swooshdave
    65
  1. Dave was out here in Oregon for a bit a year or two ago, I guess it sounds like he's back in Ohio? I literally didn't make one Guzzi event last year. How sad is that?
  2. It's a shame all the Moto International original owners and staff have retired, and MI itself then shuttered after the new owners didn't maintain the same customer service and passion. Or they actually looked at the books and decided they couldn’t make it work.
  3. I would not use actual weatherpack connectors. They are way too bulky. http://www.cycleterminal.com/amphenol-at-dt-connectors.html
  4. What type of plier / tool is used to crimp these terminals ? https://www.amazon.com/IWISS-Weather-Pack-Terminal-Crimping/dp/B0732W6HQR/ref=sr_1_57?ie=UTF8&qid=1546212291&sr=8-57&keywords=crimper+terminal https://www.amazon.com/dp/B07476C1LD/ref=psdc_553392_t1_B0732W6HQR
  5. It’s not in the workshop manual?
  6. You are definitely in the wrong place as encouraging collection expansion is a competitive sport here.
  7. NADA is particularly horrible about pricing. I’d insist on comp values and an appraisal and not go off a book. And insist on an estimate. Remember Progressive isn’t there to help you. More importantly how are you? Sent from my iPad using Tapatalk
  8. I can't. Won't clear the fairing. https://www.amazon.com/Oumurs-Motorcycle-Cylinder-Reservoir-Universal/dp/B0799JT9D5/ref=pd_sbs_263_7?_encoding=UTF8&pd_rd_i=B0799JT9D5&pd_rd_r=12d3b707-066c-11e9-a7c6-2fa816d9f586&pd_rd_w=WvrAQ&pd_rd_wg=JvKkU&pf_rd_p=7d5d9c3c-5e01-44ac-97fd-261afd40b865&pf_rd_r=5NC91F6BX5K7WY9P2RZ7&psc=1&refRID=5NC91F6BX5K7WY9P2RZ7
  9. Not possible to have it too clean. But one particle in the wrong place can be deadly. I'd take off the oil cooler and clean the crap out of it. Anywhere that oil has been should be suspect.
  10. The only reason to use carbs on a bike build is for the retro look.
  11. It depends on if you think the added complexity is worth the benefits. I think using a MOSFET regulator makes sense, clear benefits for the same price as a the SCR ones.
  12. Uh, have you ever tried to tune Dellortos?
  13. I know where I'm sending my cans to...
  14. http://www.vintageconnections.com/Products/Detail/151?fbclid=IwAR14g6bIYTXMPj2ZtP4rxBwrKcYqPBIRg8_WoVFkWkr_7oLlRCH-86Zw_xc This guy I know now has the plugs available for the Shindengen type regulators.
  15. Regulators, due to the fact that they work by generating heat are going to fail at some point. So you either treat them as a wear item and replace them with a plug and play option or you replace it with a MOSFET which should last longer, although you may have wiring and mounting issues. Just a case of calculating out the cost/effort/miles ratio for yourself.
  16. You may have much better luck on Wild Goose.
  17. Look very carefully at the pictures. I swear it seems smashed. There are certainly some dents.
  18. I had an experience last month on the interstate that has me agreeing. Heavy traffic, changing lanes to pass at 80 mph, car came into my lane and hit the brakes. A too quick grab of the brake locked up the front tire long enough for a loud screech. Scary but reassuring. how's the foot Dave? Here is the thing, better brakes aren't just about more power. Better brakes can give you more control as well. A stiffer, firmer brake lever that gives you better control of how much brake you apply as well as offering more braking power can be a good thing. On a side note, do you brake with one, two, three, or four, fingers? Four. I find l have less control with two. Sent from my iPhone using Tapatalk
  19. Purely wishful thinking. Too much work to make it happen. Sent from my iPhone using Tapatalk
  20. That's why I have an LED bulb in my 850T, the poor alternator barely puts out enough to keep the bike running with the light off!
  21. I had an experience last month on the interstate that has me agreeing. Heavy traffic, changing lanes to pass at 80 mph, car came into my lane and hit the brakes. A too quick grab of the brake locked up the front tire long enough for a loud screech. Scary but reassuring. how's the foot Dave? If anything I’d prefer ABS on the front. Toe is much better. Nail is growing rapidly. The weather has deteriorated enough that it’s not the toe or regulator that’s preventing the riding. Sent from my iPhone using Tapatalk
  22. I can’t imagine needing more front brake than what the Brembos provide.
  23. https://www.amazon.com/gp/product/B07JM421VC/ These apparently mimic a standard bulb very well. Seems the trick is to be able to rotate the LED bulb to the correct angle.
  24. Now this thing... hides the ugly under some really expensive carbon fiber!
