Everything posted by po18guy
Since the EU clamps down on noise, intake noise is also targeted. A cross section of the passages in the lower box will determine if opening the upper will net an gain. I suppose you could pod filter the throttle bodies, but that would undoubtedly open Pandora's airbox.
With a LeMans fairing, one could conceivably run the intakes forward of the engine, maybe even into clean air. Expensive surgery though.
I note that Hiflofiltro has gotten good reviews from his channel, based on construction and materials, particularly filtering media.
Here it is:
This fellow dissects oil filters on a weekly basis. Some filters have stamped louvers in the core and he has opened some new filters in which the louvers were improperly stamped and thus only partially open. This would certainly greatly restrict oil flow.
The fairing does not quite match the tank and sides. I'm thinking a period Pichler or similar aftermarket fairing, as they were hot poop in the 80s. Quite possibly a 120 crank, as it also has the calipers to the rear.
fuel pump and filter Resurrection of 2004 Ballabio
po18guy replied to LangleyMalc's topic in 24/7 V11
"Might" consider coating the tank to preserve the graphics. Unless they are already bubbled. -
Eternal rest unto a him!
is KTM going to the gallows?
po18guy replied to p6x's topic in Special place for banter and conversation
Chinese ownership: Benelli, Moto Morini, Pirelli. Manufacturing/Tech agreements: KTM and who else? Chinese money has been the quick fix, but you might as well give them the company as the CCP will steal everything it can. Remember that "China" is a 75 year old, amoral nation, where the national motto is 可以的话作弊 (cheat if you can). -
Both tight may indicate that the engine was not as cold as when you set them.
Fellow on the Kawi forum is looking at a 2-valve Norge today. "And now for somthing completely different..."
Oh. Maybe went bungee jumping? There is sound advice to swap the springs from the seat release under the tailpiece with the fast idle spring. The seat release can use more pressure and the fast idle, less.
Struggling to separate the two halves of the drive shaft
po18guy replied to Molly's topic in Technical Topics
Safety third! -
Guzzi V11 Le Mans 2000...Starting issues
po18guy replied to David Sandbrook's topic in Technical Topics
Not only keeps you going, it hopefully gets you going. These really should have been the sealed 'AMP' connectors, but that's for another life. -
Had a poor > no start issue. There is a multi-pin connector on the left front of the frame from the regulator/rectifier wiring loom. It is not a sealed connector and is exposed to rain, road spray, soap, etc. Separate it and clean the terminals on both sides using a pipe cleaner soaked in contact cleaner, denatured alcohol or similar. Probe as far into the connectors as you can, then use air or canned "duster" to blow everything out and dry it. Then, probe and swab the contacts using a fresh pipe cleaner with Caig DeoxIt on it, then plug and unplug 2-3 times to ensure good contact. I had no problems since. A check of running voltage with a multimeter will let you know if all is OK. Mine was 14.02V, which is "acceptable." -
Personal Aircraft...
po18guy replied to KINDOY2's topic in Special place for banter and conversation
But NOT with Tyco relays!!! Oh crap, the yaw control is intermittant. Let me just pull to the side of the...... -
So now when I shoot them overhead I can be charged with murder rather than vandalism? -
I converted to LED, using Taiwanese units sold by PERaccurate on eBay. A bit of stuffing to fit in the bucket, but it all eventually fits in. They are rotatable to customize the beam pattern.
