Everything posted by po18guy
Well, mine would have to actually start first... The early models, although not really lighter, have a cleaner, more compact look. The longer ones have that cantilevered fairing - good thing I'm sitting behind it. LM plastic always struck me as bulbous. Would like something in between, but I'm playing Goldilocks here.
I learned this from Kevin Cameron's writings in Cycle Magazine. Reciprocating engines do not have a 100% consistent crankshaft RPM. At each firing impulse, the cranks accelerates slightly and on each compression stroke of each revolution, it slows a bit. If you could graph it,the variation in rotational speed could be seen. How this manifests in the V11 would seem to be: the transmission input shaft runs through the clutch disc via a splined connection. There is necessary clearance in those splines so that the clutch disc can freely disengage. Engine out of the bike, you can rattle the input shaft in the clutch disc, even though it is a relatively tight fit. Each firing impulse - especially at idle - clanks those clutch splines against the input shaft splines - first against one side of the splines as the crank accelerates, then against the other side as the crank slows on compression stroke. We are talking only a few thousandths clearance here, but it does make noise, especially with dry clutches in a notice: "bell" housing. Wet clutches do not exhibit this nearly as much, as the splines are cushioned by oil, whereas the Guzzi splines are dry. The same to a lesser extent with the transmission gears engaged by the input shaft - they also make some noise, but they run in lube, which cushions and quiets the blow. There is a solution, but it would involve a heavier, more complex clutch disc with spring-loaded "scissor splines." Not worth the cost and effort. Pull the clutch lever in and the clutch disc and transmission input shaft stop rotating and thus the "spline-banging" stops. Singles and twins are worst at this, as their crankshaft accel/decel cycles are more violent. Multi-cylinder engines have smoother crank rotation speeds. Somewhat related, years back, Honda had split cam drive gears with a preload between the two halves of the gear to remove the backlash between the gears. This reduced noise - IIRC it was on their 750 V4 Interceptors so that it could pass noise laws. It also reduced dynamic stresses between the gears. Here is a web article which explains far better than I can. https://www.eng-tips.com/viewthread.cfm?qid=437206 The third answer is from someone in the aero industry: "tbuelna (Aerospace) 1 Apr 18 01:09 It's called a scissor gear. They're used on engines with cam/accessory gear drives to reduce dynamic tooth loads due to torsional oscillations. In the case of your Toyota cam gear, the torsional oscillations are produced by the varying forces acting on the cam lobes. There is a moment in one direction as each leading cam flank pushes a valve open, and a moment in the opposite direction as the valve spring pushes against the trailing cam flank during closing. Conventional gears (not scissor gears) require some amount of backlash at the mesh to prevent interference. When there is backlash, reversing torsional oscillations will cause high dynamic contact loads on the gear tooth flanks at the mesh. These high dynamic tooth contact forces also produce noise. While a scissor gear can reduce dynamic tooth loading and noise, it also involves some mechanical losses. You'll see them used on other engines like Cummins diesels and Honda motorcycle engines"
Exact same noise as in my 2004 Ballabio. The rattle with the clutch disengaged is dry clutch rattle. When idling, the rattle strikes me as the input shaft /splines/gears rattling from the rapid acceleration/deceleration of the crank between firing impulses. The Red Line trans lube "Shock-proof" pretty much tells the story.
Stepping stone Moto Guzzi in the works? powered by an Aprila parallel twin....
po18guy replied to p6x's topic in Newer models
Thanks for that. RIP Moto Morini. -
A little too cold...
po18guy replied to activpop's topic in Special place for banter and conversation
I blame Iceland splitting in two for all of this. -
Moto Guzzi has made virtually every imaginable engine type. Sure, they are known for the Vs, but like H-D you then live or die by the Vs. Moto Morini has a cracking 1200 87º V-twin, but Euro-7, 8, 9 emissions killed it for the time being. So, what do they offer? A 660cc parallel twin. So, who might make that engine for such a small company? And an Aprilia-engined Guzzi would be 10K+ how entry level is that? Where facts are few, rumors are many. -
North of you, we are in the same boat. Will supposedly rise to the 30s or so over the next day or two. -
The Guzzi of rotary winged aircraft?
po18guy replied to po18guy's topic in Special place for banter and conversation
Crop dusting all that grain, one's mind begins to think about what could be made from all that grain. On a hot and dusty day. Or a rainy day. A gray day. Any day... -
Somehow, YouTube's algorithm popped up with this 1960s Soviet designed twin radial-engined helicopter: the Kamov Ka26. Normally a utility and crop-dusting craft, the radial engine thunder and the whine of the cooling fans on the shrouded engines lends an almost Guzzi-like, visceral quality to it. Pilots seem to love it, as it is very benign handling for a 'copter. Apparently, if you lose an engine, you simply have a slower craft.
Oh. That is a rather big flaw as headlights go. Since they are now rare Italian works of art, I suppose that 2 bills is not all that bad.
What is wrong with the original?
If it is to be a commodity bike, any Honda will do and likely has the best resale. It is best to be passionate, to focus on the perfect moments, be capable of performing maintenance and have something in your wallet to own a Guzzi. There are many prior Guzzi owners. How much passion does your friend have to invest?
Kam-bodia?
Like all risky or dangerous occupations, you ride long enough, you have tales to tell. The survivors, anyway.
Whoa! This exact thing happened to me about 1970 while cruising the local Friday night traffic loop with a bald rear tire. 1966 Yamaha YM-1 305cc. Partially dismantled the bike on-site and hauled it home in the trunk of my buddy's '64 Chev Impala. Yes, trunks were that big and bikes that small back then. Still have the bike. The wrench? 5/16-3/8 open end. It must be somewhere in the garage.
Merry Christmas from left coast USA. Something on this earth has to make sense.
We own rider's bikes much more than collector's bikes. There is always the odd Daytona or even an MGS-01 sprinkled here and there for professional oglers. The rest of us enjoy that perfect road at the perfect time on what is, then and there, the perfect bike.
An oddball among oddballs.
How about an HMB magnetic clutch safety switch? Even if the sensor had to be drilled and tapped onto the clutch lever perch. That microswitch and tiny little polymer cylinder sitting there next to a greased lever pivot is, well, asking for trouble. And a coiled cord from bar to frame to lessen strain on the connector, whether bullet or AMP style. Heck I might assemble one myself. Pushing these behemoths on level ground to bump start them is more than a pain.
Tesla, at the very least, needs to install a "Guzzi Avoid" app. in their killer machines.
Old guy owner. Bad wrists, knees and lower back. Just guessing....
Yes! Those! And a few Italglish tossed in.
