Everything posted by Tomchri
Cheers Tom.
BIG JOKE, sold a few 19.99. Cheers Tom.
Easily made in an afternoon with a lathe, as it said back in the days on Hooker headers. I did find it much easyer than with the caliper. Cheers Tom.
If your keeping the bike, very happy with # 2. Have installed 4 from Roadstercycle, perfect charging. Cheers Tom.
Wondering, anybody had a problem with the clutch cylinder? Was a guy up here with a clutch problem, woudn't release promptly. Wear on the piston, see picture. Getting a new one, hmm. Searching ALL OVER, nothing. Finally a shop in Denmark called V2 parts who had 3 in stock. I bought 2. The name before was Guzzi parts, we know the reason for changing the name. Just a hint. Cheers Tom. ( can't post picture today on Tapatalk, interweb ×#€%=^> Sent fra min SM-S906B via Tapatalk
Look at my post may 29 2021, how easy the distance can be measured. Me and interweb. Cheers Tom.
I made a tool to get the clearance correct , easyly made in an afternoon. I didn't want to put anything inside the engine. Picture here somewhere, may be june 21. Cheers Tom.
Shindengen from Roadstercycle. Cheers Tom.
Timing - TPS issues. Can't remember, did you change the mapping ? Seems you are capable of handling COMPUTERS, I'm not. A good friend and some toying with the ECU. AMAZING what can be done. Good luck with getting rid of that kangaroo ride. Cheers Tom.
Or a 27mm nut welded to a bolt. Good grip and close to the pan. Cheers Tom. Sent fra min SM-S906B via Tapatalk
Bearings size 20x47x14. Cheers Tom.
I woud check the cables in the ign lock, and at the same time make a little loop with the wiring and strap it easily on the lock. Every time you turn the handlebars it will strain yor cables. Bearings shoud be easy obtainable, will go looking if nesecearly. Same time again check the lenght of the spacer between bearings. If 12cm ad a 1mm shims. Cheers Tom.
Because thet can . Cheers Tom.
Roadstercycle.com Shindengen SH847. Works wonder for your electricial system. Cheers Tom.
330km now, have a good feeling about clearances and everything. Winther project with a clean bill of health. Must admit she has an easier willingnes to curbs than myV11. I actually have a feeling for my keepers, yes IPA TIME. Cheers Tom. Sent fra min SM-S906B via Tapatalk
Why don't you look at posts july 22. I prefer less wiring if possible. Cheers Tom.
- 57 replies
- 1
Like Chuck said. Looking at your plugs, mileage, some quide wear for sure. I was lucky, bent valve outside the garage idling. Machinist told me when milling out the quide on my right head, the quide just dropped out after minimum milling. Not trying to scare, just a wear thing. 215600km not bad at all. Don't think the unsceduled pit stop had anything to do with wear. Just some thoughts docc. Cheers Tom.
MP3 grease from BMW is white. Staburags from Kluber is a v good grease for the splines. Clean EVERYTHING, and light coating. Cheers Tom.
YES. Cheers Tom.
Having a few bikes it's actually very recomended for a pensioner's health, shoud have been on blue subscription. Winther project started july last year, why not this year to with riding weather like this, -3 not far away. Gives me something meaningful to do since bikes always was a BIG part of life. Bit wet and on the chilly side here, but no thank you to 100+ in Houston. Remember well 43c in Barcelona with up north riding gear, TERRIBLE. Cheers Tom.
And ready for more km [emoji16]. Cheers Tom. Sent fra min SM-S906B via Tapatalk
MM had a nasty HS today, broke a chicken bone in the hand, and a ribfracture But seeing him getting the bike back up on two wheels using his arm and feet, amasing at least to me. To bad he was hold up today, not intensional tho, RACING Will see. Cheers Tom.
Heads back today. Another quide VERY loose. Oversize quides from Guzzi not big enough, so they made 4 new ones. Expensive but superb. Happy friday here. Cheers Tom. Sent fra min SM-S906B via Tapatalk
