Game On
You're right, of course. I have a corollary to Waddington; "It ran when I shut it off..." Bring the gears, they'll make nice centerpieces.
I replaced my intake rubber boots today. Along the way, I bothered to do some discovery on best method, at least on my '97 Sport-i. The winner is Lucky Phil- taking the intake manifolds off is enormously easier than working the boots otherwise. I'm not even certain I could have installed the new boots at all without removing the manifolds; the bar that ties my TBs together is very close to the frame bracket for the transmission brace and wouldn't move back much at all. As it was, I removed the clamps, pushed the rubbers away from the manifolds, removed the 3 mani bolts, slid the rubber back onto the manifold and off of the TB. The mani and rubber pop right out with only a little fiddling and no force. Reverse the process to install. It's easier to install the mani bolts in their holes and place the rubber before working the whole thing into place; take care with the threads as you have to keep the rubber from pushing them around. Installing the screws last is difficult because you can't slide the rubbers back away very far. A ball allen is nearly demanded. I had different gaskets on L & R sides. No info. Both sides stuck to the manifold and came off the heads clean. I cleaned the surfaces and put a very light coat of Permatex #2 to be sure they seal. Reinstalled my throttle rod, synched the TBs, set the TPS and tomorrow a test ride. Idles dead steady at 1100 now. Again. Those throttle rod knobs are still in the works, but they are a secondary priority behind real work.
Well, just think of the bashing I'll give you at the Spine Raid if your stock chain busts and bends all your valves and pushrods. Just think of the bashing I'll give you at the Spine Raid even if it doesn't. Every time your steed hiccups I'll be throwing stones at you.
I've said elsewhere that it's my observation that the bike starts easier, idles faster, never coughs or stalls, lost any hint of the ~3200rpm hiccup and generally runs better everywhere. That said in the environment of neglect, where I'd been sidelined by relay connections and a failed starter motor- the gears were a big improvement even then. I haven't had a whole good day at once on it yet since, but a couple hundred miles says it's great, and a *lot* of maintenance while awaiting the return of my throttle rod makes me very hopeful. It's my opinion that the stock chain tensioner simply does not hold timing well, particularly at idle and ~3200rpm.
Light rattle in gearbox when pushing my bike.
Pressureangle replied to Walterg's topic in Technical Topics
That's a tough 'telephone diagnosis'. Are there cushion springs in 6 speed clutch friction discs? Big trucks break those springs all the time. Could be a bit out of place, protruding just enough to clack against the flywheel. -
stelvio Stelvio gear shift arm bent and cracked-along with my ankle!
Pressureangle replied to LangleyMalc's topic in Newer models
Never had one in hand, but your lever *appears* to be forged, in which case it should be easy enough to have straightened and welded. If you have the desire to overthink and overengineer, you could have one of these cut and welded on, or weld and machine your lever tip to accommodate the replacement tip only; -
Check to see that both ends of your driveshaft are tight on the splines. I had a similarly disconcerting noise when pushing and found that my rear yoke was less than 'very' tight. I have to add that I only discovered it upon disassembly, and I replaced the outer housing bearing; the 'rattle' was gone upon reassembly. So I attributed it to the drive spline coupling. Grab your rear housing to see how much play is in that outside bearing, also. -
Tire shops, like most service businesses in the U.S., are hamstrung by insurance regulation and litigious customers; if they don't follow manufacturer's protocol they open themselves to lawsuits. Wal-Mart will not install single tires. No brake shop will pad your old rotors without at least turning them. No alignment shop will touch your car without nearly new tires. The list is infinite. Tire manufacturers 'recommend' installing new tire pairs, for instance, only on the rear of front-drive cars. WTF? Simple- front tires wear faster, so they get that second pair more quickly. Air conditioning compressor manufacturers require replacement, not cleaning, of other components or your warranty is void. The service environment is engineered to maximize the fleecing, whether it be your fleece by the service agent, or their fleece by the lawyers and regulators. These are what economists call 'unwanted ingredients', and you pay for them everywhere.
