Everything posted by Nihontochicken
I've done nothing, this is how the scooter came fro the original owner. I'm guessing it's just the amount of bolting force on the bar anchor. When I dropped the bike on its left side in the driveway , the bar anchor joint didn't rotate, only the ball joint moved, enough to keep the mirror from breaking (a scuff on the rim only).
As I mentioned in another thread, I'm happy with my CRG barend mirrors, tucked in, give a decent rear view, and one of mine even survived the V11 driveway drop test. CRG makes many other styles, link below if interested (no relation, my mirrors came with the bike when I bought it). http://www.constructorsrg.com/mirrors/index.html
I see what you did there.
Here's a closer shot of the critical parts (not showing the typical T-handle and bit holder on opposite ends). I'm quite limited on the size of pictures I can post here, so this is the best I can do after shrinking the frame, and hence the rather small pics earlier. Shown also is the original mailing box, but I don't still have the receipt, alas. Now that I think of it, the tool may have cost closer to $75, but I'm just guessing now, it was a long time ago in a galaxy far, far away. Note, I corrected a misstatement in my post above. "Depending on how far the sliding hammer is rotated with respect to the Delrin buttons, the tool may be used to either tighten or loosen screws or bolts" should instead read "Depending on which way the sliding hammer is rotated with respect to the Delrin buttons, the tool may be used to either tighten or loosen screws or bolts." Of course, only an idiot would use an impact driver to tighten a fastener, it is generally useful only for loosening. Some specialized bits to cut new slots in buggered screw heads were supposed to be included with the tool, but Joe was out of them when he sent my example, and I never did get them. Too bad, they would have been useful in a few cases.
Colder ... Warmer ... And we have a winner! It is indeed a specialized impact driver. Depending on which way the sliding hammer is rotated with respect to the Delrin buttons, the tool may be used to either tighten or loosen screws or bolts. The degree of rotation will vary how much force is delivered to seat the screw or bolt and how much is applied as a torque. Once loosened, a fastener could then be unscrewed with the T-handle wrench. It was made about fifty years by Joe Bolger of Barre, Mass. I think it was about $50, a fair piece of change back then. What a "serious" rider would have in his kit, along with his safety wire twisting tool.
Here are the tools I generally use: A bit more seriously, as I was going through my old tools, I came up with this one. Anyone wish to identify what it is? Bonus points for naming the maker and approximate year of manufacture. Double bonus points for explaining why this tool was intended as an improvement over its more usual competitors.
Ooh, bright red valve covers!
I have Shinko on my DR650, works decently for the street. For the dirt, well, okay for a smooth fire road, but that's as technical a situation as I want to push an overweight, undersuspended pig like a DR650 anyway. As an aging serious trail rider who gave it up a few years back, here's my rant (again?): Any tire that works well in the dirt will get burned up in a thousand miles or less of street riding and then be worthless in the dirt. Any tire that can last a few thousand miles on the street is about worthless in the dirt from the gitgo. Of course, I'm talking serious dirt riding here, not an occasional gravel road, so this contention has somewhat limited application to the big brontosaurs even heavier than my DR and so even less appropriate for real dirt. I think Shinko is likely the best current trade off between price, dirt traction and lifespan. JMHO.
FWIW, here is the set up on my V11 as purchased from the original owner. The left side CRG bar end mirror was unfortunately static drop tested in my driveway early on and survived with only some scratches, mostly hidden now with a bit of black touch up paint (the left turn signal was terminal). The newer CRG models seem to go for about one Benjamin a pair. I'm pretty happy with these mirrors, adjusted so my elbows take only about a quarter of the field of view. I wouldn't put up with the high rise stock mirrors or equivalent. (Hmmm, looks like the scooter needs a bath. )
Ooh, bright red valve covers. I feel a stirring. Must resist, must resist ...
Replaced the valve cover gasket yesterday with a cheap and simple greenie item available off eBay. Test ride today indicates the oil boundary is holding. Will see what a few more miles and heat cycles do. As mentioned in another thread, most time was taken by cleaning off remnants of the old gasket. Didn't the Japanese solve the problem of engine oil leaks about fifty years ago?
Replaced the leaking left valve cover gasket today. Will smoke test it tomorrow. Just used a readily available green gasket, perhaps will invest in the high zoot metal item if this current entry fails. Of course, most of the time was spent scraping the old gasket remains off the mating surfaces. Noted that the cover mating surface does not seem to be very flat, may have to try the glass plate grind trick if it piddles again. Also temporarily replaced the aluminum front brake reservoir cap with a plastic one that will serve while I get the original recoated due to the brake fluid corrosion of the paint. Maybe do it in Italian fire engine red?
Thanks for the responses so far. Again, are all the cover bolts supposed to be the same size, and do any/all utilize washers? Inquiring minds want to know!
My first oil leak (I think, I hope!) just started recently, originating from the lower edge of the left cylinder valve cover. I checked the bolts, which were not loose, but not tightened very well at the bottom. I torqued them down, but no cigar, the leak continued. Removal of the cover revealed the problem: Close up of the culprit: It appears that with the lower bolts not properly tightened, the gasket edge migrated away from the mating surfaces to the inside until a flow path was opened. So this leads to a few questions. If repositioning the gasket fails (which I anticipate), where is the quickest and/or cheapest place to get a replacement gasket, or would I be as well off to cut my own from stock gasket material? Also, I noticed all the hold down bolts were the same size except the top rear bolt, which is markedly shorter. Is this correct, or a Bubba mistake? Also one and only one steel washer dropped free from one of the bolt seats. Should all, some or none of these Allen head hold down bolts use washers? TIA for any and all enlightenment!
Wow, would really like to attend, but too many miles in between, alas. Am particularly smitten by the pic of the only bike prettier than a MG V11 or Norton Commando (edit note: venue is up tight about hot linking images, guess they don't like the free advertising, so similar images substituted below): Never scored one of those, but did finally snag a V11. Also got one of these consolation prizes: Congrats to all those who will attend this event. Good beer and classic bikes, what's not to like?
- 11 replies
- 2
- things to do in winter
- bikes
(and 1 more)
Tagged with:
Adventure bikes
Nihontochicken replied to Lefty's topic in Special place for banter and conversation
In my neighborhood. That looks like the (rare) straight-as-a-string two mile stretch just south of San Carpoforo Creek, immediately north of which the road gets very twisty as it rises off the flat and into the coastal ridges. It was on this segment years ago when a bunch of us on sport bikes (Duc 750 for me) were on the way to view a Luguna Seca road race. A laggard whom we woke up on our way through Morro Bay passed me here in a red shift blur on his Yamaha R1. When we stopped at Gorda for lunch, I asked him, a road race instructor, how fast he was going when he blew by. He answered, "A bill and a half." I.E., 150 mph. So what happens when you smack a critter at that speed??? In any event, you picked a unique time to ride through the neighborhood, the first major rain front of the season, and a damned cold one to boot. Snow on the coastal ridges is a fairly rare event here. I for one am keeping Claudia (V11 Sport Naked) snug and warm in the garage, no chill rain or snow on her delicate parts. YMMV. -
Nihontochicken replied to chamberlin's topic in 24/7 V11
I think I see a Roper line: https://photohosting.azureedge.net/vmp/Dealers/71033/135817207/Photo/ZGUKTC029M111161-17.jpg Would be interesting if closer, but then I guess one temperamental Italian hottie is enough for me to handle. -
As an aside. in the early/mid 2000s I bought a MG 850 LeMans that was shipped in a crate from out of state. I was told the shipping company would not help getting it off the truck. So I built a platform out of leftover railroad ties from the front retaining wall and used a come along to yank the crate out of the truck. I then proceeded to deconstruct the platform by hand, tie by tie. Well, on one lift I gave myself a hernia. Oops. As it turned out, the LeMans had two dented wheels (they were pretty soft in those days), and by the time I acquired two new ones (no small feat even back then), I lost interest and sold the bike on, alas. It was only a year or so ago that I filled the void (2004 Sport Naked). Just another MG trivia tale.
What he said. The MGS-01 was perhaps "a bridge too far". But there hasn't been a sport/touring bike yet out of Guzzi to match the styling of the V11. Power, yes. Handing, I suppose. Styling, no way. Strange that Piaggio should push the new path of adventure touring mis-marked by the Stelvio with the entirely new engine and chassis of the V85. Why not instead simply put the Stelvio engine in an updated V11 frame and body work? Maybe not ideal, but surely a cost-effective step in the right direction. Sigh.
So why can't Piaggio do something like this???????????????????
What do you call your V11S?...
Nihontochicken replied to mznyc's topic in Special place for banter and conversation
Just visited my old school buddy and got the answer. "Sophia" and "Gina" are Sonus Farber speakers, didn't catch the model, cost in the mid $30k range, so maybe only half the price of his BMW auto (M340i, he had an M4 but didn't like it). -
I guess mine is properly termed a V11 Sport Naked, but I call her Claudia (as in Cardinale). Why? Because Sophia (Loren) and Gina (Lollobrigida) were already taken by my buddy's Italian stereo speakers that cost nearly as much as his BMW car. -
Escaped West El Lay after high school in 1967, went to the San Diego area when it was nice. But then coastal North SD County was trashed by the developers in a metastatic southern migration from Orange County in 1976-80 while I was out of state in the Navy, so I then relocated to SLO Town (San Luis Obispo), at that time relatively unknown to me, but found clean air and low population density charm that had been eradicated in So. Cal. Been a great 40 years, but the cancerous real estate development feeding frenzy has finally hit here. Big developments used to be 50 to100 units or so, now the numbers are ten times that large. Sorry for the unrequested rant, but I'm really pissed off by the current So. Californication of this once beautiful community. Then again, by the time it's thoroughly effed over, I'll likely be past worrying.
