You should have seen mine when I got it.
Wondered about that also, mine is a '97. The piece was advertised as 'Sporti'. I guess I never looked for that in photos of the past. I'm sure someone with an earlier model will speak up.
Well, with all that in the background, I'd ride it through the summer and worry over it when season is over. There's a strong argument that changing oil filters isn't necessary with every oil change; theoretically, if your engine never creates a piece of debris bigger than the holes in the filter, the filter does no thing atall anyway. Particularly since gravity doesn't make the filter a collection point, I would just button it up and enjoy it.
It's a square-pan engine, right? Not wide sump? If so there are 4 hex bolts in the bottom, 3 in front & rear, 4 on each side. Even with Permatex hard gasket sealer, it shouldn't be so tight- even if so it should tear the gasket in half. Still confused.
Hm. I did see an old guy carefully drive a utility knife blade into a gasket to start to separate the parts. A new blade and a light touch is worth a try, I suppose.
I bought a tailpiece on eBay just to get the pillion cover, and that it was yellow matching my bike. I paid too much for just the pillion, but figured I'd have the spare tail on the shelf. I thought the tailpiece was the accessory flat-sided tail, but now I think it's from a Daytona. Can anyone confirm, and would anyone like it as a spare? I'll just shelf it. As for the pillion cover, I'm going to take it to the local boatbuilders and see if I can get someone to reproduce it in high-quality fiberglass and perhaps fit it a little more closely to reduce the big gaps they apparently all have.
I bought the beautiful billet shifter/brake levers from Harper's not long after I bought the bike. Somewhere along the way I've noticed that there's more play in the pivot bushings of the shifter than I like, so I ordered new bushings. Upon disassembly and inspection, I found that the stock (most likely stock) bolt is 110mm long, and leaves just about 10mm of threads on the bushing side of the inner nutplate/mount. So the threads and bushing on the inside are hammered. I ordered a new Stainless bolt from McMaster 120mm long, which should get the threads out of the bushing, though I'll have to trim the length of the threads once installed. https://www.mcmaster.com/92290A805/ While there, I pulled back the rubbers from the shift linkage and packed them with the open gear/cable grease I use for my driveshaft splines. They were in fine shape anyway.
Does anyone know what *kind* of sealer he used? I'm not sure even that matters. If you've made certain there's nothing mechanical holding it, the only thing left is the mallet. If there's a clean protruding edge somewhere you can get at with a piece of aluminum flat stock you can attack a corner or side that way without digging too much of the pan material off. As a last resort, and I hate even to suggest it, you might take a cylinder and piston off and see if you can get a piece of hardwood dowel down through the crank and oil stuff to strike it inside the pan. Not a happy thought, nor a guarantee of success. A long time ago, working at a bicycle shop, I was threatening a new carbon fiber swingarm while fishing through a lost cable. The boss said, "You've broken more expensive stuff than this, haven't you?" I laughed, because he was right.
Did you get the 10mm capscrews out from the center of the bottom? That one tripped me up last time, even though I knew they were there once discovered and reminded.
Right side exhaust support broken ChC screw.
Pressureangle replied to p6x's topic in Technical Topics
Buchanan's sells stainless lube for their spokes. I still have an ancient bottle I use for those rare occasions. http://www.buchananspokes.com/categories/miscellaneous_tools.asp -
Metric 150mm scale - check Magnetic angle meter - check Digital caliper - check Ride height also plays a part in rake, a little less in trail. We'll have to find a way to assure ride height is a standard; the easy way would be to measure the top of the spine with the tank off.
Living on the Seacoast myself, I have to admit it's a constant battle to keep the brown menace at bay- 'Rust never sleeps'. I replace anything I can with 316 Stainless and what I can't get in stainless I get in a phosphate black and coat it with Cosmoline RP342, either sprayed or applied with Q-Tip. Once dry, you can wipe away any excess you find distracting and it will remain in the pores for the rest of eternity. I haven't seen a spec on anything I've used it on, ever. Shouldn't be a surprise given that was it's purpose from day one, but nobody thinks about Cosmoline except when they have to clean it off a WWII relic. -
For what it's worth. I bought a case of 12. Subtotal: $96.78 USD Shipping: $32.00 USD FL STATE TAX - FLORIDA: $0.00 USD Grand Total: $128.78 USD
Throttle body balance rod adjustment knob
Pressureangle replied to Pressureangle's topic in Technical Topics
Bumping. Hope to have at least a couple in hand (including my own missing sample) in a week or so. -
I've been waiting to fill my rear drive until my Chevron Delo Gear ESI 85w140 came in. Today was the day. First thing I noticed is that considering the labelled viscosity, it seems pretty loose in the container. Far sloshier than a heavy conventional gear oil. <wary look> Visually it's darkish golden, not much different than other lubes. No particular smell. I added ~255-260cc to my dry, clean gearbox. While hard to see through the fill hole, it's quite obviously far above the 'level plug' on the back of the box, and someone has probably figured out before that the level hole *might* be correct if it was horizontal to the ground with the axle. Turning the wheel, the oil appears thinner than the Redline heavy shockproof I had in it, as well as the Lucas/moly additive just lastly. But it also carries up the gear well and leaves a heavier coat than I expected. All my research says this should be as good as it gets, and has alien magical properties unknown to lesser oils. I'd say 'we'll see' about how well it works, but truth is there hasn't been any shortcoming in previous oils to compare to. <shrug> I feel good about it, which is about all we ever get to say about gear oils.
If the engineers spent the time to design a spine via FEA as they have with perimeter frames and swingarms I'm certain it would be magnificent; the problem is it would only be applicable to Moto Guzzi, I think.
I haven't had much luck with *anything* I've purchased over the past 10 years. I assume anything new is Harbor Freight, regardless of the label. The Chinese Conspiracy is pervasive.
I have a Blue-Point made by Jaco that's about ... 40? Years old now. Doesn't have the safety relief but has been reliable, accurate, and consistent across time. I did have to replace the plastic disc in the pressure release button once about 15 years ago.
Well, being Aussie/English he'd call them 'Lambchops', of course.