Surely. Just as are the camshaft position sensors. I bought one from Romania for $18 plus about $25 postage. No Fiat model that used this sensor were exported to the Western Hemisphere.
I'd use an internal mushroom plug. If you don't ride the sidewall fast and hard, it's highly unlikely to be problematic. Even if it fails, it will leak slowly and you'll get something more out of it.
ANSWERED Air bypass screw quick question.
Pressureangle replied to arveno's topic in Technical Topics
This has me wondering if the real reason for moving the sensor into the airbox is to keep it dry, more than clean or in the perfect temperature (although all are served). I've never noticed any change when running wet or dry, but it wasn't on my radar either. I'll focus on that during the Where nobody gets home dry unless they wimp out early. -
I always install a Time-Sert in soft holes if it's been repaired, or even if it's a known point of failure and it's apart and accessible.
Behind the fairing is the factory install on this early bike. My speculation is that somewhere along the way they found that airbox temperature was significantly different than 'outside' air, most likely sitting idling in heavy traffic. Add increasingly tight emissions requirements, and a simple change of venue for the ATS helped compliance, or at least made drivability/fuel mileage noticeably better. Can't know what the eyetalyun or European requirements were at the time. -
Got to thinkin', my '97 Sport-i has the ATS out in the open behind the fairing, since the airbox draws fresh air from the front of the fairing. -
The ATS has as it's only purpose, to tell the computer the temperature of the air coming into the engine is. So you can literally hang a new ATS from the end of the connector and it will work, although it would probably not live long without a permanent mount. A simple bracket mounted anywhere near an intake, or between them, will suffice. If it's in the open, probably should be inspected periodically for debris and dirt. -
I have ZERO confidence that this 'mandate' is anything more than propaganda to push the sheeple into spending money on Chinese rare earth elements, enriching world investors who own portions of mining and manufacturing in China. Does anyone really believe that Politicians can cross the world petroleum industry? I might entertain a wager that BP and Shell own significant holdings in mining and battery manufacturing in China. The economics, environmental impact, and sustainability of battery powered vehicles is plain for anyone looking or even listening. It's non-existent on all 3 fronts. Yes, electric vehicles are interesting and useful. But they are in *no way* viable on a large scale.
Remember, nothing is obvious from a distance. Just trying to help. -
If you left the old plugs in, it will take some time for them to clean up. -
I had mine done recently by the local WP performance center, which fortunately is only a half hour away. For less than $400 they came back renewed, bushings, seals, cleaned, and hydroblasted. They look nearly new, and they were criminally stained when I took them in. I looked into refurbishing them myself, but I didn't want that particular educational experience at that price, and they needed to be cleaned up better than I could do myself.
That's a wonderful sentiment, but not really applicable in much of the country, or a meaningfully long voyage.
Petrucci and Moto America
Pressureangle replied to GuzziMoto's topic in Special place for banter and conversation
You're precisely correct, and it's been so always, since WWII. Americans fell out of love with motorcycles, and into love with money; a racetrack is a huge investment with little return, and difficult to populate not in the least part because of the cost of liability insurance, the U.S. being the captain of Litigation in the world. It sucks, it shows, and it isn't going to change any time soon. -
Probably not, though on a carbureted bike it could throw off the idle mixture a little if the carbs aren't well synchronized.
Here's my opinion, feel free to disregard it. If you're getting 40mpg, your 'driving' mixture is quite-good-to-lean. If your plugs are black, it's rich at idle or isn't ridden long enough when warm to clean them. Mine had the dreaded '2800/3200 rpm stutter' and intermittent idle stall until I replaced the cam chain with a gearset- then these things, completely unexpectedly, disappeared. At the very least, be certain your cam chain is adjusted properly. The stock adjuster must be attended manually. For my time invested, I'd at minimum replace the stock tensioner with a Valtec, or adjust the stock one properly while awaiting a set of Caruso cam gears. Edit; got my bikes mixed up. The '97 has a spring-type tensioner, but it's woefully weak and I believe allows enough timing variation to confuse the ECU at idle and in the ~3k rpm range.
