He's 10-12 months out so not taking any work. Says OEM parts are getting hard to come by, like lifters but everything for the heads is available aftermarket. I have some very competent cylinder head machinists locally, and with stock cam/valve sizes 80% of the power increase of porting is probably in the valve head and valve seat anyway, so with Mike's input (hopefully) I'll do it myself and locally.
Well, just confirmed I won't be getting Mike Rich cylinder heads. Drat. <increases motivation>
Everyone in the US acknowledges that the State tests have little to do with competence and more to do with revenue. I had a minibike, then a Sprint 350 in the trails (lol) then went flat track racing on a Yamaha MX360. The learning curve was steep... Kaw KZ400, then 500 triple, then Suzuki GS1100E. The learning curve was steep.
Pete Roper V11 slosh trays now available!
Pressureangle replied to Pressureangle's topic in 24/7 V11
Ok, verified the plates against new gaskets- everything appears in order and it's from the same file as last time, I'll say they're available again and at the same price, and I can order singles as necessary. Lead time is about a week for me to mail out. -
Yes, the original transmission is still where it was, and waiting. The title is clear, it's a one-owner bike before me.
So, Traxxion/Ohlins with Dunlop DOT race tires, and don't bother with the paint?
What am I not? Bought locally for a steal, been sitting 6-8-10 years with the transmission out, depending on who's right. At least reassembling and verifying everything. At most, budget off... anything can happen
FWIW the first picture is how it rolled off the trailer. I hadn't touched anything yet.
I had the same problem, plugged drains and water getting into the tank. The tube that the drains go through are not straight either, and I wasn't able to get any sort of wire through them. The short of the long story is I gave the holes an acid bath with Ospho (phosphoric acid, don't know what equivalent you may have) poked with wire to the extent I could, and blew with compressed air to get the acid down as far as possible. After a dozen bath/blow/wait etc. I started to get some liquid out the bottom, and all the rust that had clogged the tube internally. I stuffed up the bottom with a bit of wood and let the tube soak a couple times for 5-10 minutes and eventually it came free and clear again. The Ospho dries and leaves any residual rust converted to iron phospate, so after drying with air and leaving overnight I sent some aerosol Cosmoline down the holes to be sure they couldn't rust again. I replaced my leaky cap and gasket with a nice aftermarket unit designated for Aprilia- dang if I can find the source at the moment. You'll also want to remove and inspect or replace the fuel lines to the injectors, and clean the inside of the little aluminum cups as they get the fluffy whites from ethanol and water. The end of the story is that I also sent my injectors to be cleaned and discovered that they were something like -3% and -10% from clean and it had never run as well after this cleanup. Aprilia cap Ah, here it is- https://www.oberon-performance.co.uk/fuel-cap-kits
Resort Tax, pax ???
Pressureangle replied to 68C's topic in Special place for banter and conversation
Well, you did pick Vegas and DC, two of the most notoriously expensive cities in the US. -
Resort Tax, pax ???
Remember the Window Tax? We've brought it back. Here's how I do it as an American; If they have given me individual service, I tip. 20% is standard anymore, 10% and a confused look with an accent gets you a pass on that. If it's breakfast, say $30, I often overtip. If it's an expensive meal, I tip 20%- but beware, some restaurants add an automatic tip, especially for large groups. If they add an automatic tip, I never pay more than that which seems normally about 15%. If the service is bad (because they know it's automatic) I have the tip removed at the register. I quit playing the 'sympathy for tip wage workers' a long time ago. Too many of them make it a game of guilt rather than service. Anything you buy to take home, get it at the duty-free airport stores if you can. -
ANSWERED Advanced troubleshooting (ECU failure?)
Pressureangle replied to Mechanism's topic in Technical Topics
How many amps can your PSU supply? I bench tested a siezed starter with an automotive battery and saw ~450 amps. Have you verified voltage at the ECU while cranking? I've never tried this, so asking in ignorance. -
Er, well, doesn't seem likely. My experience so far is with my '97 Sport 1100 which has a different ECU. I have a lot of simple homemade analog tools for simple checks- for instance, a taillamp bulb with wires soldered to the base which I can attach to the pump terminals to see visually whether it's receiving power or not- sometimes the noise and activity of solo testing makes it hard to hear. I would think it's standard procedure for any EFI system to give a short prime at key or power-on. That your guzzidiag (I've not used it yet) won't connect doesn't sound promising either, but if battery voltage is low that could be the explanation also. Give standing and cranking battery voltages for comparison? -
You can start by checking the crank sensor. Use a Multimeter to check the ohm value- if the value is near zero or infinity, it's shot. I don't remember the correct value, somebody might add that here shortly. Once you determine it hasn't failed completely, you can test the AC output of the sensor also with the multimeter while cranking. You should see voltage clearly, again I don't remember the spec but 5-14v AC seems right for cranking speed. Of course, inspect the wiring all the way to the ECU to be sure it's not disconnected, damaged, or corroded. Edit; also and first, test your battery cranking voltage. If voltage falls below ~10Vdc during cranking the ECU self-protects and shuts down. -
I don't know the 'used car parts' environment in Belgium, but here in the US these Omron relays are under the hood of every Jeep in the junkyard, can be had by the dozens for dollars.
Motorcycle Grand Tour of Texas, 2025 edition.
Pressureangle replied to p6x's topic in Meetings, Clubs & Events
I'll be sure to let you know when I'm there, I have a friend in Cut and Shoot... lol and another in Tyler. Coffee's on me. -
No, I'm just about cleared of the debris from rebuilding the engine in my truck- the lift is covered with tools, parts, and fasteners. May get it up Sunday, and fit the Roper Plate to be sure the new source is accurate. I'm sure they are but don't want to send a plate out that I haven't verified the fit. The transmission is still in Ohio, I'll probably see that in May. I haven't decided whether to strip it to the last bolt or not... have to get closer to decide. The paint needs love, and if the bodywork gets new makeup the whole thing probably should.
Mine just came in the mail. 98% probability I'll be on my '04 BMW GSA. 1% probability each of being on the '05 BMW RT or the '00 MG V11. Depending on timing and availability, maybe 2 if my kid rides along. The plan is to come from East to West, and spend a week or two doing nothing but hitting the stops. Probably going to be more in the hot part of the year, June-ish. The GSA lives in El Paso and it's currently in Michigan. I have a lot of logistics to sort out lol -
Twenty-first (XXI) South'n Spine Raid 2025
Pressureangle replied to docc's topic in Meetings, Clubs & Events
Well, I will; of course any Guzzi can use them, but I'm not at all sure the... RWB flag bearing brands are reserving the spaces they take. OH then there's that one ugly duckling (Gosling) that only has the Eagle on the front. -
It really depends on the bike, doesn't it? The sport has a 4-posted nut on the front axle. 10mm wrench, and a 4" adjustable that opens to about 14mm. Tiny flat for the idle air adjustments (no, shouldn't be fooling with them) battery tire pump and plug kit. A cheap set of metric allens. Seat, tank, etc. is all allen on this one. Whilst rebuilding the V11 I'll have to make note about tools, but I expect it'll be a couple seasons before something falls off.
