red lion
Everything posted by red lion
  1. 2001 Rosso Mandello. I loosened the pinch bolts on the front wheel.Then began to remove the axle but the whole axle turned. Is the axle threaded on the left side of the bike?
  2. Are the zerk fittings from the ebay link the correct replacement for the driveline?
  3. So are the three lube points the front and rear zerk fittings and the splines where the rear wheel mates with the rear end?
  4. Grease gun is new with new tube of Wurth Sig 3000. I will check for ball movement in zerk fitting.
  5. Do the zerk fittings need to be replaced some times? I don't think any grease is getting in? { zerk at back of driveline} I should see grease coming out, But I don't.
  6. Are there pictures of the three lube points?
  7. The rear, At the back,by the rear end.
  8. The krinkle black looks real good, That could be what happened. Anyway the CA. CHP let me engrave my own numbers and it is now registered. Thank's
  9. Rear wheel off and trying to lube the rear fitting on the drive line. With the grease gun on and pumping there is no grease coming out of the joint. I don't think any grease is going in. also it's very hard to remove the gun from the fitting. Do I need to replace the nipple on the drive line?
  10. The spot where the engine numbers should be looks perfectly smooth but blank. It looks like the factory just missed it. If the CHP would let me engrave a number, what engraving tool would be best to use?
  11. I just purchased an 2002 V11 LeMans from Boston, I'm in california. Just before I left to go to the motor vehicle department I noticed there was no engine number on the engine block.Where the numbers should be it was blank, Maybe the tag fell off. Are the engine numbers located in any other place also?
  12. Yes the TPS on my 1100 sport looks the same as my V11 sport.
  13. My 1997 1100 sport has idle stop screws
  14. When asking about the bleed screw settings, I am thinking about the bike running lean or rich (the sweet spot) Not as much about balance.
  15. What are you saying by - and a half and fully closed? The link list one turn out?
  16. Is the setting the same for a 1100 sport and a V11 sport for bleed screw opening? I have read 1 full turn and 3/4 turn opening. And would matter if air filter is stock or not?
  17. A set of stainless oval Mistral exhaust from MG Cycles for my 2002 V11 LeMans cost $671.00 They only cost $568.00 from Stein Dinse shipping included.
  18. I read on an other post not to pull the axle all the way out, Only about 6or7 inches That it makes the job easier. Is this correct?
  19. Can someone please tell me the correct way to remove the rear wheel on an 2001 V11 Rosso Mandello? I tried to break the axle bolt but the axle turned with it. What size hex key is used for the other side of the axle? And what should be lubed when the wheel is off?
  20. Sold for $16,585.00
  21. It would be nice to see some Moto Guzzi's in the parade.
  22. Would this be Elk Grove Power Sports in California?
  23. New clutch at 9400 miles ?
  24. The links not working for me, Is the bike still available?
  25. A bike just like this bike sold for $30,000.00 within the last year in south california at a dealer on consignment.
