Everything posted by po18guy
Well, McDonald's sells billions of unacceptable burgers and, hate it or hate it, Foster's sells an awful lot of liquid.
Sweet. I can almost hear Carly Simon singing "Anticipation" in the background.
Well, at 5300 miles everything seems pretty good. Being a perennial rider of twins, I am sensitive to throttle imbalance. It seems that Big Red does quite well in that regard. New Iridium plugs already and the air filter is more old than dirty. The valves are not terribly noisy, which is a concern… ;-)
As to idle speed adjustment, I backed out the left throttle plate stop screw a turn or so. No change. Applying "slight" counter-clockwise (anti-clockwise) torque to the cable attachment "spindle" atop the left throttle body slowed the idle. Thus, I went to the other side. That screw is not as out-in-the-open as the left side, but it is doable. However, it was rather tight from not being moved for 15 years as well as the electrolytic activity between the steel screw and alloy throttle body. The Eklind 2.5mm ball-end wrench was a so-so fit, slightly on the loose side to suit me. Scanning my eclectic assortment of otherwise useless sockets and bits, I spied a WIHA T10 hex bit. Torx bits have essentially the same contact surface as a standard hex wrench, so why not give it a try. Aha! And, using it with a Pittsburgh (Harbor Freight) right angle ratcheting screwdriver (an exorbitant $2.99) did the trick. Idle now being too low, I brought it up to 1050 +/- using the left throttle body screw. All is right with the world once again** **A few notable exceptions, but all-in-all rather good. *
Search "Hugger" as awhile back, one seller thought it was a rear hugger.
I'd kiss you but, well, you know... Now, I have to adjust the throttle cable slack, as it won't allow the throttle body to close sufficiently. Easy enough.
But I sneaked out and put a few miles on the Ballabio today! I think the engine is breaking in/loosening up, as the idle RPM has risen to 1400 or so. Gotta look in the manual and see how to lower it.
We could use some global drying here in Raintown USA. Something like 34 days straight. Had three days of sun, but it just could not stand it and began raining again.
SOLD - 2003 Moto Guzzi V11 LeMans - San Francisco area
po18guy replied to jmardy's topic in Personal Ads
And Champagne has quite a bit of silver in it... -
Killer deal! I would almost see if someone might want to make a cast of it or measure the coordinates for a CNC duplicate. We're all one get-off from needing another timing cover.
po18guy replied to chamberlin's topic in 24/7 V11
D'Oh, probably, dang it! Too pricey for the work it will need. Crappy header wrap is coming undone, and I see the rear master cylinder shield is gone. What else? -
Another mysterious Scura, $9K, in Sacramento. https://sacramento.craigslist.org/mcd/d/las-vegas-2002-moto-guzzi-v11-sport/7071357568.html -
I see that banana-swingarmed "newer and more exciting" spouse in the background... -
Would try it myself, but DW assures me that my obit would be the last thing posted here.
Phil, getting closer and closer. Wondering if the whole mess would fit better in a long frame? Nevertheless, we use what we have.
And why not? I was looking at the Shiver 750 and then the 900, but Mandello called.
Dunno of any of the Yanks are using the Yuasa YUAM6215L / YTX15L-BS AGM battery. Last I hears they were still made in Reading, Pennsylvania. $73 shipped via Amazon. I was grumping about the Yuasa AGM in my Kawi going bad this winter - then I checked my log book and noticed that it was 9 years old. Well,, OK then.
Zero mile Greenie, $44??? OK, it's 1/12 scale, but still tempting. https://www.ebay.com/itm/MOTO-GUZZI-V11-SPORT-NEWRAY-DIE-CAST-1-12-NEW-IN-BOX-VERDE-LEGNANO/283777269881?hash=item4212718079:g:FEwAAOSwJFVeQGVg -
Yeah, pretty soon, we'll need our own forum! Oh, wait...
Searching for parts, this one just turned up in Texas. Starting bid $3,500. Appears to have a Corbin seat and comes with a pricey old-school café fairing extra. https://www.ebay.com/itm/2000-Moto-Guzzi-V11-Sport/124086408955?hash=item1ce42056fb:g:t18AAOSwEWpeSczX -
Sadly, we are such a niche within a niche market that only the old-school mom and pop dealerships had knowledge or concern about the "historic" bikes like the V11. I have had no contact with Optimum, but based on their site, it appears that they cater primarily to the hipster V7 Racer/V85 crowd.
Easy! Sign up at Imgzeit for $11/year/ Super easy to use, add or delete images and was developed by a forum member. You'll never look back. Dang! I have the blue tail and was looking for a red one.
Well, the side covers still say V11 Sport. It's the year (long frame) and sub-model that make the difference. maxv11, what color is the tail fairing?
According to Yelp, Portland Aprilia/Guzzi is DOA. https://www.yelp.com/biz/aprilia-moto-guzzi-portland-portland I think that gstallons' suggestion to contact Barnett is excellent. They make "one-offs" http://www.barnettclutches.com/cables.html
Maybe Paine Field? I would still lean toward aircraft welders, as they are under more scrutiny. And, leave it to Guzzi to make the engine a stressed member, but only via the timing cover(?) Back to Jeep: they did the motor mount on the timing cover of their technically advanced OHC 230 six cylinder in the early 60s and had nothing but oil leaks. Solved by using block mounts but the die had been cast, so to speak.
