kool keef
Everything posted by kool keef
From the album: kool keef
Pete and Phil - thanks for taking so much time to reply and explain. Unfortunately you are making the assumption that I am into 'tech'! This is all right over my head I'm afraid, but interesting nevertheless. Just out of interest, I don't see how you can possibly get the best out of any sort of remap unless it is done in conjunction with a rolling road which produces real performance data?
So are you saying the standard ecu can be custom remapped?
Don't get what you are saying here Pete - explain? Several years ago I fitted a PC 3 on my V11, which was then set up on a rolling road and the bike has to be ridden to be believed, it is so superior to a standard bike.
I am looking for a Dynojet Power Commander 3 for my 2004 V11 powered Triking, so the ecu can be custom remapped on a rolling road. This is no longer available from Dynojet in the UK, but I have been offered a Power Commander 3 for a 2000/2001 V11. Does anyone know if there is actually any difference? Will this suit the later engine and ecu?
Does anyone know which oil pipe union on the front of the engine, is the return from the oil cooler? I am building a Triking with a V11 Sport engine and want to mount the oil cooler vertically, so want the return from the topmost union.
I am about to break a 2002 V11 LeMans. The bike is not damaged as far as I can see. All parts are available except as described below. I am keeping the engine/gearbox/drive chain/swinging arm and the wiring loom and electrical parts required to run the engine. So please don't enquire about these parts. Only UK enquiries please. For anyone wishing to collect parts, I am in Devon.
Thanks for your input everyone. If I do try a linked brake set up I'll report back with my findings. Now I need to make the most of the English summer and ride it! For those interested in engineering, I've put a load of pictures of the bike on the gallery (hope I've put them in the correct place!) Thanks for your interest
The result of eighteen months work. Anything you don't recognise - I probably made it! Any questions do ask.
From the album: V11 Retro LeMans
How it started off -
Tank nearly finished -
Tank under construction -
Brake side of the rear hub -
Completed rear hub with the rubber and bearing cartridge -
Main body of the rear hub showing the cush drive rubber recesses -
The inboard oil cooler mounting -
Showing the custom made rear sub frame -
Tank is held in place by a wide stainless strap set in a recess in the tank, which engages on a clip on top of the frame and screws down to the frame behind the tank
