red lion
Everything posted by red lion
My bike ran perfect before the exhaust change. How could that be timing or tune up related. Also it missed more after the bike warmed up. I think it's running lean, so how do I adjust the fuel mixture?
2002 LeMans. All stock, Ran grate, Then I installed a new set of Mistral exhaust, Now the bike is missing around 2800 RPM. What do I need to do to get it running good again? Can deferent exhaust change the CO? do I need a new map?
None of the moto guzzi suppliers had the O ring in stock. I found it at napa auto parts. All's well now. Thanks
It looks like 22 meets with the tank. #23 looks like the gasket. What part # would that be and is it available? Also where to purchase the gasket?
I looked at AF1 racing and for fuel tank they did not even show the fuel pressure regulator.
Gas is leaking on my 2000 sport where the fuel regulator and gas tank meet. Is there a replacement gasket available, And who would have one? I have not removed it from the tank yet.
I think the relays were taped to keep them dry. I was out on my 1100 sport and it started to rain lightly. The #4 relay got wet, the tach stopped, then the light got dim, then the bike died and I had to have towed home. After drying #4 with a hair dryer the bike started up and ran fine. I won't ride that bike if it looks like rain. I wonder if I sprayed the relays with cage deoxit if that would solve the problem and I'd be safe to ride.
Why wouldn't it fit. I have a 2002 LeMans?
I sent a email before, but never heard back from them.
I should of said chin pad, not tank pad. I still have it but it looks like a tank bag caused some wear on it. I read the link on the ShinEets grease. If anyone has a nice one please let me know.
Is the pad that is on top of the V11 gas tanks still available? If so where
I don't see any pricing on the Ghezzi Brian web site. How much would the kit cost to convert a Centauro?
Well I Got some Caig DeOxit, Took the kill switch apart, Sprayed it and worked the switch back and forth. It now works perfect. Thanks for the help.
I'm picking up some Caig DeOxit. Can the kill switch be dismantled to be cleaned or should I just spray in the cracks when working it on and off back and forth?
Well today checked to see if she would start, and nothing. I then worked the kill switch hard back and forth many times with no improvement. I then took my 1100 sport for a ride. When I got back four to five hours later I checked on the bike. Turned on the key and heard the fuel pump prime, Then hit the starter and it turned over and fired up. I never touched the adjustment on the clutch lever.
I haven't moved the bars yet. But I did adjust the clutch lever before the problem. That could be what's going on with the starter button, I'll check today. Also about a year ago my friend went down on his Griso, I pulled over and turned my bike off with the kill switch. Then turned it back to run and the bike would not start. I got a ride to my house to get my trailer. When I got back to my bike it started up and has been OK until the kill switch was tripped yesterday. What are your thoughts, bad kill switch. Bad # 5 relay? I'll see if she starts today.
The clutch was pulled in when I tried to start the bike.
2001 Rosso Mandello......When trying to start her up I turned on the key, the head light came on but no fuel pump sound. I then pushed the start button and nothing happened. I noticed that the kill switch had bin tripped. I flipped the kill switch to run but it was dead. The bike ran when I parked it. What do you think it could be?
I'm not sure if I need the hardware. There are the two screws that look like mounting hardware
I'm looking for a starter cover for my 2002 LeMans, Anyone have one they would sell?
Your information was very helpful. Thanks
How do you adjust the throttle slack on the V11. I don't see an adjuster on the cable like on other bikes?
There is no nut on my axle so it must be threaded. Thanks Doc.
2001 Rosso Mandello. I loosened the pinch bolts on the front wheel.Then began to remove the axle but the whole axle turned. Is the axle threaded on the left side of the bike?
