About LangleyMalc
- Birthday 11/28/1950
Location
Langley BC 🇨🇦
My bike(s)
2004 Balabio, (2014 California and 2013 Stelvio. Both sold)
LangleyMalc's Achievements
Guzzisti (2/5)
42
fuel pump and filter Resurrection of 2004 Ballabio
LangleyMalc replied to LangleyMalc's topic in 24/7 V11
Thanks for the replies. Like you I also could not find an Odyssey or a Yuasa in YVR. Finally bit the bullet on an EarthX ETX12A as per gmc28. It is slightly smaller than the Odyssey or the Yuasa in one dimension (1” approx) and in CCA. It is 220cca vs 230cca for the other two. It also needs the right smart charger but I had one of those anyway and I don’t have to fiddle with the wiring as per Phillip. Finally it is the same price as the Odyssey on ebay.com. Only drawback is a trip to Point Roberts WA to collect it. (Free postage to the US even if PR is in Canada- perhaps we can get Donald to sell it to us. Property values will then tripple!). I will try to make a Moto Social this year and may see Phillip there. thx. -
Hi guys. Tank is cleaned out and back on but I need a new battery. Yuasa YTX15L-bs is unobtanium up here. Also Odyssey PC545 out of stock, which I had last time and which did not last as well as the Yuasa. Anybody tried a NiFePo battery? -
Thanks Guys, a big help; particularly the tank off check list at the end. anyone replaced the internal filter? -
I have finally got Collector Status on my Balabio which gives me cheap(er) tax here in BC. So it is going back on the road after about 4 years of standing. Right now I am planning a fluids flush plus replacing the fuel filter and in tank hose. The tank is off and I am emptying out the old fuel/mush and cleaning that out and will do the brakes and clutch. what else am I missing? Tyres are new/5 yrs old. Brake pads are good. also any suggestions on the in tank portion of this challenge gratefully received. I got past the dreaded QDF connectors to get the tank off, but the tank breather hose underneath is a bit tired so will replace that. Not sure on pump gasket but will find out shortly but does anyone do a complete kit for the pump hose, gasket and in tank filter? Thanks.
Stelvio/California soft brakes - ABS?
LangleyMalc replied to LangleyMalc's topic in Technical Topics
Looks like I need the latest version of GuzziDiag. Then I have to find a Windows computer. Granson has one I think. I suppose its in keeping with the bikes! The trouble with Guzzis is that they push you towards excellence and they are relatively easy to work on. Not sure wether or not that is a good thing but it keeps me amused. -
My two ABS bikes do stop - just not crisply. Perhaps all I want to know is that everyone else’s bikes of this genre behave the same. However, I feel that would be disappointing and as such choose to believe there must be something I can do about it. the $64,000 question is what? -
I have re-assembled the bike post my last off road adventure, and apart from realizing that the Stelvio is big and heavy, particularly when fully fuelled and loaded with camping gear, I have now come to the realization that I cant ride in sand! either way, I noticed on the trip that the brakes on the Stelvio are a bit mushy. They have always felt a bit like that. They stop the bike, but I don’t get the feeling that it will stand on its nose, and the back brake has longer travel than I would like, ( touches the centre stand on full braking) and does not seem to really lock up the back wheel. The brakes were bled by me and fluid replaced at the beginning of the season, but the ABS was not purged as I am too tight to pay the dealer. So any suggestions on shortening the brake pull and sharpening up the brakes, or am I going to have to pay the dealer to cycle and purge the ABS? I do have new pads to go on, but am holding off until I have to fit new tyres this winter. separately my 2014 California also has “long and softer” brakes, ( it weighs at least as much as the Stelvio) but the V11 Balabio (no ABS) will stand on its nose and locks up the rear at any opportunity!
stelvio Stelvio gear shift arm bent and cracked-along with my ankle!
LangleyMalc replied to LangleyMalc's topic in Newer models
Thanks for the advice Peter. I’ll get one. -
Many thanks for the responses. I managed to find an OEM replacement on e- bay. For Pete R, I was curious as to which pivot pin? I presume it is the one that mounts the lever. Like Scud the conclusion I reached at the end of this trip (apart from being thankful I was wearing long touring boots) was that while the Stelvio is a great touring bike and load carrying Mule, it aint no back roads ADV; at least not with me riding it. So my next tyres will likely be Conti Trail Attack 3,s. Oh dear, is that the start of a tyre thread! Thanks again. -
I dropped my Stelvio in sand on a backroad (twice). Apart from buggering my ankle under the pannier box, (note to self - you cant ride in sand and certainly not on a Stelvio with full gas and loaded with camping gear. Stop kidding yourself); In the crash, I bent the gearshift lever and cracked the end fitting where the pedal attaches. You can see in the pictures the bend and it is cracked and bent at the bolt hole for the pedal. The light is hopeless but you get the idea. I presume, looking at it, the arm is toast; but just on the off chance, can the arm be straightened and the crack welded, or does anyone have a spare I can buy or steal, or do I have to go to Guzzi for a replacement?
