider at that event!!), Camp Hearne, Lufkin, Terrell, Paris (3 stops), Gladewater (3 stops) and in the last 2 weekends covered Cuero, Buda (Creedmor), stop for BBQ in Lockhart with Galveston Dave, Burnet, Llano, San Saba, Brady, Mason, (Luckenbach…unofficial stop!), Center point, Bandera, Alamo BMW San Antonio, Johnson City, Texas City, Bolivar and Red Roof! What a fun tour!! Will see if I can get Beaumont next weekend! I'm not sure I'll have the time before mid November to make it down to South Padre or the valley, would like to try to get 30 stops, no way this year to get the full 50 however.- 111 replies
- 5
- motorcycle grand tour of texas
- 2022
(and 3 more)
Tagged with:
hi Paul...I'll take it! What other goodies have you got for the Griso...I have to get the mudder installed next weekend! Thanks again! Paul
Or keep in the tent at night when camping if you don’t want to find a nearby tree!! 😀😀
Was that because he pronounced it Puh Kahn instead of Pee Can? 😀😀 Some people mix a little pecan with mesquite…also quite tasty. BBQ is so particular…have to agree on leaving the sauce off or just using a tiny bit for a dip or two. Proper brisket, bark done right is an all day job…I appreciate the time people spend cooking it, it’s much easier just to eat it! There was no BBQ at our Texas Guzzi rally this past weekend, but we had good pasta and meat sauce! Headed to Black’s BBQ in Lockhart Texas next weekend to bag another 10 stops on the Tour of Texas…two years ago we had 10 Guzzi riders show up in Lockhart on a whim just for the BBQ!
