bbolesaz
    15
Everything posted by bbolesaz
  1. They are selling a bunch of V85TT's. But it's up against the BMW R1250GS. So, I bet the "new" engine/bike is a VxxTT with a liter or plus engine.
  2. Biggest effect? Canceled my moto trip to Spain last year, and my trip to the Himalaya's this summer is hanging by a thread. Lucky that I'm a engineer by profession and have been able to work from home no problem. Personally, I'm very strict on public interactions and so far, so good. Wife is eligible and scheduled for vaccine at the end of the month. I'll have to wait a bit.
  3. Press fit?
  4. Looks like part #29 is splined and the splines have been ground off. The photo, looks like spline remains above the blue arrow closest to the gear.
  5. (Can't find eating popcorn icon) My Scura needs all the same. Love to follow along.
  6. Mike, lemme know if you want to shake that LM down some. The Scura needs a ride.
  7. BTW, I would use Time-Serts over HeliCoils. https://www.timesert.com/
  8. If you are helicoil-ing a block, you need a bottoming tap, not a tapered tap. The tapering tap can be helpful to cleanly cut the 1st couple of threads at the top of the hole, then finish in with the bottoming tap.
  9. Sparklehorse does the greatest version of Pink Floyd's "Wish You Were Here".
  10. This is a helpful resource for finding ethanol free gas. Unfortunately, at least in Arizona, most of the ethanol free is not available at pumps, but rather in 5 gallon cans. http://www.pure-gas.org
  11. To answer the original question, no a resistor would not work. The voltage drop across a resistor is the resistance * current. The current will be strong on a weak battery and low on a strong battery so the voltage will vary.
  12. I'm looking for an editable source file. The spine drawings from 1999 and 2004 don't exactly match my 2002. I've asked Carl if he has source.
  13. Do source files for the wiring diagrams on thisoldtractor exist anywhere ?
  14. We got Matt in NM and Tom in AZ.
  15. None of the in tank electronics "spark". If they do, that's badness. And yes, the pump motor is brushless. Edit - I don't think the pump is brushless in early 2000's. The brushless motors are becoming more common. I know this because my company build the controller chips used for these motors. (A good business for us!). It's the concentration of the fuel vapor that prevents explosions. From Google - "The reason electric, tank- mounted fuel pumps do not cause explosions is that the concentration of fuel vapors is too high to allow an explosive mixture. The volatile (which in this context refers to a tendency to evaporate) nature of gasoline causes fuel vapors to take up any empty space as the fuel tank is emptied. Even if you completely empty a tank, open its access ports, and allow it to sit open, the concentration of vapors INSIDE the tank will still be too high to explode. Now, OUTSIDE the tank is a different story, and for this reason, one must use caution when performing any sort of repair or maintenance to a fuel tank, regardless of the type of pump used on the vehicle."
  16. I like the NEP throttle lock. Info here -
  17. Thanks @Tinus89 those pix are very helpful.
  18. bbolesaz
    Tekno Bags
    Anyone tried to dye the Tekno bags "back to black" ?
  19. I ordered the #"175" tank ring. Still not sure if chinpad and no chinpad caps have the same bolt pattern. I'll report findings when my part gets here.
  20. Also, @KINDOY2, does the gas cap open all of the way or does it interfere with the inside of the ring? Will a %$#% California emissions gas hose fit in the gas cap opening with the ring on?
  21. Is the hole pattern for the tank ring the same between later, non-chin pad tanks and earlier chin pad versions ? There's 2 different part numbers for the caps, both US versions. Earlier - GU 0110 3920 Chin Pad Later - GU 0110 3990 No Chin Pad Asking for a 2002 Scura with CF Chin Pad
  22. The Beemerboneyard ones are metal replacements for the shitty plastic ones used on BMW bikes. The plastic ones have a nasty habit of cracking and spewing high pressure fuel all over the engine. Very common BMW problem. Had to do a rather long ride home one time hoping no one threw a cigarette butt at me.
  23. Took the Scura out for a ride around what Zonies call the Salt River Canyon (SRC) Loop. Ultimate social distancing. Just over 300 miles worth. From my home in Mesa, AZ to Globe, across the Salt River Canyon, Show Low, along the rim to Payson and back down into the desert and home. Lots of traffic in the Payson area. In these days of C19, lots of folks going camping for weekend fun. Caught a few monsoon sprinkles along the rim. I would say that the Guzzi purred like a kitten, but that big twin sound is much more like a flatulent Italian grandpa who ate too much spicy Italian sausage.
  24. An example -
