Tomchri
    33
Everything posted by Tomchri
  1. The Sport still has the Duc regulator, so that was actually in the brain thing, figuring out why. Have an extra 847, winther soon. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  2. Omron with a problem again,, oh well. Lost rev counter, instrument lights and probably head light, didn't see that first time. Problem comes and goes. Ok, had a big print made of Luigi electrical for the Sport. Problem solved, headlight relay. Had a 4 hour ride today to a Guzzi meeting in very nice riding weather, bit chilly in the morning 9c, but later 20c. NO RAIN. She love the curbs, hate traffic. Can't blaim her. Was it 67 Guzzi's up there, sorry no V11. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  3. . Cheers Tom.
  4. Isn't it 8mm bolts, so 8-12nm will not do it. Cheers Tom.
  5. 2003 Le Mans on kleinanziegen with 2800km, 19900Euro. Coppa Italia with 6700km was advertised here 185000kr. My Coppa Italia with 10000km ( 1 scratch pork chop) otherwise perfect) 150000kr, but with parts worth easyly 50000kr Cheers Tom.
  6. I woud take a piece of wire from + on the starter to the solenoid, starter and battery test. Cheers Tom.
  7. Great chassis balance for a street car. Enjoyed 90km with a good buddys Aston. Ok 1 thing, opening the hood, try finding the lever well hidden on the passenger side? Cheers Tom. Sent fra min SM-S906B via Tapatalk
  8. Rosso C and Nero Corsa has both Bitubo. Coppa Italia with Øhlins. Cleaned both Bitubo's, filled with ATF, works fine. Cheers Tom.
  9. Handlebars looks comfy, Something with a Greenie, spesially with a V clean one . Cheers Tom.
  10. My head starts to hurt reading all this, nææh have a beer. Who the H is Tom Cruuus. Cheers Tom.
  11. Cheers Tom.
  12. BIG JOKE, sold a few 19.99. Cheers Tom.
  13. Easily made in an afternoon with a lathe, as it said back in the days on Hooker headers. I did find it much easyer than with the caliper. Cheers Tom.
  14. If your keeping the bike, very happy with # 2. Have installed 4 from Roadstercycle, perfect charging. Cheers Tom.
  15. Tomchri
    Hint
    Slave cyl. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  16. Tomchri
    Hint
    Wondering, anybody had a problem with the clutch cylinder? Was a guy up here with a clutch problem, woudn't release promptly. Wear on the piston, see picture. Getting a new one, hmm. Searching ALL OVER, nothing. Finally a shop in Denmark called V2 parts who had 3 in stock. I bought 2. The name before was Guzzi parts, we know the reason for changing the name. Just a hint. Cheers Tom. ( can't post picture today on Tapatalk, interweb ×#€%=^> Sent fra min SM-S906B via Tapatalk
  17. YES
  18. Look at my post may 29 2021, how easy the distance can be measured. Me and interweb. Cheers Tom.
  19. I made a tool to get the clearance correct , easyly made in an afternoon. I didn't want to put anything inside the engine. Picture here somewhere, may be june 21. Cheers Tom.
  20. Shindengen from Roadstercycle. Cheers Tom.
  21. Timing - TPS issues. Can't remember, did you change the mapping ? Seems you are capable of handling COMPUTERS, I'm not. A good friend and some toying with the ECU. AMAZING what can be done. Good luck with getting rid of that kangaroo ride. Cheers Tom.
  22. Or a 27mm nut welded to a bolt. Good grip and close to the pan. Cheers Tom. Sent fra min SM-S906B via Tapatalk
  23. Bearings size 20x47x14. Cheers Tom.
  24. I woud check the cables in the ign lock, and at the same time make a little loop with the wiring and strap it easily on the lock. Every time you turn the handlebars it will strain yor cables. Bearings shoud be easy obtainable, will go looking if nesecearly. Same time again check the lenght of the spacer between bearings. If 12cm ad a 1mm shims. Cheers Tom.
  25. Because thet can . Cheers Tom.
