TimB MV
    04’ LeMans v11
TimB MV's Achievements
Guzzisti
Guzzisti (2/5)
6
  1. That’s scary!! Ha ha!! Great Pic!!
  2. Roger That Pete.. I did my research and quickly came to the fact this is not a job I should tackle.. I’ve been able to work on smaller issues..trace and fix an oil leak.. diagnosed and replaced the stador and regulator on my own.. but this is a job for a professional!! I thank you for your input.. this forum really helps people!! Stay safe!!πŸ€™πŸ»πŸ€
  3. Thanks Pete.. You seem pretty sure... On the difficulty scale.. how bad is it to replace the clutch?? I’m a marginal mechanic.. but I live on an island and I’d have to ship/transport it off to get it to a shop! Any tips/recommendations??πŸ€™πŸ»
  4. I had just returned from a small vacation, I want to roll my v11 Le Mans out of my garage. I was holding the clutch in, it was in gear I only rolled a few feet and stopped. I clicked it in neutral and it rolled back just fine. After starting the bike in neutral and letting it warm up, I put the bike in gear and it stalled. Put the bike back in neutral, and it started up again. This time after putting it in gear, it struggled to start going. Once the bike was moving it seem to be OK. Well riding it, I could feel a strange feeling in the clutch handle. The bike was not running very smooth at first, but seem to work itself out as I rode it around the block a few times. I got up this morning and wanted to check a few things. I got on the bike, without starting it, and holding the clutch in. I was rolling it back-and-forth there was a new clicking noise coming from below. I’m not sure if this is coming from the clutch, or the gearbox. Does anybody have any leads to where I might start looking at this problem. I’m not sure I wanna write it very much, even though it did ride fine once it warmed up. I don’t want to do any damage to my engine. Any help would be greatly appreciated!!
  5. Problem Solved... I had a short/melted harness connection between stator and regulator... I decided to replace both components... Everything is back up and running.. I’m grateful for this forum and other outside help.. and the patience to work the problem and fix it on my own! I know that much more about my bike now!!! Safe riding everyone!! πŸ™πŸ»πŸ‘πŸ»
  6. Did you experience the same sort of power loss?? Om thinking of just replacing it with a new one... Thank you for the suggestion of soldering it... I’m a woodworker/carpenter!! Not mechanic.. but I’m learning thanks to all of you!!πŸ€™πŸ»πŸ‘πŸ»
  7. Trying to upload photos.... This seems like the obvious cause now.. but I just hope it didn’t happen while investigating it... Anybody else have experience with this.. Text me for Photos.. 603-209-1875 πŸ™πŸ»πŸ€™πŸ».. Thanks everybody!!
  8. Good Morning All... So I’ve replaced battery and relays... This morning I had time to uncover my Stator cover to check connections.. I was careful doing so... and I found a broken connection. I certainly don’t think I caused this while removing the cap!!
  9. Relays ordered... harder to find than I thought!! Going to follow up on others advice as far as the ground and stador wires soon.. want to be able to focus on what I’m doing.. the island of Martha’s Vineyard is a little crazy this time of year!!πŸ™πŸ»πŸ‘πŸ»
  10. Should I replace all relays and see if that is the next logical culprit? i figure.. replace one.. order all 5.. Replace all 5.... they are the same correct??πŸ€·πŸ»β€β™‚οΈπŸ‘πŸ» Is there an order of what relay does what?? Ill look it up.. but any info is helpful!!
  11. Good evening my friends!! All is well on MV. Test of the old battery and replacement of a brand new one is the solution!! NOT!!😑🀬😒 The Odyssey battery came fully charged at 12.78 on the multimeter. Ready to go out of the box!! I installed it and was feeling pretty good about things! Fired right up... sounded powerful.. went for a test ride! Then.... I tested it after the ride and it went from a 12.78reading to a 12.46 reading.After only a 15 min ride or so. Losing charge somewhere still! So... where do I go from here... Lose connection, Stador coil, ???? Fuses are fine... nothing smoked...πŸ€·πŸ»β€β™‚οΈ Any other diagnostic things I can do?? I appreciate the help from you guys.. Stay safe and talk soon!!πŸ€™πŸ»
  12. You all are awesome... I will do my due diligence as the bike deserves!! Ill check back soon with updates!!πŸ€™πŸ»πŸ€˜πŸ»
  13. Yup!!! Try trickle charge? Why would a new battery just die like that... could something drain even when key is out??
  14. I’m reading around 12 or 13 GEI Relays now
  15. Great Pictures by the way!!πŸ€™πŸ»
Γ—
Γ—
