red lion
Everything posted by red lion
  1. Not yet. But I will give it a decent tune up, Do these bike need a new map when changing to open exhaust?
  2. After adjusting the CO fuel trim from -10 to 0 I took the bike for a ride and there was no change. The bike runs good for the about 10 miles, then as it heats up to running temp it starts to miss, with two very very small backfires, It sounded like the left pipe. the bike runs poorly under light throttle, but runs strong under heavy throttle. Again the bike ran good before I changed the stock exhaust to mistrals with the baffles taken out.
  3. Not one of the first 300. But I think they only made another 300 not numbered. Still fairly rare. I haven't seen another on the road since I bought the one I have, and It's also not numbered.
  4. GuzziDiag connected and worked fine and was very easy this time. thank you all for all the help. My CO trim was -11, Now at zero on the 2002 LeMans. Would -11 cause the bike to poorly? Do some bikes run better on the plus side of zero? I'll ride it on saturday.
  5. I found device manager on my computer. I then plugged in the FTDI cable and down loaded the program again. now when I plug in the FTDI cable, The device manager lists com port 3 under other devices. I will try the Guzzidiag again today.
  6. I'm running windows 11 home.
  7. I hate to say this but I don't even know what a task bar is or where to find it. I don't see any windows icons.
  8. I have the chipped cable from lonelec, but I had no wi-fi. a I will try again with wi-fi.
  9. I did all of that with no results. the com port was still blank. I could select English and my motorcycle but no com port.
  10. OK I down loaded guzzidiag, but I didn't transfer it to a folder. I got it to open but the com port was blank. maybe my mistake was not adding the down load for the chipped cable to a folder on my computer. I need some help.
  11. I tried to open the guzzidiag download and my computer said no internet.
  12. Do I need a internet connection to run the Guzzidiag program?
  13. When I hook up the cables to the bike, Do the red and black clips go to the battery?
  14. I downloaded V0.60. Now what 's the next step? do I download the reader and writer?
  15. I'm sorry, but there are so many software choices for windows that I don't know what to download
  16. I'm running windows 11 home. 64 bit. What I think I need, is what ECU model numbers these bikes are running to know what program to download.
  17. I just received the guzzidiag cables. I'm running windows 11. My bikes are a 2000 sport- 2001 rosso mandello- and a 2002 LeMans. What is the correct guzzidiag program download that I need?
  18. If anyone has a factory V11 rear rack that they would sell, or knows where I can buy one please let me know.
  19. I sent an email to Prodigium two days ago about the V11 rear rack availability, But no word back from them yet.
  20. Why not using it on the seat also?
  21. Thank you that was very helpful. How hard is it to use the guzzidiag program?
  22. I have the breakout harness and a carb mate. I have used them on my 1100 sport and others to set TPS and balance throttle bodies in the past. I have not yet tried to set the CO trim because my computer skills are not grate and just thinking of the guzzidiag program has stopped my in my tracks. I'm not even sure what the CO trim is. Is it the fuel mixture?
  23. Is this the correct cable to set CO trim? From Lonelec. Guzzidiag JP diag. Ducati diag kit- interface+adaptor (kit + 3 pin set)? SKU#LEZBGUZKIT01
  24. No I don't know how to set the fuel trim.
