Everything posted by po18guy
We might just improve the breed to where we can forget those special Italian words we have learned. Nah...
A group US order? The switch is small and light, so many may will fit into a reasonably sized box. Example: I bought two helmets from FC Moto in Germany. That huge box and two spare shields were sent via DHL to the west coast of the US for $43. So, the shipping can certainly be far less than what is listed. If we can come up with a group order, perhaps HMB Moto can moderate their shipping cost.
While the Chinese make some pretty good looking stuff, I don't mind paying for the British Ti. As it is written: "You pays your money and you takes your choice. - Aldous Huxley
For future needs, check RaceTi for titanium, and RaceBoltUK in England for aluminum, stainless and Ti fasteners. Great people to deal with.
If you get any air in the line, like trouble with disengagement or a dragging clutch, I installed a bleeder banjo bolt on the clutch master - the highest point in the system. Then bled it from both ends. Been fine ever since.
I paid $175 (late last year?) at the local multi-brand dealer but we are in inflationary times.
For what it is worth. I live in rainy town, so I wondered who deals the most with wet roads. The Brits are certainly top 5 if not #1. So, to Avon I have gone. Their bias ply tires served me well on my "collector vehicle" EX500, and so when I picked up a nail in the rear of the V11, I went with the Avon Spirit ST. Dual compound, possibly front and rear - rear for sure. When the front Michi is gone - I suspect its geometry is not ideal for the V11 - I'll mount a Spirit ST on the front as well. The reviews mention that they even work for track days. NOT a concern with me. https://www.avontyres.com/en-us/tyres/spirit-st
clean, low mileage Coppa Italia for sale with titanium MG pipes...
po18guy replied to fastaussie's topic in 24/7 V11
Here is his YT vid on an '03 V11 he restored and sold. -
An electric regulated by TYCO relays? Ummm...
Aha! I recently solved a low battery voltage issue by cleaning and Deox-It-ing the multi-pin connector between the rectifier and the main wiring loom. It is rather exposed to weather (being about one foot below the clutch switch bullet connectors on the left side). It gets wet when washing the bike or riding in the rain, and the water sits and corrodes the contacts. So, off to the bullet connectors. NOTE: I had thought that clutch lever gunk had plugged the tiny, easily lost plastic cylinder which operates the clutch safety microswitch. After cleaning and testing, all was fine, but the problem persisted. So, bullet connectors and then the relay if needed. Got those in stock, fortunately.
I have an occasional no-start issue with the clutch microswitch. It bump starts fine (ugh!). Based on the diagram, am beginning to suspect relay #1. But, is it still relay #1 on 2004 models?
OK, so other than OEM, what have you done? What survives?
Did a valve adjustment. And thanks to KINDOY2, I have some spiffy head guards. While I was polishing them, I also brightened up the valve cover bolt heads, so I fully expect to dazzle a few motorists in today's sun. In search of "approved" muffler hangers.
All I know is that Prince should have ridden that bike in his Purple Rain vid.
po18guy replied to p6x's topic in Newer models
Guzzi is reportedly developing a V-twin shaped battery for future models. -
The stealth color is so that none of your riding buddies will know that you have the shifting advantage.
Was owned by Ben... Ben Messtwith.
The learning curve is steep. Clutch: As to the clutch, I recently had trouble with air in the line. Removed the rear wheel so that my fumble fingers could get in there. Most do not have to, but it is a bit of a wrestle to reach the bleeder screw. I thought, the line goes upward - all the air is at the master on the handlebar. So, I installed a bleeder banjo bolt at the clutch master and all is happy motoring since. Oil: Inside the oil sump is a screen. Since you might be in there, good time to check it and clean it, since the bike has only been ridden 1,100-1.200 miles per year or so. Since the oil filter mounts top up, I fill the filter with oil when installing a new one. Just that much less time for pressure to build once you start it. I use HifloFiltro HF551 filters, which are generally pretty well regarded. Use a good oil for flat tappets (like Harley oil, diesel engine oil or similar) with enough zinc to protect your cam. Shifting: A couple of "post-Guzzi engineer" members here have brainstormed a few things for shifting. First - in your case - would be the bolt-on "Lucky Phil Extender" which shortens the throw of the shift lever. That is half your problem. And, as I have been well advised, it is also a big help to preload the shifter with your toe just before clutching. That helps all that mechanism into motion when the time comes. The other is a shift mechanism spring, which most of us will need at one point - but it requires quite a bit more digging into the trans. For a tune up, you might try some iridium plugs, as I found quicker starts/less cranking. The rest is in the "Decent Tuneup" thread. Gives you something to do with all of your spare time
Coppas have Öhlins. This one has Nöhlins. Wrong forks, shock, fairing, paint, handlebars. Other than that, it's fine. More questions than answers.
Yes, all works perfectly fine. The blink rate is adjustable to personal preference or legal requirements. EDIT: I see that the picture of the latest bulb shows no projector lens - no idea if that affects the brightness.
- 57 replies
- 2
My '04 has clear signal lenses and the following is the combo I settled on. I have used these for about two years now - no problems. In addition to the side LEDS which use the OEM reflector, the bulbs have a projector lens on the ends which focus the light straight behind you. https://www.amazon.com/iBrightstar-Newest-Extremely-Bright-replacement/dp/B07BXNMNRF/ref=sr_1_22?crid=NJN75N30DW71&keywords=ibrightstar&qid=1658273217&sprefix=ibrightstar%2Caps%2C159&sr=8-22 And this flasher unit - adjustable blink rate -also works well. https://www.amazon.com/Motorcycle-Flasher-Electronic-Signal-Adjustable/dp/B091PXFXFD/ref=sr_1_23?crid=1603YA1WSJQ6M&keywords=led+flasher+unit&qid=1658273542&s=automotive&sprefix=led+flasher+unit%2Cautomotive%2C147&sr=1-23 It even has the tab to fit in the OEM location.
- 57 replies
- 3
