Emeraldv11
Emeraldv11 last won the day on February 3 2021
Emeraldv11 had the most liked content!
Location
Ireland
My bike(s)
Flat tankers, brits and italians
Emeraldv11's Achievements
Guzzisti (2/5)
79
Hi to All,Just a thought... When the new E5 petrol arrived in Ireland some years back, the ethanol dissolved some old epoxy based thank liner treatment. It resulted in quite a few valves tightening when their guides got glued up with the accumulation of that goo, some carbs too were a nightmare to clean up. Worth checking inside your tank to see if it has been lined and the liner's melting away.
To straighten your bracket, If you have access to liquid nitrogen( your local doctor or a cattle inseminator) tie some wire on your bracket, dip it in the nitro and secure it in the vise wearing welding gloves and straighten it back to shape. The cold tightens the granular structure of the alloy (if thats the right words) and it wont break. I straightened many gear levers ,brake pedals etc that way and saved a fortune. Very handy for bending thick aluminium plating to make sumpgards etc
Hi to all, Oddyseys, Hawkers and top of the range Yuasa's are made in the same US factory. I got 10 years of use with a US made yuasa in my Stelvio, reselling the bike with its original battery still installed. Now, on the V11, a generic lawnmower battery (70 euros) is on its 4th year without trickle charging it. Battery life is a lottery and price has no relation to lifespan ,in my own experience anyway...
Looking at my first CARC bike, what to look for?
Emeraldv11 replied to activpop's topic in Newer models
All Stelvios bar the first 250 or so came with the bad followers ,mine was amongst the very first ones built and i did 65000k without any problems before i sold it. While in Mandello i enquired about getting a repair/mod kit just in case and in view of my engine number was told that i was a very,very lucky guy, that the second batch of followers was crap and people putting in a claim were sent another pure mozzarella set of followers and so on, some had 3 faillures in a row. I think that the V11 engine has much more character than the Stelvio. Always found the Stelvio very ackward to maneuvre around parking, more over with luggage. -
Hi from Cork, The last thing you want is waste your power into heat by running an underinflated tyre. Also you need your tyre to flex to increase its road contact area in order to provide grip. This is how to calculate: -First thing in the morning take your tyre pressure with a telescopic analogic pocket guage. -go for a good ride with your bike loaded with your gear. -stop and remeasure the tyres pressure when they are hot (with the same guage) Back tyre pressure should be between 5-10%higher than cold Front tyre pressure should be between 3-5% higher than cold. This is valid for all motorcycle tyre types ,type of bikes , loads and road surfaces.
The better Yuasa batteries are made in the same Pensylvanian factory as the Odyssey's. I recently bought a brand new pc545 for a customer's Vincent in which i was after fitting an electric start. That battery would not charge above 12.5v, would discharge in 3days down to 11.7v and give only 120 amps under test. So a Dud could appear amongst the bests
Hi to all, Any one wanting to swap a Verde Legnano seat cowl for a red one in good condition ?
Hi to All , My Greenie was pinging a bit on the original pipes and now runs absolutely perfect with mistrals without altering anything. A Complete Pavarottisation!
Hi from Cork! The old Nitromors active ingredient was Methylene Chloride and would dissolve any paint. It is now banned and the new stuff is as efficient as spring water. Hers in Ireland you can still get methylene chloride based stripper but only by 5 liters for 'professional use only', about e40 a can. If you check with suppliers of parts for the restoration of vintage tractors they should know how to get it. I will have to do mine next winter and i wil attempt it with the engine i situ, small section by small section. Its only silver paint that the previous owner did with a brush. I will leave it in bare aly with ACF50 surface treatment,like my T5
Hi to all, Concerning lithium batteries i asked my whole sale supplier why he was not stocking any of them. His reply was : i dont want to deal with all the waranty claims!
The Yuasa 'made in USA' are, i believe, made in the same factory as Hawker Odyssey's. My 2008 Stelvio's day one factory original Yuasa battery was still perfect when i sold the bike last year, no special treatment, no trickle charger just luck!
+1 !
ANSWERED Horribe clutch screech as soon as I touch the clutch lever.
Emeraldv11 replied to rich888's topic in Technical Topics
That was typical of the Stelvio starter buttons. Started the bike once amongst a big group taking off and did not hear that the starter stayed engaged. A mile further down the road and a lot of smoke. Got a replacement switch unit under waranty and it was faulty too. Fitted a big 60 amp starter button from a vintage tractor on the bars that gave no trouble for the next 10 years . -
Reviving an Old Garage
Emeraldv11 replied to Kane's topic in Special place for banter and conversation
Hi everybody. Here are a couple if pictures, the first one is the small bench ,what they call a hospital trolly. It lifts a V11 no problem and is very steady. The second one is electrically operated and the picture shows how easy it is to squeeze between bikes. Hope this helps.
