Agonza5
About Agonza5
  • Birthday 05/30/1974
  • Location
    Lebanon, Pa
    Moto guzzi V1100,Suzuki tl1000r,2 Honda cx500
610 profile views
Agonza5's Achievements
Guzzisti
Guzzisti (2/5)
3
  1. Ok thanks
  2. Just installed a odyssey battery and I did check the voltage on that, that reading at about 12.75
  3. Yes
  4. I did that, when I’m looking at the bulb I can see that the probes are making contact with the bulb and I did change out bulbs with 2 different ones just to be sure that it wasn’t the bulb. Do you think that since I got 2 different voltage readings that it should be working?
  5. I used a volt meter and got 11.5 and when pushing on the brake pedal got a reading of 11.75. I checked all my connections in the tail section. Everything is connected getting power to it. I did reverse the two wires for the tail light just to see what would happen and noticed that the brake light and parking light came on and stayed on.
  6. Yes
  7. I have a 01 V11, parking light is working but when I apply hand brake and foot brake the brake brake light doesn’t turn on when I reversed the wires to see what would happen the brake light then comes on and stays on. I checked all my connections, fuses and relays to make sure I have power and I do, I’m not sure what to do next, any help would be greatly appreciated.
  8. Agonza5
    Agonza5
  9. Brand new starter and switch.
  10. Thanks docc, I will check it out. I had a bit of trouble yesterday riding home, I thought I could hear back fire not loud and loss of power until it shut off on me and the tachometer stop working also couldn't get it restarted after that.
  11. 2001 v11 Russo Mandelo
  12. Ok WTF, I never had to do that before I changed starter and switch, can you explain why it starts this way now and thank you for this. I was pulling my hair out!!
  13. When I hit the starter switch I get absolutely nothing, after several attempts sometimes it will engage or when I roll the bike around
  14. Replaced starter switch and starter on my 2001 Russo Mandllo, still having issues with not starting, what to do???