ANSWERED My Stelvio coughs on overrun and does not like idling!
Having read all the comments above (at least twice), I would comment as follows: The bike is stock, with a colostomy bag and standard exhaust. It does have a washable air filter - I did listen to Peter's comments on that; in my defence it came with it and this is BC and despite the four months of absolutely dry weather for the summer this year, most of the time it rains here! However, I will replace with a paper filter next time I am in the dealer - assuming he doesn't suck his teeth and say "Not a lot of call for that. We'll have to order it in". In that case it will be at least 8 weeks and by that time it will be Christmas and we will be worrying about frost and snow. Since the latest check of the valves, (all within 1 thou of 4 & 6,) plus the reset of the throttle bodies, it now idles quite nicely at 1200. On a point of information it always did idle well on cold start up, but once the engine was warm it would then start to bumble a bit and could stall on tick over. Not any more. The popping on overrun was worse with the original map and mostly went away with the Beetle map. I tend to blip the throttle on downshifts and use engine braking alot. So while it still pops a bit, based on Pete's latest dissertation above, it apears that this is now a "Feature." So not a problem as long as I know what is causing it and I think now I do. It was just my Cali 1400 did not do it! (different engine and different map I presume.) Either way - I will now leave the bike alone and ride it for a while - weather permitting - knowing that I have the fuelling as near to right as you can get it, without resorting to re-mapping. Quite frankly, the bike is still capable of a lot more than me and as such, apart from the weight of it and even worse the weight of the Cali, I think it is a fine bike and I am very fond of it and its associated "Features". The next job is putting back together the V11 that my daughter dropped! Nothing major, but lots of bits of unobtainium. Thanks again for all the help and a very interesting discussion and learning experience. Malcolm- 44 replies
- 1
- carburation
- lambda sensor
(and 1 more)
Tagged with:
Well I finally got Guzzidiag to load and recognise the ports on the old Windows computer. Then got hooked up and checked the TPS - it was at 4.6 deg. Then checked all the screws on the throttle bodies and the ends of the linkages etc and all the painted ones were still painted and intact with the exception of the high speed adjust screw on the linkage on the left body and the two air bleeds. After this I reset the TPS and it went to 4.8 and I cleared the learning parameters. To make it easier to get at the left hand bleed screw, I took off the starter motor cover. Needless to say one of the little dome head Allen screws socket stripped, so I had to use a stud removing socket to get it out, but after that no problem. Must have been done up by Guy the Gorilla. I then checked the air bleed screws with a view to shutting them. Both were open to some degree, so I closed both. That was tricker than it should be because of the location. Then hooked up my ancient mercury powered Motion Pro vacuum gauges and after the first run, remembered to move the breather hose on the back of the motion Pro to the open position; thus improving the stability and accuracy by a significant degree! Ran the bike up to 3500-4000 rpm and held it there at a reasonably constant 3800 speed, with a G clamp on the throttle and then balanced off the mercury columns using the speed adjust screw. Removed the G clamp and let the throttle snap back. TPS was now 5.2 and then re-sett the TPS again (back to 4.8)and cleared the learning parameters. Finally, adjusted the slow running balance using the air screw on the right hand carb as it was higher. On the tick-over part of this the mercury was bouncing about a bit, but both appeared to be level, or operating in the same range, so I called it a day. End result is that the tick over is around 1200 and not too lumpy. (It got smoother once I took off the carb sticks and re-connected the vacuums.) Cant tell about the over run as it was P-ssing down outside the garage so that will have to wait for another day. All in all a successful mission and I now understand how the throttle bodies work and the logic behind the tunic sequence. One question - If the stepper motor basically controls the slow running sequence via the computer, is it not possible that the pipework, or the stepper motor gets full of sh1t and so needs occasional cleaning? (Not letting go of this one quite yet!) Many thanks for the help and instruction Pete, - Anyway; I enjoyed it! Malcolm.- 44 replies
- 1
- carburation
- lambda sensor
(and 1 more)
Tagged with:
Talk to you tomorrow.- 44 replies
- carburation
- lambda sensor
(and 1 more)
Tagged with:
Hi Pete with the lumpy idle, could this be the stepper system getting clogged? I presume it is worth cleaning it no matter what, along with the rest of the service and throttle body reset.- 44 replies
- carburation
- lambda sensor
(and 1 more)
Tagged with:
Enjoyed the youtube video which was very informative. Thanks. Now to get the Grandson's computer to start the process and to take a trip to the garage after dark. More in the next week!- 44 replies
- carburation
- lambda sensor
(and 1 more)
Tagged with:
