BramF
  • Location
    Gld (NL)
    V11 LeMans 2002
1,769 profile views
BramF's Achievements
Guzzisti
Guzzisti (2/5)
25
  1. A few years back I ordered a complete bucket for my V11 Lemans from Wendelmotorraeder (https://wendelmotorraeder.de/headlamp-assy_640541-p-1043390.html) They still seem to be selling it now. I know it's not an upgrade but it might give you an additional option to consider
  2. Thanks for the tips! Have contacted a few of the sellers, just waiting for a response from them. Somehow I do find it strange that these Brembo original discs still go for such a high price, considering they are used on a lot of bikes. Update: Just got a reply from my local Piaggio/Moto Guzzi dealer, they can supply the discs at 430 euro's a piece
  3. Is there a shop within the EU that still sells the rotors at a 'reasonable' price? The only options that I can find are 400+ euro's for just 1 rotor.
  4. Great bit off kit! Had the pleasure of receiving it just in time ahead of a long trip to Germany and Luxembourg. It held up great and improved the shifting a great deal.
  5. Correct, there is a fuel sensor on to one side of the tank towards the seat area, the other side contains the fuel petcock (at least on my V11 Lemans ’02). Because of the way the fuel tank hangs on the frame there are essentially two compartments on either side of the frame. Moving the bike side to side will cause some of the fuel to move over to the other compartment.
  6. I'll be happy to take one aswell, so that's 4 in total now
  7. Just finished the installation of the Hyperpro, it fits perfectly fine. Just have to make sure the adjuster knob is pointed as far upward as possible.
  8. Thanks for all the replies! In order to find out for sure and provide a bit of additional knowledge to the forum I decided to bite the bullet and order the Hyperpro damper. Should be here in a few days and I will report back to you with my findings
  9. Hi all, Whilst performing some maintenance on the V11 LeMans I noticed the Bitubo steering damper weeping oil. As I’m overhauling the suspension (front shocks -> Andreani Misano Evo, rear shock -> Hyperpro) I figured I might as well find a good replacement for the steering damper. After browsing the forum and searching all over the internet I've not found an alternative to the less than ideal Bitubo steering damper. The Shindy 17-001 seems to be unavailable in Europe and the guys at Hyperpro can’t confirm that their steering damper will fit as they only tested it on a V11 Sport. Have any of you found a good replacement that is still available?
  10. Hi, Does anyone know of a front brake rebuild kit or what kinds of supplies I need to get in order to do a full service on the front brakes that is available in the EU? Turns out none of my local Moto Guzzi suppliers can help me as Brembo is not offering any rebuild kits. As far as I can tell by the maintenance records mine have never been rebuild and one of the pistons keeps getting stuck causing my front brakes to judder. Whilst doing some googling I’ve only been able to find this kit : https://www.ebay.com/itm/153586237870?hash=item23c27401ae:g:yJMAAOSwS6ddQEb7 In my mind it seams fairly expensive for just a few plastic rubbers and crush washers. Hope you all can help me. Kind regards
  11. Oil pressure and neutral light all word like they should. Usually the low fuel light would come on at 250km. I have gotten to this milage a few times recently but haven't dared to ride much further without fueling up, what should be a 'normal' range for the fuel light to turn on?
  12. So i checked the sensor wiring and it seem to be connected, also hooked up the multimeter which gave me a measurement of 1,600 ohm. Guess I'll have to keep looking/troubleshooting...😥
  13. Thank you all for the good suggestions Will investigate the fuel sensor connection this weekend and report back to you all.
  14. Is there any new info on a replacement for the fuel level switch? After taking my tank apart in order to get it painted it seems as the switch has given up. I've tried testing the fuel light by powering it directly and that lights it up nicely so I'm suspecting the fuel level switch of causing the fuel light to no longer work.
