TimB MV
Everything posted by TimB MV
Thatโs scary!! Ha ha!! Great Pic!!
Roger That Pete.. I did my research and quickly came to the fact this is not a job I should tackle.. Iโve been able to work on smaller issues..trace and fix an oil leak.. diagnosed and replaced the stador and regulator on my own.. but this is a job for a professional!! I thank you for your input.. this forum really helps people!! Stay safe!!๐ค๐ป๐
Thanks Pete.. You seem pretty sure... On the difficulty scale.. how bad is it to replace the clutch?? Iโm a marginal mechanic.. but I live on an island and Iโd have to ship/transport it off to get it to a shop! Any tips/recommendations??๐ค๐ป
I had just returned from a small vacation, I want to roll my v11 Le Mans out of my garage. I was holding the clutch in, it was in gear I only rolled a few feet and stopped. I clicked it in neutral and it rolled back just fine. After starting the bike in neutral and letting it warm up, I put the bike in gear and it stalled. Put the bike back in neutral, and it started up again. This time after putting it in gear, it struggled to start going. Once the bike was moving it seem to be OK. Well riding it, I could feel a strange feeling in the clutch handle. The bike was not running very smooth at first, but seem to work itself out as I rode it around the block a few times. I got up this morning and wanted to check a few things. I got on the bike, without starting it, and holding the clutch in. I was rolling it back-and-forth there was a new clicking noise coming from below. Iโm not sure if this is coming from the clutch, or the gearbox. Does anybody have any leads to where I might start looking at this problem. Iโm not sure I wanna write it very much, even though it did ride fine once it warmed up. I donโt want to do any damage to my engine. Any help would be greatly appreciated!!
Problem Solved... I had a short/melted harness connection between stator and regulator... I decided to replace both components... Everything is back up and running.. Iโm grateful for this forum and other outside help.. and the patience to work the problem and fix it on my own! I know that much more about my bike now!!! Safe riding everyone!! ๐๐ป๐๐ป
Did you experience the same sort of power loss?? Om thinking of just replacing it with a new one... Thank you for the suggestion of soldering it... Iโm a woodworker/carpenter!! Not mechanic.. but Iโm learning thanks to all of you!!๐ค๐ป๐๐ป
Trying to upload photos.... This seems like the obvious cause now.. but I just hope it didnโt happen while investigating it... Anybody else have experience with this.. Text me for Photos.. 603-209-1875 ๐๐ป๐ค๐ป.. Thanks everybody!!
Good Morning All... So Iโve replaced battery and relays... This morning I had time to uncover my Stator cover to check connections.. I was careful doing so... and I found a broken connection. I certainly donโt think I caused this while removing the cap!!
Relays ordered... harder to find than I thought!! Going to follow up on others advice as far as the ground and stador wires soon.. want to be able to focus on what Iโm doing.. the island of Marthaโs Vineyard is a little crazy this time of year!!๐๐ป๐๐ป
Should I replace all relays and see if that is the next logical culprit? i figure.. replace one.. order all 5.. Replace all 5.... they are the same correct??๐คท๐ปโโ๏ธ๐๐ป Is there an order of what relay does what?? Ill look it up.. but any info is helpful!!
Good evening my friends!! All is well on MV. Test of the old battery and replacement of a brand new one is the solution!! NOT!!๐ก๐คฌ๐ข The Odyssey battery came fully charged at 12.78 on the multimeter. Ready to go out of the box!! I installed it and was feeling pretty good about things! Fired right up... sounded powerful.. went for a test ride! Then.... I tested it after the ride and it went from a 12.78reading to a 12.46 reading.After only a 15 min ride or so. Losing charge somewhere still! So... where do I go from here... Lose connection, Stador coil, ???? Fuses are fine... nothing smoked...๐คท๐ปโโ๏ธ Any other diagnostic things I can do?? I appreciate the help from you guys.. Stay safe and talk soon!!๐ค๐ป
You all are awesome... I will do my due diligence as the bike deserves!! Ill check back soon with updates!!๐ค๐ป๐ค๐ป
Yup!!! Try trickle charge? Why would a new battery just die like that... could something drain even when key is out??
Iโm reading around 12 or 13 GEI Relays now
Great Pictures by the way!!๐ค๐ป
Same thing... Fires right up from a jump... runs for 1 min or two at idle... then seems to choke out... still sound like relay?? Or something else??
Roger that!! Ill move #2and#3... see how she goes,! Ordering a new set of 5 is best solution?
Canโt upload file.... can you text me?? Iโll send pics that way...603-209-1876 No stress if you canโt doc....๐ค๐ป
Can you point out the location of the relay?
AWESOME... Iโm looking into it as we speak!! it does have a brand new Odyssey Extreme Series battery!!
Iโm looking for any leads into this problem please!! Woke this morning to a dead battery. Bike has been running in top performance. Battery is new last year. I jumped it.. fired right up... Rode it for 10 minutes or so and noticed my rpm tack was not registering. The motor sputtered and quit about 2 min later. Bike world not turn over... jumped again and idled perfectly.. as soon as I put it in gear it sputtered and quit again. I have it back home and looking to trouble shoot this!! Brand new battery from last year... I ran the bike just two days ago and it was just fine... Any help is much appreciated! Tim B on Marthaโs Vineyard jrbeg@hotmail.com
