po18guy
    29
Everything posted by po18guy
  1. Was squinting at the wheels. My bad.
  2. Sorta Zook is that?
  3. Charging a new Yuasa AGM as we speak. If I read the Odyssey info rightly, it looks to be about 10-11 years old. I get about that out of Yuasa AGMs in my Kwackers and this one was US $79 to my door.
  4. There is apparently much cash chasing the hipster café trend. Consider that most of the US options are either 175-350cc Hondas, or Hardley bobbers.
  5. Auction started at $100. Now 43 bids have it up to 8K!?! https://www.ebay.com/itm/174740324615?hash=item28af55c107%3Ag%3AbY8AAOSw81Zgf2FE&LH_ItemCondition=3000|1000|2500 Nostalgia and pockets run deep.
  6. po18guy
    Decent Tune-up
    For those times that I want to go ghetto, I also made up some QD spring clips. Those times would be when confronted with the veritable plethora of leads competing for space at the battery terminals.
  7. Sadly, I do not have any elderly uncles who have either car.
  8. po18guy
    Decent Tune-up
    I'm getting to the point where all things wiring related are simply "Plug-N-Dismay."
  9. po18guy
    Decent Tune-up
    (In best Elvis voice) Thank ya very much! I'm on kind of a roll with this electrical stuff. For the ever necessary voltage check via the SAE charging cable:
  10. con·tra·dic·tion| ˌkäntrəˈdikSH(ə)n |PHRASES contradiction in terms a statement or group of words associating objects or ideas that are incompatible: “Italian electrical system" is a contradiction in terms.
  11. po18guy
    Decent Tune-up
    Given the fine direction provided by the IllumiGuzzinati, here is the TPS harness all dressed with multimeter connectors attached and the yellow terminated with liquid electrical tape and tucked into the harness.
  12. While you are poking around, the ground to the trans is on the opposite side - just trace the fat black wire from battery to the transmission casing, pop it off for a bit of a clean, then (if you have some) CAIG DeoxIT will clear out the oxidation and ensure a better connection.
  13. Still have the 1977 brochure.
  14. Remember the wedge garage of the Triumph TR-7 and TR-8?
  15. po18guy
    Decent Tune-up
    You'd think a purpose built MG harness breakout would have only the two necessary wires? Are there earlier or later TPS units that require a third (ground?) wire? I have two plain purple and a single plain green. Will check after a period of dormancy.
  16. Some confusion - my bad. This is the fairing "design" I am commenting on. As to aerodynamics, the Subaru XT6 proved the slippery does not necessarily mean beautiful.
  17. po18guy
    Decent Tune-up
    Got my Casper's TPS breakout harness. How do I terminate the green and purple wires?
  18. That's odd, the VIN on my '04 is, in part: KRAKEN" Anyone know about that?
  19. Valve covers and porkchops remind me of a verse in Flash "N" the Pan's song Media Man: "Copper-colored hair..."
  20. Am guessing that the slave might be the weak link. Either quickly in my case, or over time as in yours, air is seeping in. First time in history that something leaks into a Guzzi.
  21. Dad paid his dues with John Mayall's Blues Breakers, along with Coco Montoya - another great.
  22. Heat would seem to be a factor. I had just shown some racer kid in a Jetta up from down on I-5 in Seattle when the lever stopped returning and the clutch drag followed. The M/C and some of the line clearly heat up, given their location. The reservoir was full to the top - which I do not think was the case prior. Did the expanded fluid feed its way back into the reservoir and a bubble of air filled the void at the slave? As the fluid cools, it shrinks. Could that vacuum be pulling some air in? I suppose. Someone fully familiar with fluid dynamics and the intricacies of the MG system might better explain.
  23. Walter Trout is up there. Had to re-learn guitar after an almost failed liver transplant. And a duo with his son Jonathan Trout. Dad taught him well.
  24. The same. Being a lifetime anomaly, turning 69 this year, I want lower bars and more rearset pegs for my '04.
  25. When I checked, the reservoir was filled - no air space. So, I drew some fluid off and ran through a few cycles. Nope. Surely, replacing the entire hydraulic system and clutch will fix it but... Here is the parts schematic from This Old Tractor: https://www.thisoldtractor.com/mg_manuals/spare_parts_catalog_v11-sport_v11-lemans_v11-rosso-corsa_2012-02.pdf Takes a while to load as it is a graphic and text-rich PDF. It seems that, lacking a fluid leak, air in the system would be the only likely (not the only possible) cause of the behavior. OP bridge, have you change out levers for aftermarket? Just curious.
