Niels Knudsen
Everything posted by Niels Knudsen
Hi Condezaca. It may be the loose counterweight-syndrom. See my post: Greetings Niels
Owing a MG V10 Centauro, Ive made a TPS-harness myself, I used Superseal 3 pin male and Female, see link: https://www.dkvolt.dk/produkt/superseal-stik-3-pin-er-et-vandtaet-stik-til-samling-af-ledninger/ Which fitted the OEM connectors 100 %. See photos. Greetings from DK Niels Knudsen.
Veglia again, again.. pointers and repair.
Niels Knudsen replied to Niels Knudsen's topic in Technical Topics
Hello Lukcy Phil. I used nailpolish, because my wife always have a heck of trouble removing it. So I thought it will be durable. And it was easy to applicate with the built-in brush, and furthermore cheap, because I stole it from "She Who Must Be Obeyed." Greetings from Dk. Niels.- 11 replies
- 1
- veglia
- speedometer
(and 2 more)
Tagged with:
Hi all. Last week both my speedometer and tacho stopped working. Speedo at Zero and tacho steady at 7000 rpm working upwards. Pointers very fainted. Decided to repair. Removed bezel as otherwise described, painted pointers with red nailpolish. Found loose counterweight in tachohousing (clic-clac). Repositioned counterweigt and glued it. Put meters back together. Speedocable was broken, replaced. Now a happy man...... Photos at this link: https://www.dropbox.com/sh/n5y45n8b9itng5f/AABNyYy7UqkU3oagmoOnXoMsa?dl=0 Greetings from Niels Knudsen, DK
- 11 replies
- 4
- veglia
- speedometer
(and 2 more)
Tagged with:
First go to: https://www.blocklayer.com/degree-wheel.aspx Fill in your values from handbook, EX: Intake: open 22°30' before TDC - type 22.30!! Follow page instructions, I choosed CD-size, and print PDF. Cut out print and glued to a CD. Wheel is hold at alternator by magnet, pointer made of coloured paperclip, bent and hold by magnet. Photos here: https://www.dropbox.com/sh/wpw59z5j0wr4or5/AABWfJp0ndQOaEr9fDZviHD8a?dl=0 Greetings from DK Niels Knudsen
Hi all Guzzistis. Ive installed, what I consider being the best mechanical cruisecontrol: "BrakeAway". It locks the trotthle-grib at preferred position, it is activated by pressing a button, and de-activates by pressing a second button. The genius thing is that if the brake-lever is activated, the cruisecontrol is immediately de-activated. Easy installation and use. Se photos at this gallery: http://www.v11lemans.com/forums/index.php?app=gallery&image=1963 and installation/function here (sorry, no Guzzi): Greeting from Niels, DK
Best mechanical cruisecontrol??
Images added to a gallery album owned by Niels Knudsen in Members Gallery
The "BrakeAway" cruisecontrol, which can be de- and activated by thumb-press, but also by activating the brake lever. (Genius) -
From the album: Best mechanical cruisecontrol??
Hi All Guzzistis. Ive made a little experiment: Is it possible to connect a bluetooth-enabled helmet to a handheld radio using bluetooth-setup with a wireless PTT. My ingredients were a bluetooth-enabled helmet (Schubert C4), radio Baofeng UV-5R, and Louiton Bluetooth Earpice. I only turned the helmet in pairing mode and the BT Dongle and the PTT on......Succes, Heureka, the Helmet connected to the Dongle, and I could listen and transmit via the wireless PTT. If my touring-companion makes a similar setup on his helmet and bike, then we can communicate effort- and wireless up til 5 kilometer, app. 3 miles. See photos in gallery, at this link: http://www.v11lemans.com/forums/index.php?app=gallery&image=1962 Greetings from Niels. DK
- 5 replies
- 2
- bluetooth
- communication
(and 2 more)
Tagged with:
Bluetooth communication Helmet PTT
From the album: Bluetooth communication Helmet PTT
