Flooky
  • Location
    Uk
    V11 sport, yam fzs
1,153 profile views
Flooky's Achievements
Guzzisti
Guzzisti (2/5)
46
  1. Any body got one lying about?
  2. Flooky
    Happy xmas all
    Have a great xmas everyone 👍
  3. Thanks.. Switch fitted, new oil, new fuel tank to pump fuel line seems ok too. All good now..lights out as it should be.
  4. Thanks folks, I will order a new switch tommorrow. Got the old one off and i am now replacing the tank to pump fuel hose. This forum is great. I would be lost without it
  5. Hi folks, I started the bike today and the oil light was on, through the revs, not flickering, on solid. Searched this great site... Took sump off, filter tight. No recent oil changes ( so not 2 filter gaskets ) Nothing horrid in the sump and strainer clear Oil level fine. Refitted sump. Tried to remove oul pressure switch but seems tricky without removing tank. ( sundays job ) Any pointers would be great, is it likely to be the switch ( when i pull the wire off the light goes out ) Or something else ? Cheers
  6. Great, thanks
  7. Just a quick question, can i run 5 pin relays in all the positions ? I know only one needs 5 pins, but will a five pin work in the others. ( cutting down which spares to carry )
  8. Thanks for all your help . Bike is running ok, but i am slowly working my way through all the connections. This really is a great forum. I wish i lived in the US
  9. I will try, new ones, thanks
  10. I carry spare relays under the seat, and i changed the pump one at the side of the road, didnt work. Can relays be intermittent ? Cos i put the original back after it didnt appear to be the issue.( original being an omron not original original )
  11. Thanks folks, this a great forum. Bike will now will start under all the above conditions, but i would like to find an issue so i can have confidence again, the fuel pump is buzzing away well, but i dont trust it. I will source a new pump ( thanks docc ) but not sure thats it, do they fail interrmitantly ? ( spell ). Cant seem to find a reason it didnt work. When i disconnected the sidestand and it worked i was happy, but then all back together , no pump. I can only think connections on fuel pump. I think my rides will be near home for a while, but we got a great burger place 15 miles away so 👍
  12. I took the tank off, pulled apart the sidestand switch conector, pump worked ! Great Put it all back together, no pump. Apart again, checked pump connections, a bit loose but not terrible, cleaned and tightened them. Bikes running now, but i think the pump is intermittent. Any advice about a replacement ? Thanks folks
  13. I have the omron relays ( after all the great advice here ) I changed the fuel pump one and the fuse . The 30amp fuse was a bit melted but still functional unrelated i think., changed that too. ( got a maxi fuse ready to fit.) Battery on charge now so gonna have another go today. If i remove the sidestand relay will that indicate its that or not ? ( sidestand switch )
  14. Thanks, 2003
  15. Hi folks. Stopped for fuel today after a ride, bike cranks but wont start. I notice the fuel pump noise is not there. I have changed the relay and fuse, i am stumped now. Any thought ? Cheers
