Everything posted by Tomchri
Share your lithium battery experience; cold environment, durability, else?
Tomchri replied to p6x's topic in Technical Topics
Not much experience with Li-Ion batterys, but there was an EXIDE ELTX14H 48wh 240A installed in my 1100 Sport ( yellow). She was parked sep 7, chlutch gone. When parked it had 13.52V. Had the battery in now to check everything is working, no smoke. Not a lot of use, but holds 13.50V now = 7months . AMAZING i think. Cheers Tom. -
Cheaper, check connections from alternator. Bulletconnectors and all kind of horrible connections. Mine started to flip the tach, then misfiring and dead. Melted connectors. Cheers Tom.
Yes, what a race. MM had brake problems, according to the news. Cheers Tom.
Few hours ago on Finn.no, a Coppa with 6732km. 200000kr . Cheers Tom.
Yes it took awhile before lesson learned about the octane hunt. Back in the days it was possible to get 110 octane from a buddy working offshore. Cheers Tom.
Since s arm is of, you are talking about front part of shaft connected to the tranny ? Can you move,slide the shaft a bit on the splines, if, tighten the bolts. Shoud be NO play in the ujoint. Cheers Tom.
Get your checkbooks ready...
Tomchri replied to activpop's topic in Special place for banter and conversation
820cc Denco modified to 120hk. Bought a new 72 H2, painted it maron, WHAT. Did around 28000km with those 2. The H1, nææh. Cheers Tom. Sent fra min SM-S906B via Tapatalk -
Finished, now weather and tuning. ECU been a trip to C Jefferies. We like clean ladies. Cheers Tom. Sent fra min SM-S906B via Tapatalk
Have those bulbs in my 03, 04, V11 and patterns is like a regular H4 halogen, only brighter. 1100 Sport needed some grinding on the bulb to get the lock working. Don’t fit in my 01 Greenie steel housing. My 99 has an aftermarket smaller housing with enough length to fit. Don’t ride a lot after dark no more, but no dought, BETTER. Cheers Tom.
Recomended by the doc. I have 4 going, BEST sofar. Cheers Tom.
Can't help myself, do I spot something what we call an electro thief ? Don't like greeniesh copper wires Cheers Tom.
Zero failures. IPA time here. Cheers Tom.
No, but fairly simple to do. I put it under the battery tray, check clearance. Idling 14.73 on my greenie, and not even a red one. . I did install extra terminals + and - , only 1 cable on the battery. Some pictures on the forum somewhere. Others here have installed it to, all seems happy. Cheers Tom.
Seems you enjoy mileage, so just install a good regulator that connects direct to the battery. Your electric system on your bike will thank you. I have installed 4 Shindengen 847 from Roadstercycle, GLAD I did. Cheers Tom.
And mine showed up yesterday, 18days. Liked the 12$ value . Cheers Tom.
And help the soldering points in the switch by making a little loop on the cable and secure it to the switch, easy strap or tape. Every time you turn the handle bars is stress on the wires/ soldering. Cheers Tom.
Like you said, ride it more. I thought about it on my 1000S, but l liked the way she was settling her rear. Cheers Tom
Bass ale down south Devon on the little rock in the sea, hmmm Good. Cheers Tom.
