Phillarsen
    2004 Moto Guzzi V11 Sport Ballabio, 95 Ducati 916, 82 500 Turbo, 79 CBX, 75 Norton 850, 40 Indian Chief
803 profile views
Phillarsen's Achievements
Rookie
Rookie (1/5)
3
  1. Phillarsen
    Phillarsen
  2. Thanks Chuck and Scud for all your work on this issue. I received the springs (2) for my 2004 V11 from Scud (had broken third spring in about 12,000 miles, and had 15mm correct arm from new, some broke at coil and at end). Thanks Scud for effort to get spring to me in time for the long weekend. I installed about 3 weeks ago, and now have about 1500 miles on the new spring. Shifts great, everything works as normal. Working to get more miles on these next few weeks.
  3. That looks useful and I think the odometer and trip meter gears are there, so I could use it to see about getting some made. Can I buy it from you?
  4. I am hoping to keep the bike stock, thus the desire to fix the ITI Speedo. The part number I am hoping to buy is GU01761560 or GU01762490. One is MPH the other KPH. Either one is ok with me. One where the odometer is not working is what I am looking for or is there is such a thing , one that is working is good to, and I will still take it apart and get replacement gears made thanks
  5. Motorcycle Parking is right at the front door. The way it should be. Great wine, beer and pizza served.
  6. I had a problem like this a few years ago on my 2004 V11 Sport. It ended up that when I was starting it, and did not engage starter long enough to start it popped back, and as I found out after a couple hours of trying to figure out the issue of lean and missing and popping on one cylinder (left one) that the boot between throttle body and head had dislodged aft but was not apparent at a glance. It was leaking air in. When I found it, I was shocked it ran like that. I just loosened it all up and reinstalled it and everything back to normal. When I checked the right boot it was also not tight (all was as installed from new, never taken apart).
  7. I am looking to buy a used ITI speedometer to use to take apart and see if I can get some replacement gears made for the worn out plastic gears. My odometer stopped working. I took it apart and confirmed the gears are worn out. As I could not get any replacement gears I put it back together so I could use the bike as speedo still works. Would like to work on repair of another broken one while still using the bike. You can also text me at seven seven eight nine nine nine zero zero nine four. Vancouver Canada
