Everything posted by po18guy
And a round fin at that! Those rods look a little Ti to me.
Many EU parts are labeled as to plastic type. However, this may be a small part that is not labeled. Basically, if acetone or ketone will melt the surface, it is bondable by various adhesives (J-B Weld, various epoxies etc.) If it is one of the slick "Polyethylene" plastics, virtually nothing will bond to it. It is a thermoplastic and some form of heat welding is the only manner of repair. For small cracks in non-polyethylene plastics, a drop of the horrendously dangerous methylene chloride/dichloromethane will almost instantly bond it. It is a very powerful solvent, thinner but considerably heavier than water. It is so dangerous that it is used to decaffeinate coffee beans! It "used to be" in all of the good paint strippers. So, beware! Just last evening, fixed a freeze-cracked polycarbonate Gardena garden hose manifold ("Hergestelt in Deutschland") with a drop or two. Repaired the tiny crack instantly and saved me $50. Priced at $199/5 gallons, it is barely more expensive than gasoline.
Riding Breeches / Riding Jeans?
po18guy replied to LowRyter's topic in Special place for banter and conversation
I have a couple of pairs of Israeli made Brosh riding jeans, and two pair of their "cool pants" cargo pants. Brosh uses removable Kevlar panels in the hip/buttock area and T-Pro knee armor. Unless you are really tall, they fit nicely. The jeans are armored jeans, simple enough, but the cargo pants are more useful and cooler in the heat. They really believe in the Kevlar and are great folks to work with. https://brosh.com/ -
That's the flat crank version. Basic 4-cylinder inline sound. The cross plane, now that's Italian! The first 14 seconds of this video are the cross-plane engine warming up. I suspect that only tin ears dislike this sound.
Well they seem to have learned the art of machining quieting ramps and other changes into the cam lobes and valve train. The early Guzzi's valve trains sounded more like VW Beetles than a motorcycle. Actually, I have a '73 "Super" Beetle (Ha!) that would sound much better with a V11 motor! Hey, wait a minute...
Having had a disturbing number of PC545 "clicks" when far away from home - even after conditioning - I recalled that my Kawi had a Yuasa AGM that worked just fine for 9 years. So, what's a couple of pounds on a 550 pound bike? I can skip a meal or two and lose more than that. So, the AGM is in and works as expected. If one has an aversion to Yuasa, say because a Yuasa let them down back in the 70s, there is yet another battery maker in Reading, Pennsylvania: DEKA (East Penn Mfg.) They also make an two or three AGMs for Guzzis.
I have noted that Staintunes give it a distinctly basso profundo tone. Would like to have a Morini 1200 for comparison, but they are only 87º and are immoral to import.
Here's a night shot of the B/LT setup. Also, another shot from about 30º to the right, showing that the light, for me, is still plenty visible.
They are unbelievably inexpensive. I bought 5 for less than $5, but had to wait for the boat from China. Surprisingly, the first one is fine at the 2-year mark. They have a blink-rate adjustment screw between the pins, and a tab so they will pop into the OEM rubber mount. These at the Amazon link are horrendously expensive - almost $3 ea., but you get five of them tomorrow. https://smile.amazon.com/Adjustable-Electronic-Flasher-Relay-Signal/dp/B07JYY6H3W/ref=sr_1_13?crid=1E2W3F33YJIFM&keywords=adjustable+led+flasher+5x&qid=1650760934&sprefix=adjustable+led+flasher+5%2Caps%2C132&sr=8-13 So, a monkey paw trap full of spare Osrams and flashers for the journey!
I have the adjustable blink rate unit for the signals and will use one of the strobe flashers for the 2nd brake light. Unsure which. Would like one that strobes three times then solid. But anything that will stop the horrible Seattle-area "drivers" from killing me is OK with me.
There are many LED strobe units available - all somewhat different as to flash rate and number of flashes. They are less than $2/each if you order from AliExpress and are a bit patient. Somewhat more from eBay and Amazon. The second LED brake light was a snap to wire, as the OEM tail light connectors are the "flag" type and there is plenty or room beside the crimp to solder (or de-solder) the small gauge LED wires alongside. Rather than drill holes, I routed the wires through one of the grommets under the license plate and behind the middle inner fender plastic and to the tail light connection. I ran them inside a silicone rubber hose so that the 1-inch exposed section is well protected. As to the narrow focus of the typical LED beam, I aimed the lower brake light where drivers' eyes would be in the bright spot.
Well, not today, but have made a few mods on the rear - to save my rear. First an LED taillight. Came with a smoke lens, but I wanted something a little brighter. So, I found a $10 eBay Ducati Monster rip-off taillight and used the clear lens. Then fabbed up brackets and added a cheap universal LED brake light atop the license plate. I have this strange aversion to being killed by a somnolent driver. Anything will help, and I have a couple or three LED flasher units (flash 3X then steady) that I can connect to either of the brake lights.
Hollow spokes. Some plug the casting holes to exclude dirt and debris.
I detected a certain sense of entitlement in dealing with them. Hey! A member co-op!
- 38 replies
- 1
- shop stand
- workshop stand
(and 1 more)
Tagged with:
The Teo Lamers engineering problem is that the pivot should have been about 2" higher which would have allowed an equally longer stand to be more upright when it contacted the ground. Thus, one would be rocking the bike more back and up instead of more up and then back. But, the price was right (bought by former owner) and it is very good for maintenance etc.
- 38 replies
- shop stand
- workshop stand
(and 1 more)
Tagged with:
As to images, are you using Imgzeit? No problems there. 0.92¢/month. I have the Teo Lamers center stand on my V11 (came with it installed). No foot lever at all and darned near impossible to deploy as is. The pivot point is too low, thus the initial lift is more up than back. Ouch. However, if you roll the rear tire onto a 2X6 board laid flat, it is then fairly easy to deploy. The problem is that the rear tire is held by the board. Placing the board just right will have it just roll off the board when fully deployed.
- 38 replies
- shop stand
- workshop stand
(and 1 more)
Tagged with:
Hear, Hear!!! Super-easy, super fast and super options for copying and pasting.
Yeah, pull one gear and rotate the crank until the marks line up. If the plugs are in, it prolly ain't at TDC. In any event, after the install, rotate the crank verrrrry slowly, listening and feeling for interference.
Calls for a window in the timing case.
Before and after sound clip!
What have you done? We will soon see!
Does the tank have a "Lift and separate" bra?
Being the prayerful type, I will send some prayers for your #2 son.
