Tomchri
    36
Everything posted by Tomchri
  1. Tomchri
    Map Day
    Correct distance, and easyly made in an afternoon in my friends shed, and a couple of useful tools for the Øhlins. Did the measure tonight and ended up with 0.85mm clearence and good spark again. Have to go riding with a friend tomorrow, meaning that will be nice, but can't wait to see how she behave now. I am listening to the SB mech from down under to, so when I get her straight, curious as usual, I will reduce my valve clearenses a few times, CURIOUS, and my own experiences. ( like the Carb tune) Cheers Tom Sent fra min SM-A505FN via Tapatalk
  2. Tomchri
    Map Day
    Few miles test ride today, No, about same behavior, so inn with the other Meinolf mapped ECU. Another full tuning, and then no firing at all, 1bang from right muffler. No spark,, I did ohm the almost new sensor from TLM 0.0, shit. The old one shoved 644. Next goal, correct distanse, was it more preferable at the upper end, 0.8 - 0.9mm ? Sensor lenght was 29.95mm, all I have in shims is 0.7 and 0.9mm. More spear parts. Cheers Tom Sent fra min SM-A505FN via Tapatalk
  3. Tomchri
    Map Day
    Quick reply, between the shovers, still struggling with the Ti ECU. Just tried with a new TPS, battery needed some juice, wouldn't even fire. I need to go for a little ride, to cool down. Later. Cheers tom
  4. Tomchri
    Map Day
    I have 0.25mm on both valves. How the H can she run that good after 3000, and so rubbish between 1500 to 3000. Oh well,, another IPA,, might be some weather tomorrow. Cheers tom
  5. Tomchri
    Map Day
    Twin Max electronic device for balancing,,, Carb tune is with manual tubes and restrictors, I like it. Cheers tom
  6. Tomchri
    Map Day
    Why my question ? Had my 2 ECU's loaded with Meinolf's latest mapping, by him. Did a few rounds with tuning on my Rosso Corsa, and she is running Very good. Did the same tuning on my Greenie ( quite a few times ), idling perfect and Very strong after 3000. Did buy a new Carb tune,, much better than my Twin Max. BUT from idling up to 3000, she is not happy with the right cyl. So what you are experiencing, had me wondering,, ( again ). I'm quite sure my tuning is on course,, so coud it be the mapping ? I have a brand new TI ECU, so will try that one, when the weather permits. Will report back after the test Cheers tom.
  7. Tomchri
    Map Day
    Sorry no answers just another question, did you confirm the misfiring was on 1cyl or bouth ? Cheers tom.
  8. Have you checked the charging ? Cheers tom
  9. Yes, that would be a safe bet with the golf ball there. Just another old habbit of mine, wondering or checking ,, what does it look like inside And, it will be nice to see it on the bike, hear it to. Cheers tom.
  10. Sorry, still curious ,bad innlish, meant looking inside with some fancy equipment, or feeling with a steel wire or something for the opening's in the crossover- xover ? Cheers tom.
  11. Pressure thing,, just rememberd, before any electronic world, putting a new dual exhaust on the 440, and put a stripe of white paint on the fresh pipes after the Hooker headers,, go for a sporty trip,, most burnt spot got a crossover. I'm sure it was fun Cheers tom.
  12. Curoius,, has it been an inspection inside the crossover - xover ,, whats happening there Cheers tom.
  13. No sir, hopefully next week . Cheers tom.
  14. Just ride faster, if anybody around ,,, they WILL see your brake light when you need to use it Cheers tom.
  15. I put about 6000m on the Øhlins, so it was D time for service. And in all the bikes Kodak Gold,, might be lucky. And yes another IPA. Cheers Tom Sent fra min SM-A505FN via Tapatalk
  16. Oh well, been waiting for the leak, those low friction Øhlins seals didn't like my last trip in the mountains. So trying these Swiss made seals. Cheers Tom. Sent fra min SM-A505FN via Tapatalk
  17. Hi 01 Balancing only, right? Take the B rod of, adjust throttle screws so they just touch the stopper,, I use a 0.05mm blade, or a piece of paper, then I turn them both in about 1sixth of a turn. My Greenie starts fine without the balance rod connected. Easier to set the idle with the left stop screw,, just do the same adjustment to the right side. Adjust the balance rod with the white nob so it slips on without moving anything. Then use your balancing instrument and the white nob for final tuning. Seems to me they all have different souls and behaviors . Cheers tom.
  18. The Stucchi has the suport,, if you find 2 let me know . Might be ilegal to copy one ? Just put the Mistral on my Greenie, which is solid and well made,, but the Stucchi has proven it's # on the bench. I'm reading more tuning between the lines, I think we all like to hear about tuning. Cheers tom.
  19. Will see how long I be happy with the sharp angle, I do like the stock angle,, it flows correct with the rear section of the bike. MORE TUNING. Cheers Tom Sent fra min SM-A505FN via Tapatalk
  20. Might as well ad fuel tank going back with the same force Had a not planned stop, in a lousy place of course after fitting new boots. The one that came of,, was easy to fit back,, ehh warm enough. Retighten was the point. Cheers tom.
  21. I leave the boots in real hot water for a bit,, and use a dishwashing liquid called Zalo over here,, some green stuff from the misses dep. Cheers tom.
  22. Right side connector,,, I'm quite sure is the sensor in the air box, I will double check tomorrow. I like it CLEAN to, nice. Cheers tom.
  23. Sorry to hear that Jan, my condolences. Cheers tom.
  24. Wasn't sure about posting another picture of my Corsa,, ( nick name ) But They All Do look pretty, right Wish I coud take pictures. And different backgrounds from all over. 360km ride, exelent seat and suspension, she can take it, we are not short of curbs up here. Cheers tom.
  25. It was 23c down in the valley, 10c up in the hills,, Just don't eat the yellow snow Cheers tom.
